would you buy?
Discussion in 'Other Epiphones' started by geddy, May 10, 2013.
  1. geddy
    geddy Senior Member
    649
    585
    Dec 30, 2012
    Would you buy an Epi flying V with a crack in the finish below the neck joint. Seller believes it to be just finish. Is this something seen on these guitars or am I right to suspect the neck joint might be cracking?
  2. makoshark
    makoshark Senior Member
    600
    644
    Apr 13, 2013
  3. geddy
    geddy Senior Member
    649
    585
    Dec 30, 2012
    thanks. I know theres no easy answer just need a sanityy check
    only pic I have
  4. makoshark
    600
    644
    Apr 13, 2013
    That just looks like a lacquer crack along the glue join. Nothing serious to worry about,only cosmetic.
  5. Tanqueray
    Tanqueray Senior Member
    2,052
    2,141
    Apr 6, 2012
    My guitar has a crack near that location and it's just in the finish. Had multiple luthiers check it out and they said it was fine and that there was no cause for worry about the wood breaking or anything like that.
  6. paruwi
    19,899
    26,494
    Dec 24, 2009
    I would not buy it....
    not even if it had no flaws....
    cause I don't like the V-shape :naughty:
  7. Mr Teeny
    Mr Teeny Senior Member
    3,543
    2,402
    Dec 27, 2010
    Poly doesn't just crack on it's own, especially along joints, that's taken some sort of knock on the neck for it to crack and split the finish below the joint. Doesn't necessarily mean the necks buggered but without seeing it in person you can't really tell. Unless it's a real bargain it's probably not worth the hassle.
  8. geddy
    geddy Senior Member
    649
    585
    Dec 30, 2012
    While it was £70's it seemed reasonable. It went for more and not to me
