Zero Fret Opinions
Discussion in 'Luthier's Corner' started by Adinol, Sep 18, 2015.
  1. Adinol
    Adinol Senior Member
    200
    132
    Jun 25, 2015
    I was wondering what are your opinions on zero frets.
    As a teenager I had a guitar with a zero fret. That fret had indentations similar to wear that we see on the first three frets. But the frets on that guitar were made of standard material. In other words, not stainless steel.
    Perhaps with stainless steel frets the zero fret is a better idea.
    But what are general opinions about this?
    I'm sure you all know StewMac sells a zero fret conversion kit. But I'm not really talking about that. I'm thinking of finishing up my current build and future builds with stainless zero frets.
    Thanks...
  2. Archer
    Archer Senior Member
    889
    450
    Apr 18, 2011
    They work great, but have a stigma of being associated with cheap Japanese guitars of yesteryear so virtually nobody uses them. When I saw the Zero GlideĀ® | Replacement Nut System for Stringed Instruments system when it came out a few years ago I was intrigued. So I cut a bone nut in a similar fashion with a file and made one for myself for a LPjr I had. It works perfectly and it doesn't look "different" like a zero nut normally does. If the look bothers you, try the ZeroGlide or make one for yourself. It's reversible so if you end up not liking it, just try something else.
  3. Bill Hicklin
    Bill Hicklin Senior Member
    7,539
    10,203
    Nov 3, 2014
    Selmers and Selmer-Maccaferris had them
  4. ricky1918
    ricky1918 Senior Member
    400
    183
    Jun 26, 2014
    Do you have a pic of you LPjr to show please? thanks
  5. Baylin
    Baylin Senior Member
    1,150
    846
    Feb 16, 2014
    Whilst I'm not against the concept, the original brass adjustable zero fret nut Gibson recently introduced was crap. It wore grooves into it within 2 weeks. I got it smoothed out and again it wore grooves into it very quickly. When I complained to Gibson they replaced it with a harder alloy similar to the frets so hopefully it'll all be good for many years to come
  6. B. Howard
    B. Howard Premium Member
    501
    423
    Apr 19, 2014
    I have had this guitar for 30+ years and it is still one of my favorites. The zero fret is a wear item just like a nut and needs periodic replacement
    [​IMG].
    1 person likes this.
  7. emoney
    emoney Senior Member
    7,021
    3,189
    Jan 31, 2010
    My only Zero Fret guitar is a '69 Framus acoustic and I have to admit, I kinda like it.
    There's no nut to worry about, that's for sure. Not sure why, but before I got this, I never
    considered anything other than a standard, bone-nut-setup.
    If the zero fret has wear, odds are the rest of the frets might as well, but that's the reason
    why we periodically have to do re-frets.
  8. Baylin
    1,150
    846
    Feb 16, 2014
    If the zero fret needs replacing more often due to being in constant contact with strings under tension, would it be prudent to remove the tangs and use just ca glue to hold it place to avoid undue fretboard damage?
    2 people like this.
  9. Adinol
    200
    132
    Jun 25, 2015
    That is an EXCELLENT point!
    Thank you all for sharing your thoughts. I guess I will experiment with it and see how it holds up with stainless fretwire. Should have a longer lifespan than nickel/silver.
    Thanks again...
  10. Bill Hicklin
    7,539
    10,203
    Nov 3, 2014
    Stainless is harder than the mild steel used for unwounds and the nickel wrap on wounds- it should last darn near forever, or at least as long as a bone nut.
    2 people like this.
  11. David Mccarroll
    David Mccarroll Senior Member
    1,775
    1,265
    Oct 12, 2011
    gotta bear in mind that its position in relation to scale length is absolutely crucial, so a fret slot isn't a terrible idea.
  12. Jim Engen
    Jim Engen Senior Member
    346
    92
    May 7, 2011
    Works great! I did that on my last build. Used Stainless. It's been about a year and I play it every day. Not a scratch on it. The string is just resting on it so it's not like most frets where you bending and doing vibrato. Should last forever. You still have to us a nut or something similar to hold the strings from sliding back and forth. I'm going to do it on my next build too. I don't really notice an open tone difference. I just think it's easier than cutting perfect nut slots
  13. ARandall
    ARandall Senior Member
    11,801
    7,199
    Apr 16, 2012
    Yep, constant pressure will do less wear than the smashing of a string into it as you fret, let alone the aggressive rasping with vibrato and bends.
    And building and using any guitar is an acceptance of wear down the road. Whats one more fret in the general scheme of things.
  14. Archer
    889
    450
    Apr 18, 2011
    Yes, a terrible pic but a pic nonetheless.
    Ideally, you wouldn't want the slight gap between the nut and the end of the fretboard, and one day I'll get around to fixing that. I simply need to file away a little more bone between the zero fret and the string slot side of the nut. But it plays fine as is.
    2 people like this.
  15. KnightroExpress
    KnightroExpress Senior Member
    1,392
    1,411
    Sep 5, 2013
    I'm actually about to start working on a buddy's old Teisco KL4. It's got a zero fret and desperately needs a refret, so I'm gonna do the stainless zero and NS for the rest. I'll post pics soon.
  16. cmjohnson
    cmjohnson Senior Member
    1,574
    1,036
    Dec 13, 2012
    To me, the ideal situation would be to have a hardened steel zero fret, ground in with diamond stones, with an overlapping nut that only sets string spacing.
    The zero fret is a logical product but as has been said before, it suffers from the stigma of having been featured frequently on some very cheap Japanese guitars from the 60s.
  17. Adinol
    200
    132
    Jun 25, 2015
    How about just filling the slot from the sides with some kind of soft putty (like the synthetic clay for kids)? At the end, it's just about the appearance and not having an ugly gap. If you use black, it might actually look nicer than trying to color match (which will never be dead on).
  18. Adinol
    200
    132
    Jun 25, 2015
    Would the ideal thing be to have all the frets like that? They would simply never wear out. But it would be quite a job to dress the frets. But with the right tools it would be possible.
    Stigma is one thing and physics is another. I guess there is also a stigma that Gibson guitars don't have that. But in my mind I was always wondering why that was not the preferred standard, as a zero fret does make the open string more like a fretted string.
  19. Adinol
    200
    132
    Jun 25, 2015
    The direction I am leaning in, with my build, is to do a stainless zero fret and a machine bolt for the nut. The machine bolt gives perfect spacing and I would adjust its height to be perfect for whatever gauge of strings. The only thing that I foresee as a potential problem is the radius. But the radius isn't pronounced and in my case the nut width is also narrow. I'll be posting progress notes in my thread (and I did some work today, BTW, I just have to post).
  20. Ripthorn
    Ripthorn Senior Member
    1,495
    1,150
    Mar 7, 2014
    When I do a zero fret, I use a regular nut with the slots cut extra deep as my string spacer. It makes it so that it doesn't look so weird but you get the performance of the zero fret.
