Wiring Library
Discussion in 'Tonefreaks' started by ashbass, May 30, 2007.
  1. cgm
    cgm Senior Member
    444
    195
    Feb 13, 2012
    Edit: never mind, I am going a different route with my bb3.
  2. jay1williams
    jay1williams Senior Member
    2,160
    1,014
    Mar 3, 2010
    How would I wire this up for 50's style?
    It almost looks like the one above, but that one has the cap grounded to the tone pot.
    My understanding was you want the cap between the vol and tone pots?
  3. David Collins
    David Collins Senior Member
    1,066
    792
    Dec 20, 2009
    50's style = output loading of the tone pot. All you would need to do is move the white wire between the volume and tone pots over to the center lug on the volume.
  4. JCarno
    JCarno Senior Member
    1,740
    754
    Nov 17, 2010
    I need some help. I'm embarrassed to have to ask this but here goes.
    I wired up an LP 3 way switch with braided wire. Like a dumb ass, I forgot to label the leads.
    I'm sitting here with my multimeter trying to figure out which is which.
    With the meter set to ohms, what reading am I looking for to determine what lead I'm testing? I just can't wrap my head around it! :eek:
    Without touching anything, the meter reads O.L. When I touch the leads on the meter to each other, I get 000.0. So which of those readings am I looking for if I have one lead on the hot of the switch wire and one touching the switch prong where the hot is hooked up?
    Hope this isn't too confusing, I tried to explain it the best I could. Thanks!!
  5. jay1williams
    2,160
    1,014
    Mar 3, 2010
    So if I wanted to remove the coil tap would I just tape up the green and white wires from the pickups together?
    Thanks!
  6. jonesy
    17,130
    4,364
    Mar 28, 2008
    TV Jones 4 conductor color codes if anyone needs to know them...
    White +
    Black -
    Red/Green series link (coil split optional)
    Bare wire is baseplate and cover ground (isolate for phase mod)
  7. DrBGood
    DrBGood Senior Member
    813
    789
    May 17, 2013
    Has this one been asked before ?
    2 P90S from a 2014 Melody Maker to be installed in a Special 1 Epiphone les Paul. PUs have 4 leads + bare. Guitar has one volume, one tone, three way switch. Wire colors are black, red, green and white.
    I want them installed as regular P90s, no coil splitting or anything.
    Thanks.
  8. jonesy
    17,130
    4,364
    Mar 28, 2008
    Those are stacked P-90s so they have two coils just like a humbucker
    Red +
    Black -
    Green/White solder and tape off (series link for coil split if desired)
    1 person likes this.
  9. DrBGood
    813
    789
    May 17, 2013
    Great, thanks a whole lot Jonesy !
  10. jonesy
    17,130
    4,364
    Mar 28, 2008
    You're welcome bro. :thumb:
  11. DrBGood
    813
    789
    May 17, 2013
    Since I have you at the end of the line ...
    Everything connected, checked 3 times, bridge pickup doesn't work. Connected both black/bare to ground on 3 way selector, as it was with the normal P90s. Each red goes to each side of the selector and white/greens are taped together.
    I guess I should unweld the bridge pickup and test it by itself. It doesn't read from selector on the meter as connected. The neck does. Could be the selector itself ? Pretty simple mechanism on that, not much that can go wrong. The lever seem to be doing it's job OK. It worked fine before.
    Thanks again.
    EDIT : I unwelded the pickup and the only reading I get on it, is with green and white. Pickup is dead ?
  12. jonesy
    17,130
    4,364
    Mar 28, 2008
    With test leads on red + and black - (green white together) you should get full reading of pickup with both coils in series.
    If you put lead on green/white and then the other on the red + or black - you will get reading of each coil individually.
    If one side does not show any reading or shows abnormal reading you may have a bad coil on that pickup.
  13. DrBGood
    813
    789
    May 17, 2013
    No reading in any position. Should I untape the coils and look for a short with the white or green wires ? Or should I return it to the seller so he can claim it on warranty with Gibson, since it is a 2014.
    Thanks
  14. jonesy
    17,130
    4,364
    Mar 28, 2008
    Not sure what the problem is, but if it's still under warranty I would not take it apart. Contact seller and see what happens.
  15. lunchbox
    lunchbox Senior Member
    6,280
    7,804
    May 29, 2011
  16. DrBGood
    813
    789
    May 17, 2013
    Well ... go figure.
    I sent the pickup to the seller so he could forward it to Gibson, they were going to exchange it. But to before he sent it, he tested it and he found out the wires are inverted. Green and white are the live ones (with red & black together). I guess the only combination I didn't try.
    So it's coming back unharmed but goofy.
  17. sidious911
    sidious911 Senior Member
    838
    266
    Oct 3, 2011
    Useful video for being able to determine which wires are what when you have an unknown pickup.
    https://www.youtube.com/watch?v=7UfxQBhqen8
  18. jonesy
    17,130
    4,364
    Mar 28, 2008
    :hmm: very strange, doesn't sound right for a Gibson pickup.
  19. Shai`tan
    Shai`tan Senior Member
    1,402
    291
    Sep 13, 2008
    I have a 78 Black Beauty.... Can anyone tell me what the wiring scheme is? I thought it was Modern, but it looks odd. The problem I am noticing is the tones only work proper when the volumes are maxed. When I turn down the volumes, the tone knobs don`t seem to work. Thx.
  20. jonesy
    17,130
    4,364
    Mar 28, 2008
    I took a look at the pic and on the bridge volume pot there is no lead running to the outside lug that the cap lead is connected to. :hmm:
    Modern stock wiring would have the bridge pickup lead and cap lead both going to that outside lug.
    Couldn't see the outside lug of the neck volume pot because the black tube is blocking the view.
    Those 3 pickup guitars use a different toggle switch and the wiring scheme is unlike a typical LP guitar.
