Work order guesstimate
Discussion in 'Other Epiphones' started by Paully, Feb 19, 2015.
  1. Paully
    Paully Senior Member
    187
    162
    Nov 22, 2013
    Hi,
    Thinking of taking my 16 year old Epi Joe Pass in to have the frets leveled, crowned and polished. I'll also have a complete set-up done at the same time.
    The frets have very little wear so I'm thinking that the fret job won't require anything extraordinary.
    As for the set-up I'd like for them to set the relief, action and intonation and spray the pots and switch with contact cleaner.
    I'll provide the new set of strings for the set-up.m
    So what I'm looking for is a SWAG
    (scientific wild ass guess) or ballpark figure on what this is gonna cost me.
    I know that the market I'm in is gonna be the deciding factor, however if I can get some figures from you guys I'll be able to come up with some kind of half assed idea of whether the shop is being honest or trying to take me for all I've got.
    Thanks in advance,
    Be excellent to each other ☺
    Paully
    GEAR:
    Epiphone Joe Pass Hollowbody
    Squier Stratocaster SE
    Yamaha F335 Dreadnought
    Yamaha Thr 5 Amp
    Tascam DR-05 Digital Recorder
    Dell Latitude Laptop
  2. edselman
    edselman Senior Member
    1,164
    604
    Mar 19, 2010
    A couple of hundred dollars at least. I do my own work. I purchased the tools from Stewart MacDonald, purchased Dan Erlewine's book and watched lots of do-it-yourself videos online. A fret level, crown and polish is costly because it is so labor intensive. If you spend the money on good tools and learn to do the job you can do all of your future setups yourself and save big time. Also, most guitars you buy today have not been properly setup and the frets are not level.
  3. Paully
    187
    162
    Nov 22, 2013
    Thanks for the response
  4. Rocco Crocco
    Rocco Crocco Senior Member
    6,573
    7,776
    Feb 8, 2013
  5. straybeat
    straybeat Senior Member
    2,629
    1,460
    May 11, 2011
    IMHO, depending on where you live, the general cost of the area and the level of expertise to get the job done, it could be anywhere from $50 to $150-ish. Up to the $200 if the luthier "has made a name for himself."
  6. Phildog
    Phildog Senior Member
    3,602
    1,449
    Apr 11, 2010
    Paully, what area are you in? That would help a lot. And the guesstimates would be a little more accurate.
  7. Brians Evil Twin
    Brians Evil Twin Poophoria Sōtō Zen V.I.P. Member
    10,811
    27,557
    Apr 24, 2012
    I'd charge maybe $40 for the neck adjustment/setup/cleaning the pots and another $80 to $100 for a "light" fret level and polish. Slightly more if I scraped the board down. But it's hard to know how much work the frets need until you get it on the bench, set the neck to zero relief and go over all the frets with a rocker. Sometimes you find a few high spots and can just take a little off with a crowning file, other times there are too many and you have to use a radius block and re-crown them all. And a lot depends on how low you like your action. It's a lot trickier to get the action down low and have it be stable over changing temps/humidity, string changes and carting around.
    But while it's up on the bench you may want to consider upgrading the jack to Switchcraft at least and possibly the switch too. The jack is easy so maybe another $20, perhaps $40 for both. Another good upgrade is a bone nut. Now, I work out of my basement shop as a hobby, so you'll probably want to double those rates if you take it to a full-time luthier in a major metropolitan area. Triple if it's in or around NYC.
  8. mgrasso03
    mgrasso03 Junior Member
    23
    33
    May 25, 2010
    I just had my Masterbilts worked on.
    One had a setup (I supplied the strings), humidification, truss rod adjustment and the frets leveled and ends smoothed for $60.
