Hi everyone,
I just got my first Les Paul and it plays like a dream. It is my first big guitar purchase so I am being a little picky and would like to get some feedback/advice on how to proceed with certain small issues. I plan to keep this guitar as there are no deal breakers but I wanted to know if the toggle switch not being perfectly flush with the body is something that others have noticed on 2017 Studio T models.
This model does not have the poker chip washer (like most 2017s) but it also uses a very shallow washer nut on top of the toggle switch. This means that it is almost impossible for it to sit absolutely flush on the body of the guitar which itself is not perfectly flat in that area. It could be that either the finish on top of the guitar is a little thicker in that area or that the surface inside the switch cavity is not 100% flat or parallel with the top surface.
I am including a couple of pics of my guitar as well as a stock photo I found online that also seems to show a bit of a gap between the washer and the body of the guitar.
It is a brand new instrument so I am hesitant to open things up and start fiddling with things and risking scratching the finish. For anyone who has played around with the 2017 Studio T model and installed the poker chip washer - were you able to unscrew the washer nut without tools? I would really appreciate it if people can check their 2017 models to see how flush the toggle switch nut is against the body.
Second small issue is some glue/gunk that is barely visible just in front of the first fret. I have not tried scraping it out because I was not sure if it was simply a residue that should have been cleaned up or whether it was there for some purpose. I am including a couple of pics.
Thank you for your feedback and advice.
