Wiring Library
Discussion in 'Tonefreaks' started by ashbass, May 30, 2007.
  1. jonesy
    17,168
    4,387
    Mar 28, 2008
    Yep ground is a ground, they all end up at the output jack :)
    You're welcome bro, hope your wiring project turns out great.
    Jonesy
  2. Twofox
    Twofox Junior Member
    5
    2
    Apr 23, 2015
    Well it's done! Took a bit to cram everything in there but the new Calig PU's sound great. Used a super pot from rsguitarworks, along with a cts 500k taper tone pot and a .022 rs guitarcap. Included a tusq nut. Nice project (my first). Used the 50's mod for the tone cap.
    One thing is strange though, and that is when on the treble side of the switch, the tone turns the volume down. The switch is still original, has some static, and did that before the upgrades.... bad switch?
    Before:
    And after:
    New strings: (Epiphone SG Special)
    I picked this up off of craigslist for $45 with a non-working PU. The tech at the guitarshop ungrounded that for free, but I wanted to upgrade it anyway. Now it sounds great!
  3. Twofox
    5
    2
    Apr 23, 2015
    The more I look at it, I suspect not grounding the tone pot to anything other than itself may be the issue?
  4. jonesy
    17,168
    4,387
    Mar 28, 2008
    Yeah the tone pot needs to be grounded to work properly.
  5. Twofox
    5
    2
    Apr 23, 2015
    Sweet, thanks. I noticed it wasn't grounded before either. :thumb:
    1 person likes this.
  6. ry_
    ry_ Junior Member
    17
    3
    Oct 3, 2010
    I have some wiring questions about my 3-PU custom. I want to upgrade my caps and pots from stock as well as switch to 50's wiring. I should mention I have been mostly happy with the wiring configuration of the guitar and have flipped the magnet in my bridge PU in order for it to be out of phase when selected with the middle PU. My only real complaint (besides the unavoidable out of phase volume loss) is that I notice some muddiness when rolling back the volume. I think this could be cured by the pot/cap upgrades and 50's wiring, and I want to try and maintain my current configuration and avoid and push/pull pots and 3PU specific harnesses.
    Currently the controls are as follows:
    rhythm toggle= neck PU with neck volume and neck tone.
    middle toggle= middle PU and bridge PU (together magnetically out of phase) with bridge volume and bridge tone controlling both.
    treble toggle= bridge PU with bridge volume and bridge tone.
    Looking in the control cavity it seems to me the pots are wired in the modern style similar to the way a 2PU guitar would be, with the exception that the middle PU lead is connected to the same pot and lug as the bridge PU.
    Would installing in a normal 2-vol, 2-tone harness allow me to leave my toggle switch and jack untouched, connect my PU's in the same configuration they are now to the new pots (with the neck PU to neck vol and the mid and bridge PU's to bridge vol) and the only difference being switching the lugs from modern to 50's style? If it is possible to do this, I am leaning towards some .022 NOS sprague vitamin-q's in a harness from one of the mlp vendors.
    The pic at the bottom is upside down. Keep in mind this is for a left handed guitar. the bridge volume is at the top and it is a hard to see due to my bad picture but the two PU leads connect to the outside lug. the neck volume is at the bottom. I assume the yellow insulated wires are the grounds, with the neck tone grounding the tailpiece post. Thanks for the help!
  7. jonesy
    17,168
    4,387
    Mar 28, 2008
    No. The 3 pickup LPs have a specially designed switch that is not the same as a regular stock 3 way LP switch.
  8. ry_
    ry_ Junior Member
    17
    3
    Oct 3, 2010
    Thanks jonesy. So I would still need to buy a 3PU harness even if I left I my stock 3PU toggle switch in the guitar? What I am having trouble wrapping my head around is this: Say hypothetically I needed to replace a pot, I could just swap in a new one for the old one. Now say I needed to replace all pots. To me it seems as if I could just straight up switch the pots one by one and wire everything back in the same way. So far so good, right? What is the difference between doing this and just buying a complete 50s harness? The only changes I can see to the wiring would be swapping the lugs to 50s style. Is that alone going to cause wiring issues? Sorry for my ignorance if I am missing something obvious but I am having a hard time understanding why I cannot install a 50s style harness instead of 4 separate pots and 2 caps. I was under the impression that the harness didn't come with a new 2PU specific toggle switch and I could reuse my 3PU switch with the new 50s harness. Your thoughts?
  9. ry_
    ry_ Junior Member
    17
    3
    Oct 3, 2010
    Also, since I currently have my bridge magnet flipped, if I got a 3PU harness I would need to flip this magnet back to normal to avoid neck+bridge being out of phase when used together. I could then flip my middle PU magnet to get out of phase tone when neck or bridge are used with it.
    A 3PU harness and switch would be wired something like this...
    (With bridge tone push/pull NOT active)
    Rhythm= neck
    Mid= neck + bridge
    Treble= bridge
    Will my vol and tone controls still work as normal?
    Bridge tone control would be a push/pull turning on middle pickup, so when active I would have
    Rhythm= neck + mid (out of phase)
    Mid =neck + bridge + mid (out of phase)
    Treble= Bridge + mid (outof phase)
    If I do this would I still have use of my volume and tone controls when the mid PU is selected?
    For reference, if I choose a 3PU harness, this is the one I am considering: Prewired Les PaulĀ® Custom 3 Pickup Wiring Harness – Martin Six String Customs
    (My Apologies jonesy, I realize mssc is a competing vendor. Hope you are not offended. You both offer stellar products and have great reputations. I am only leaning towards his harness because I want some other parts as well that so far I have only found on his site)
  10. mux164
    mux164 Senior Member
    2,618
    1,869
    Sep 1, 2012
    hi there, i rarely frequent here but i have a question, i have a 96 ibanez rg270 with the usual deal, its a hsh guitar, i had it all wired up using a diagram from Ibanez.com | Wiring Diagrams
    anywho i wired it up following this diagram, tested it out and then when i was locking the pots into place volume pot spun around and took off the ground wires off the back of the pot,
    long story short i found 2 stray wires that i think came off the switch, i dont know what to do with them, does/would anyone be able to do up a full schematic including all the wires that come off the switch?
    thanks in advance, if not i will get it done but a pro
  11. mux164
    2,618
    1,869
    Sep 1, 2012
    okay this is what i am working with, i ended up cutting the wires off, i will clean up the solder and hopefully start again if someone could show me where the wires go on the switch before the pickups are connected
    URL=http://s1328.photobucket.com/user/mux164/media/ibanez/IMAG1302_zpsncjtrhwc.jpg.html][​IMG][/URL]
  12. Big John
    Big John it's all about the shirt V.I.P. Member
    7,209
    6,318
    Mar 18, 2007
    Don't know if this layout has been posted here or not, so here you go. It'll work for any 3-pickup electric instrument. This is what I did on my Warmoth JPJ bass, but you can use it for anything with 3 pups...
  13. skrumian
    skrumian Junior Member
    18
    4
    Sep 20, 2010
    I have 2013 Traditional Pro II which has 3 push-push pots (that is, 2 volume with push/push each for coil-splitting; 1 tone with push/push connected to 9v battery to activate 10db boost) Can you make it into 50s wiring but still retaining boost and coil splitting functions? I always wanted how 50s wiring cleans up using volume.
    This is the gut shot of my Trad Pro II:
  14. ScottMarlowe
    ScottMarlowe Senior Member
    3,294
    2,795
    May 2, 2014
    Yes, in this case you want to move the wire that goes from the tone to the volume pots from the outside lug on the volume pot where the pickup connects, to the inside lug of the volume pot where the wire goes out to the switch. This moves the capacitor to be further away from the pickup, electronically, as the volume is turned down. In this picture that is, I believe, the brown wires.
  15. skrumian
    18
    4
    Sep 20, 2010
    Hey man, thanks. How about if I totally remove that blue capacitor, then remove brown wire in Vol and put it on ground. then solder 0.022 capacitor in Vol middle lug and Tone outer lug? (Just like the 50s wiring.) But not sure if coil splitting and boost will still work?
  16. ScottMarlowe
    3,294
    2,795
    May 2, 2014
    Electronically they're the same thing. Some folks like the cap going from the tone pot to the vol pot, some folks like a wire. The electrons won't know the difference. OTOH, changing cap values definitely will.
  17. notjoeaverage
    notjoeaverage Senior Member
    549
    369
    Apr 7, 2012
    I checked all 42 pages nobody had what I was looking for naturally.
    Anybody have a wiring diagram for a Master volume NV BV and Master tone 2 pup configuration with an inline switch not a toggle and 50's setup.
    Epi Kats or some Gretsch
  18. drew365
    drew365 Senior Member
    1,226
    856
    Oct 23, 2011
    I've been searching for a diagram, but can't seem to find exactly what I had in mind for my Strat.
    Neck: Fat 50 Single, Mid: Fat 50 Single, Bridge: SD Pearly Gates HB
    One Volume, two tone, 5 way switch
    Tone one controls neck and mid
    Tone two controls bridge
    Bridge coil split with a push / pull pot on tone two, or coil split on position 2 of the 5 way.
    Also, should I use a 500k pot for tone 2, and should I have a cap on both tone pots? If so, should I use .047 for tone 1 and .022 for tone 2?
    Thanks for any help. I've been trying to do all my mods myself, but I like to have an accurate diagram whenever possible so I'm not guessing too much.
  19. Cantaffor59Lespaul
    Cantaffor59Lespaul Junior Member
    3
    3
    Dec 16, 2015
    Thanks a million for listing these diagrams. I had them but lost them so Thanks Manny
    2 people like this.
  20. the drew
    the drew Junior Member
    19
    4
    Nov 12, 2012
    awesome cool
