ZW 81/85 Possible Faulty Buss?
Discussion in 'Tonefreaks' started by MisterStrike, May 20, 2010.
  1. MisterStrike
    MisterStrike Junior Member
    Nov 9, 2008
    I Recently purchased the Zakk Wylde 81/85 solderless pickup kit. I have everything installed and wired up but only one pickup would work. I have re-checked the wiring several times to make sure it was correct. My first thought was the three way selector switch in my Epi Les Paul Standard could be faulty. Because only one side would work, I purchased a new switch and installed it and the issue is the same. I moved both the neck pickup to the bridge side of the buss and I can verify that both of the pickups work using the bridge input on the buss. When I place them in the neck side of the buss I do not get any sound at all. I wired them up using diagram #8 in the instructions that came with the kit. Does anyone have any suggestions of something that I may have missed? Thanks for your help!
