Zoom G1Xon tube amp modeling
Discussion in 'Amp Modeling' started by Guitar Rod, Jun 8, 2016.
  1. Guitar Rod
    Guitar Rod Senior Member
    1,423
    666
    May 29, 2016
    I've never owned a tube amp, so I'm wondering what the "tube" setting does in a tube amp model on the G1Xon or any other amp models that may have it?
  2. Mindfrigg
    Mindfrigg Senior Member
    55,048
    296,279
    Dec 28, 2010
    A modeler simulates the conditions inherent in a system or device. The characteristics of components are broken down into elements and reproduced digitally. That is, the input is digitized then reproduced with modifications in the same way an analog component would change the sound. Tube characteristics and their effect on a signal are understood to a great degree. Exactly how well is debatable as you've no doubt observed on the forum.
    It's an effect not disimilar to the phasing, flanging overdrive, exciter, compressor...and other effects that are also now digital. I would say more complex though.
    1 person likes this.
  3. Guitar Rod
    1,423
    666
    May 29, 2016
    Thanks. I'll have to play around with it with less and more gain. 80 seems to be a nice setting. Now I know what to look for.
  4. cybermgk
    13,037
    16,757
    Jul 7, 2011
    In simpler terms, that 'tube setting' will most likely adjust the eq in subtle ways, how your attack affects the tone, in some way, and interact with the gain settings a little, in an attempt to sound like your using different output tubes in the amp being simulated.
  5. Guitar Rod
    1,423
    666
    May 29, 2016
    I didn't get a chance to play today, but it seems like it causes the sound to break up a little like a tube amp does. The manual describes it as tube compression. 100 was not great sounding, but 80 was a nice sweet spot for my settings.
