Zero Fret Opinions
Discussion in 'Luthier's Corner' started by Adinol, Sep 18, 2015.
  1. Archer
    Archer Senior Member
    886
    448
    Apr 18, 2011
    Yeah, I could do that, and I may. I have wondered if it affects the tone having that gap in there. Maybe I'm being anal retentive. I need to play that guitar a little more; it's been a while.
    1 person likes this.
  2. Adinol
    Adinol Senior Member
    200
    132
    Jun 25, 2015
    I've wondered about the same thing.
    If a zero fret is installed inside a regular slot of an extended fret board, that fret is anchored on the board as any other fret, as both sides of the crown are touching the board. But when you place it at the outside, with the extension, and the string tension pulling slightly backwards, I feel in some cases that fret might not be transferring the vibrations through the soundboard exactly the same way.
    I guess the question to ask is, does it kill sustain?
  3. p45
    p45 Junior Member
    23
    9
    Mar 31, 2012
    i have used zero frets in most of the instruments i have made ive used the same fretwire for the zero fret as the rest of the board (jescar gold fwiw) the guitar i use the most is about 3 years old and the zero fret is hardly marked let alone worn
  4. syndromet
    syndromet Senior Member
    547
    1,042
    Apr 6, 2011
    I have a zero fret on my Yamaha SA-5. It's one of my best playing guitars, and works wonders. The zero fret has a lot less wear than the other frets.
