Wiring Library
Discussion in 'Tonefreaks' started by ashbass, May 30, 2007.
  1. jonesy
    17,168
    4,389
    Mar 28, 2008
    Here is my version of the Jimmy Page Zoso Wiring, 21 Tone Combinations. This is the Longshaft version for Les Paul Customs...
    It Has 4 Push-Pull Pots...
  2. Frit
    Frit Junior Member
    4
    0
    Jun 19, 2008
    Thanks for the above schematic. Unfortunately, I have it and have tried it, and it's not working for this particular guitar. I'm still looking for a 3-pup schematic that shows everything, including the switch. I have all of the ones previously mentioned....
    sigh.
  3. jonesy
    17,168
    4,389
    Mar 28, 2008
    Not sure what brand pickups you have in that Bird, but check out this color code chart. I have built and shipped over 50 of these JP/Zoso rigs all around the world using this schematic and color code chart and they have all worked in a wide variety of guitars. Double check your wiring...
    LIBERTYMACHINE likes this.
  4. Peaceman
    Peaceman Senior Member
    469
    4
    Apr 29, 2008
    This thread is fantastic guys, thanks to all of you who have contributed.
    One question from me is this, Is there any difference in tone etc with or without the ground/earth plate that some LP's have?
  5. wolfy317
    wolfy317 Junior Member
    4
    0
    Sep 1, 2008
    Hey all, I'm new here, and I'm upgrading my stock pups in my Epi black beauty to passive EMG, but I wanted to ask if anyone knows whether the wire colors will match or not, last time I put EMG's in a guitar, the colors didn't match. Thanks for any input. I'm only putting neck and bridge pups in btw. Should I just disconnect the stock middle pup, and rewire accordingly?, or should get a third emg for the middle? THanks guys!
  6. richedie
    richedie Senior Member
    1,150
    60
    Jan 26, 2008
    Is the Black Rose site still up?????
    Does anyone know if that Modern wiring with independent volumes is correct? Ever since I went to independent volumes, my treble bleed circuit does not seem to do its job as well.
    Finally, any way possible for me to test a pot when it is in the cavity to see if it is 500k?
    THANKS!
  7. richedie
    1,150
    60
    Jan 26, 2008
    Anymore I am thinking it is best to stick with standard LP wiring rather than mess with the core tone. Too many people report weird overtones and atreble sheen when using a treble bleed cap and some people report odd tonal changes when using independent volumes. I may go back to totally stock wiring configuration.
  8. getkey
    getkey Junior Member
    1
    0
    Mar 15, 2008
    Hi guys!
    Sorry for my bad english!
    I hope you can help me. I'm installing an EMG Zakk Wylde set in my Epiphone Les Paul Standard, but I have a problem.
    Here's a picture I made with paint. It only shows the pots and the wire from the pickup selector.
    So, 3 wires coming from the pickup selector (yellow - neck pu, white - to input jack, red - bridge pu). But when they reach the pot cavity there is one more wire (a black one). I don't know, where it's coming from. And there is some kind of plug here (the brown thing on the picture). On the other side of the plug the wires have different colours. And the black wire is divided into two, and joins the white wire and one of the red wire (i have 3 wires again). Does anyone know where should i solder the wires (in the yellow circle)?
    Please help me, if You can!
    Thanks in advance!
  9. nathanmanansala
    nathanmanansala Junior Member
    11
    0
    Aug 29, 2008
    :thumb:
  10. WadeClay
    WadeClay Member
    75
    1
    Nov 17, 2008
    Can anyone tell me what style of wiring my 08' studio would have. I'm assuming the obvious answer is the modern wiring diagram.
  11. brotor
    brotor Junior Member
    2
    0
    Dec 15, 2008
    '08 black beauty wiring anyone?
  12. Gryphon
    Gryphon Senior Member
    158
    86
    Dec 26, 2008
    Just joined this forum to say thanks to all the contributors. Never knew that the 50s wiring was different from modern-day. My 91 LP Std has the Peter Green (magnet flip) mod already and I had some Orange Drop 0.015uF caps sitting around, and a new soldering workstation, so I set to work replacing the stock caps and changing the layout to 50s spec. I'm glad I did. The tone controls now give much more subtle changes, the treble is retained better when the vol is rolled off, and I'm a happy ex-lurker. The only thing I might change from this point on is the bridge pu cap value as the 0.015 I put in that position doesn't give much tone change at all; just enough to be worth having the control, but I can see why others use bigger caps in that position.
  13. charmcitysaints
    charmcitysaints Member
    33
    6
    Dec 28, 2008
    so what is the "real" 50's wiring? in looking to change my wiring i have been doing tons of searches and have found conflicting sketches, pics and info.. sometime in the same article..
    this claims to be the "real" 50's style wiring..
    but that has that cap tied to the center lug on the tone control.. and then this pic is saying it is the "real" 50's wiring but tells you to move the cap from the center lug to the one where the ground was, and move the ground to the center lug.. and on the volume pot shows switching the input and output wires around..
    then this one show not switching the input and out put wires around..
    and then there is this.. from this thread http://www.mylespaul.com/forums/epiphone-les-pauls/21354-re-wiring-epi-lp-standard.html
    but it looks like the "modern" wiring depicted here..
    god i am so confused... am i reading these incorrectly? can anyone shed some light on this?? which is the correct way?
    i found this on the gibson site..
  14. jonesy
    17,168
    4,389
    Mar 28, 2008
    I use the one marked 50's style wiring and take it to be correct. Center lug on tone soldered back to case and cap connected to center lug on volume pot.
  15. jonesy
    17,168
    4,389
    Mar 28, 2008
    How about this one?
  16. charmcitysaints
    33
    6
    Dec 28, 2008
    thanks jonesy.. :fingersx:
  17. jonesy
    17,168
    4,389
    Mar 28, 2008
    Your Welcome bro, if you need any help with wiring just let me know OK?
  18. VastHorizon
    VastHorizon Senior Member
    7,414
    1,651
    Sep 27, 2008
    Why did I just see one cap in my 3-pickup strat?
  19. jonesy
    17,168
    4,389
    Mar 28, 2008
    Stock Fender wiring just uses 1 cap for both of your tone controls actually. Some guys add another cap and have different value for each tone control.
    Also check to see if your lower tone control works bridge pu, chances are it doesn't unless you have delta-tone or a little jumper wire added on switch.
  20. VastHorizon
    7,414
    1,651
    Sep 27, 2008
    I think so too. My lower tone control knob does not control the bridge pup. Do you have a picture where I can copy the 2 cap and bottom tone control mod. Thanks Jonesy!
