Zero Fret? Thoughts Pros and Cons Please
Discussion in 'Luthier's Corner' started by C Squared, Jul 25, 2009.
  1. soggybag
    soggybag Junior Member
    26
    3
    Feb 26, 2009
    I have been thinking about using a zero fret on my current project guitars. I really like the idea. It seems to make a lot of sense.
    I was looking at this: ZerO Glide | Fretted Instrument Replacement Nut System
    It's a zero fret conversion nut. Has anyone used one of these? I was having trouble figuring out the right nut size, and the cost is $30, so I started to think I could make my own. Essentially I just need a regular nut with a step on the fretboard side.
    My first idea was to make a jig that would allow me to swing the nut over the top of the router table in the arc of the fretboard (12" or 16" for example). After some thought, I started to think it would be too difficult to hold something as small as a nut in place, and the router blade might knock it free.
    My second idea was to just sand down a regular nut and add a shim on the fretboard side. The shim would be as wide as the shelf of the fret, minus the width of the tang.
  2. geoffstgermaine
    geoffstgermaine Senior Member
    385
    948
    Feb 7, 2013
    I'm a big fan of using a zero fret. I've used them on a number of builds and have always found the setup to go smoother than on a neck with a conventional nut. The downside to me is the lack of adjustability and having to explain what it is and why it is there and why it is used instead of a conventional nut.
  3. cmjohnson
    cmjohnson Senior Member
    1,566
    1,034
    Dec 13, 2012
    To extend on my idea of using a zero fret with a nut that covers it, I would also mill off the body-facing side of the zero fret, so it becomes a half fret. This would probably best be accomplished with a side cutting file with the face of it that touches the fingerboard being smooth and non-cutting. This way, the fret and nut assembly would look like a conventional nut unless you were very observant. And that avoids the issue of it LOOKING like a zero fret design, which many people associate with cheap imported guitars from the 60s and 70s even though the design itself is quite sound.
  4. geoffstgermaine
    385
    948
    Feb 7, 2013
    I might remove slightly less than half of the fret for wearing reasons. The other concern would be to ensure that there is enough fretboard material to hold the tang - making a solution that does away with the tang or has part of the nut sitting on the fretboard surface. For me, I'd probably consider this too much work to be worth it, but you might have a more elegant solution in mind.
  5. frankv
    14,528
    12,925
    Aug 25, 2011
    Isn't the Buzz Feiton system a better approach as it's much easier to maintain and install?
  6. ihavenofish
    ihavenofish Senior Member
    2,320
    827
    Jan 17, 2010
    ummmm.
    zero frets are not more expensive, not created by "the germans", and certainly not being used on all (if any) gibsons for 2015.
  7. soggybag
    26
    3
    Feb 26, 2009
    I would say the Buzz Feiton system is something different. Where the Zero fret swaps the nut for a fret. In a way you could look at this as having a permanent capo on the first fret.
    The Buzz Feiton system changes the nature of the nut. You could look at the Feiton nut as a compensated nut, like a compensated bridge.
    I have tried the Buzz Feiton nut on a fender style guitar. I did not like it. The nut I had was two pieces, with the compensated upper piece attached to the lower piece with two small screws. It was made of a material similar to the graph tech stuff. It seemed to improve open chords, but didn't do a lot for the rest of the fretboard. So there was a minor improvement in intonation.
    The sound of open strings was weak on the other hand. I think this had to do with the two piece nature of the nut, the material, and the the way the slots were molded. I had a brass nut before which had a great sound.
    I see the zero fret as the easiest way to get the optimal string height at the nut. With the added bonus of having open strings sound like fretted strings.
  8. frankv
    14,528
    12,925
    Aug 25, 2011
    Yeah, I hear ya on that. I had a BF on my Washburn X50PRO.
    It is written that the zero fret, no matter how hard it is, still wears out at an alarming rate and causes other problems like fret buzzing.. Any word on this?
  9. SteveGangi
    SteveGangi V.I.P. Member
    30,880
    57,361
    May 20, 2010
    My old Gretsch had a zero fret. It worked fine, and never had any problems whatsoever.
  10. ihavenofish
    2,320
    827
    Jan 17, 2010
    it will wear, but it shouldnt be all that fast. less than the rest of the fret wire.
    as for buzzing. it makes it the same as a regular fret, so its entirely dependent on the setup and fretwork quality if it buzzes.
    a regular nut is high which gives some forgiveness on open strings but that's about it.
  11. KnightroExpress
    KnightroExpress Senior Member
    1,392
    1,407
    Sep 5, 2013
    I've never heard of that problem with a zero fret, though my experience is limited to a lot of reading and little else. I'd imagine if that is the case, you could use a stainless steel zero fret for durability and keep the rest of them NS or whatever you prefer.
  12. cmjohnson
    1,566
    1,034
    Dec 13, 2012
    My opinion on the Buzz Feiten system is that it only has a single benefit: Putting money in Mr. Feiten's pocket. It changes the tempered tuning in an already well tempered tuning system, only applies to open notes and chords with open notes in them, and restricts you to keeping the guitar in the standard relative tuning. Change the tuning to something other than EADGBE (or something featuring the same intervallic sequence) and the guitar will play MORE out of tune, not LESS. So in short I'm strongly opposed to the usage of that particular GIMMICK.
  13. soggybag
    26
    3
    Feb 26, 2009
    I don't want to knock Buzz, I'm sure he believes in his system, and he has some followers. I personally did not like it. Once you're on fretted notes it seems the effect of the BF nut, is close to nil.
  14. jiveturkey1
    jiveturkey1 Senior Member
    1,471
    634
    Mar 3, 2010
    Not an expert here but to clear something up......a zero fret SHOULD be higher than the first fret. The same distance a nut slot is, right? If not you would need a he** of a neck relief to clear the 1st fret. Or am I missing something? What's the best way to do that, one taller fret wire at zero?
  15. soggybag
    26
    3
    Feb 26, 2009
    That's a great question. I'm not an an expert. That said, if you can have great action from the second fret onward, it seems that if the zero fret were the height of the other frets it would work fine.
  16. cmjohnson
    1,566
    1,034
    Dec 13, 2012
    The zero fret is levelled and dressed as part of the fret job. It yields the same action height as a fretted note. It is NOT left higher than the other frets.
    Ideally, the slot depths of a conventional nut are equal to the height of a zero fret in its place.
  17. jiveturkey1
    1,471
    634
    Mar 3, 2010
    Thanks for the clarification. It took me awhile to wrap my head around this. I thought the bottom of the nut slots had to be slightly higher than the first fret. Makes perfect sense when you consider fretting the first or any fret when the frets are level with each other. Or using a capo. Neck relief and or bridge height takes care of the rest........I think.
  18. jiveturkey1
    1,471
    634
    Mar 3, 2010
    You said, "Ideally, the slot depths of a conventional nut are equal to the height of a zero fret in its place."
    So a guitar with a "higher action" at the nut, the slots would be higher. The lowest action at the nut would be slots level with first fret. Any lower would result in first fret buzz. So to get perfect "low" action with a zero fret would be pretty easy when leveling frets...... I think?
    Am I getting it now?
  19. jiveturkey1
    1,471
    634
    Mar 3, 2010
    Sorry for 3 posts in a row but while I'm thinking about it, could someone provide a link to explain how to get the perfect nut slot height with feeler gauges? Not entirely off subject I suppose.
  20. LtDave32
    LtDave32 Sua Sponte Super Mod Premium Member
    28,439
    82,994
    Mar 19, 2010
    Gretsches used them, and who, if they love old guitars, doesn't love old Gretsches? Wobbly, wonky, funky ol' things they are, and I'm not a big fan of zero frets, but I do love them ol' Gretsches, zero fret and all. They for some reason to me get a pass. The rest of the zero fret guitars, meh.
    1 person likes this.
