paddybrown
- Joined
- Oct 12, 2015
- Messages
- 76
- Reaction score
- 88
Not sure if this or Luthier's Corner is the right place to post this, but Luthier's Forum seems to be about building guitars, and this is a restoration, so here seems the most appropriate.
I found this guitar in a local second hand shop.
On examination it turned out to be a 2005 Les Paul Double Cut Faded - basically, a Special with stoptail and tune-o-matic rather than a wraptail bridge - somewhat inexpertly modified and refinished by some barbarian of a previous owner. It's been painted white, but the white paint wasn't very durable, so the original cherry finish shows through, the pickup routs have been enlarged to fit full size EMG humbuckers, it's been rewired for a master volume, master tone and two knobs that do nothing, the bridge volume knob hole has been enlarged and the switch moved there, and the pickguard chopped up. I thought I'd have a go at turning it back into a decent guitar. I tried removing just the white paint, leaving the original cherry, but it had got into the grain and I couldn't remove it without taking too much of the cherry off with it, so I sanded it back to the wood.
I rebuilt the pickup routs almost invisbly with mahogany wood filler. They still need a bit of work to even them out and straighten the edges, but I'm pleased with the colour match. Will hopefully be inconspicuous except under close examination.I also need to figure out how to make the hole for the bridge volume a bit smaller.
I came upon a pair of mini-humbuckers online, which would fit the P90-sized routs. I already have a Reverend Sensei Junior with a P90 in it, and I don't have a guitar with mini-humbuckers, so I bought them. Next stage, finishing. It has nice grain, so I want a transparent finish, but if I apply the colour directly it might take differently to the wood and the wood filler, leaving the repair much more obvious. So I'm going to try a clear sanding sealer first, then the colour, then a clear coat. Assuming the wood and the filler don't look too different under the sealer, I can spray the colour onto the sealer and it will look even. I'll need to rig up some kind of spray stand in the back yard.
Once the finish is done, then I need to worry about wiring it up. I'm really bad at soldering so I'll probably outsource that to a local tech.
