Lester
- Joined
- Mar 18, 2007
- Messages
- 823
- Reaction score
- 375
Sanity check? Additional electronic knowledge?
TL;DR: Below is my wiring diagram. Tone control is acting like a volume control but only on the bridge pickup.
The guitar is an Epi SL with two single coils. The pickups are not strong, resistance measures 5.6K and 5.5K Neck and Bridge. (I'd guess they have half the output of my mini-humbuckers when played through an amp). The bridge is weaker than the neck despite it being set very close to the strings and the neck being almost flush with the pickguard. I'd guess the bridge is about 1/2 to 2/3 the volume of the neck.
The tone control is cutting volume significantly on the bridge pickup. With the neck pickup, it only seems to change tone as expected. One the bridge, 10 gives me bright, but 0 gives me almost no volume.
It's not the cap (tested by replacement, and working fine on the neck pickup). It's not the basic wiring... the wiring was actually much more interesting with phase and serial/parallel switches. I rewired ground-up to this simpler layout to test and it didn't improve things at all.
Is there some interrelation between the weak pickups and 250K pots that might be happening? Those interactions are well beyond my electronic knowledge. Or maybe the bridge pickup has issues?
