1960 Les Paul Jr. and Fair Pricing (Updated Pics)
Dee Bone
On the left is low end fair condition. The right is the high end in EXC. Also these values all dealers utilize worldwide. Take into consideration condition, originality, the case & case candy.
Also values could be lower or higher pending these factors.
Dee Bone
The guide is used for base pricing. A mint 1960 Gibson Les Paul Jr with OHSC and case candy would fetch way more than posted values.
Liam
Kluson 3-a-side replacements fit these perfectly, but make sure you get the ones with 1/4" rather than 6mm shafts. I think WD make them, available from Fake 58 here in the UK.
For what it is, needing tuners and with non original knobs, I'd be looking to get it for $5k if everything else about it seemed reasonable. Good idea to have a guitar repairer with experience of 50's Gibsons look it over.
That Reverb listing looks very optimistic to me...
Liam
StSGLPJ
Liam
Thanks, Liam. I think I can get it for $3k and will most likely have a vintage guitar expert work on it.
none2low
3k would be a great deal IMO, definitely worth more based upon what can be seen in your pictures.
delawaregold
_______Artie_______
I wouldn't replace anything unless I absolutely had to.
The shaft can be straightened, and the pots cleaned.
I would use Fret Doctor on the Fretboard.
(Available at BeAFifer)
If you felt you had to, you could use the Meguiar's 3 part
cleaner / wax system on the finish, but I wouldn't even
do that. Good to go just the way it is.
LtDave32
Desert Star Guitars
Thanks again for posting. Looking at the pics, would you put this one in the $4500 range? Also - this has not been cleaned up at all. Maybe I can get the value into the $5000 range?
Pal, I don't think you understand how nice and lovely that is, as it is. It doesn't appear to have much "battle damage" from years of playing and abuse as so many do.
I just saw one at Hollywood GC that wasn't near that nice. And it was over 6K.
LtDave32
Desert Star Guitars
Nut isn't original either. But that's fixable to get it back to a Nylon nut as per the originals.
StSGLPJ
Are you talking about the shaft on the tuner?
StSGLPJ
is there a way to figure out which nut I should be buying? Is there product code? Same with the knobs and the plastic piece that covers the jack. I believe they’re not original.
truckermde
I learned from Dave that the original nut material is nylon 6/4, which is no longer available. Nylon 6/6 is your choice now.
delawaregold
_______Artie_______
Yes, the shaft on the tuner. I wouldn't try this yourself, but
send it to a Luthier that has experience in disassembling
the tuner. Do not try to straighten the shaft in an assembled
tuner. That is a recipe for disaster.
Rick Norman (Dr. Vintage) used to restore vintage tuners and
potentiometers, but I haven't heard from him in years. I don't
know if he is even in the business anymore. Perhaps someone
will have some info.
delawaregold
_______Artie_______
Eric is always a great option for you. I would buy the tuners as a set.
(Both Left and Right) To be sure they match patinas.
Also give him your Pot Codes, so he can get close for you.
StSGLPJ
My advice would be to immediately take it to someone who knows what they're doing.
i’ll have to start a search for somebody reputable. I’m in Eastern Pennsylvania if anybody has a recommendation.
