Fascinating; I love this almost Heath Robinson stuff.
Just so I understand what I'm looking at, it appears that the strap button is in fact a lever, (the hole in the body that it runs through appears to be slotted). When pulled upwards, the first lever pulls the long rod, which in turn pulls on the final lever, changing the tension on the B string. The spring also provides some resistance & returns the strap button to the "normal position. Yes?
So the pitch of the B string is altered by pushing the guitar down, whilst wearing it?
...& why the B string; what's the significance here?
What does this sound like; can you tell me which track(s), this guitar was used on?
...I take it the pup selector is redundant?
The pickup selector is fully functional. Routing is needed for
clearance of the switch housing if you are going to use an SG type 90 degree switch. This will clear the mechanism arm and allow for bigger bends. Mine has a regular switchcraft switch but there is a hole on the top side bout approx above the selector switch. It has a recessed screw which you can screw down as a stop for the internal bender arm. Mine is set where the arm just stops shy of hittin the toggle switch and is a perfect whole step bend. The song "All of my love" is a great song to play with a bender. I believe he used a B Bender tele for this song originally.
Here are some shots of mine that I posted in another thread. This first shot shows a view of the strap button actuator.
[/URL][/IMG]![]()
[/URL][/IMG]![]()
[/URL][/IMG]![]()
[/URL][/IMG]![]()
Wow, that looks like quite a commitment...
What was the base guitar that was done on?
interview with the inventor:
All is explained within...
The Byrds; Gene Parson's String Bender - YouTube
Interesting......
https://music.yahoo.com/news/robert...-led-zep-reunion-141025086-rolling-stone.html
I saw that this morning... It annoys the crap out of me that he claims playing with Led Zeppelin is not something he wants to do, but he has no problems filling his set lists with LZ songs these days when he plays live. It appears to me that he wants to be the center of attention and playing with LZ takes that away from him. he also seems to try and shift the blame quickly that it is not him that doesn't want to get together... its always someone elses fault.
However, doesn't page own the name to LZ? He should just start a new LZ with a new singer and move on from Plant if he wants to play and record...
I believe he only wants to do acoustic stuff with Jimmy at this point.
Hell I would go to an acoustic Zeppelin show
