Les Paul John
Ah yes, the hump. I bet you’re happy with the pickups you got in that.
I like buying used Epiphones because many people replace the pickups with “upgrades”. I got a gold top that had Seymour Duncan vintage styled P-90s. I wasn’t expecting that.
I think used Epiphones may start showing up if really recent with stock pickups given how good the Probuckers are. Doubtful many people are replacing those.
Jewel the Sapphire
After some consideration I decided on hotter pickups and tulip style tuning machines.
Now that im finishing up the frets its time to swap pickups and tuners with my Gibson SG!
Jewel the Sapphire
Yes the 57s, absolutely!
The classic has that unpotted squeal on high gain, but on clean- crunch, it is everything I ever wanted from a neck humbucker. Moving on.. balanced musical tone from the 57+. Holds up when you roll the tone, and full bodied break up in the volume.
Here is the SG before and after the swap, I forgot to
record the Les Paul before and after, it sounds so great with the George Lynch Screamin' Demon!
https://soundcloud.com/sapphiresounds/sd-demon-vs-57
Jewel the Sapphire
Pre drilled short pilot holes for the screws in back after tightening the bushings on the front to keep them aligned.
With the neck straight on the bench I got enough material off and polished everything up for set up.
The Seymour Duncan in the bridge is the George Lynch signature pickup. Now the neck humbucker is potted, a quality part pulled from an early Epiphone Les Paul Classic 2003 Made in Korea. Stamped HB6N.
For the wiring I bypassed the push pull pots (which already had .022uf caps) to solder the pickups straight to the volume pots. After that I tightened the pointers and input jack, then swapped the knobs to some lighter yellow golds.
Action is 4/64 treble side and 5/64 bass side.
Strings are top wrapped 11s, neck relief is just a papers height.
Very easy to play and get ahold of notes, the break angle is perfect and no more choking out up top!!
WaywerdSon
What u planning to do with the Grovers you took off? I might be interested in swapping a set of tulips for them.......
