Wiring a three way switch (Help guitar tech's)
Discussion in 'Tonefreaks' started by Fixxxer, Mar 16, 2008.
  1. Bowhunterwt
    Bowhunterwt V.I.P. Member
    525
    6
    Aug 9, 2007
    If you have EMG's active pickups (one that requires a battery) DO not ground to the post. If you have passive EMG's (the one that don't required battery) you have too ground
  2. Frit
    Frit Junior Member
    4
    0
    Jun 19, 2008
    This is a great thread, and I have all of the above schematics. However, I have a 3 pickup LP Custom that I was modifying to 3 volumes 1 tone. The customer decided they didn't want the guitar, so I went to restore it. I had meticulously drawn all of the connections....except to -- am I a bonehead -- the switch. It's a 3-way toggle, but it has an extra leaf that I haven't seen on a 3 way toggle. I've rewired the whole thing, but I can only get the neck pickup to make a sound. WTF am I doing wrong?? Can I rewire to a regular 3 way toggle? Is there some extra connection that I don't know about?
    Sorry for all the questions, but this is driving me batshit.....
    Thanks,
  3. Big John
    Big John it's all about the shirt V.I.P. Member
    7,244
    6,426
    Mar 18, 2007
    Frit, you say it has an extra leaf. In the schematic already posted for this mod (3 vols/1 tone), the extra leaf isn't being used. Also, since you're not getting any signal from the bridge and middle pups, that means those signals are getting shunted to ground through resistance. You might want to re-check the wiper connections on all the pots, and make sure everything is going to where it's suppossed to.
    Also, a pic is worth 1,000 words. If you can post a clear jpeg of what you have, that may help.
  4. Buffleheid
    Buffleheid Junior Member
    2
    0
    Jun 22, 2008
    holy crap thats the exact thing that happened to me...
    now im redoing the connections following this instead.
    GuitarElectronics.com WDU-HHH3T22-01
    should be interesting...
  5. Frit
    Frit Junior Member
    4
    0
    Jun 19, 2008
    Thanks for the replies-I'll try to post a pic of what's going on. And thanks for the schematic, I have that one, too, but the toggle is different on the guitar I am working on.
  6. gadgetfreak
    gadgetfreak Senior Member
    230
    79
    Nov 27, 2010
    Hello Gentleman,,
    I have just purchased a pre-wired switchcraft switch and Jack,etc... I understand and have directions on what to do except for 1 little point.
    On my switch I have a wire labeled white which is supposed to be soldered to the hot lug on the output Jack. Do I have to soldered the braided outer jacket to the other lug? Or does the lug only need one wire connected because I have another wire labeled black that is my ground that is going to a pot. Make sense??
    My current epi output jack has 2 wires connected, 1 on each lug but this new switchcraft only has 1 wire labeled for the jack so I just want to be sure.
    I'm laying it all out before I even break the soldering Iron Out, Doing it right this time.
    Thanks in advance for any help, Yes I have read all wiring pages but this is a unique question to my particular jack and switchcraft I guess. Thanks
  7. jonesy
    17,171
    4,389
    Mar 28, 2008
    Your output jack has a hot lug that goes to the tip + and another lug that connects to the inner sleeve that is ground-
    If you are using the vintage braided wire the outside shield is ground and the inner lead is hot. Solder braided to ground lug and inner lead to hot lug on output jack
  8. gadgetfreak
    230
    79
    Nov 27, 2010
    Thanks Jonesy,, I just read in my directions under vintage wiring that they provided a seperate wire coming off the switch with black tape marking it and it says to wire the tip and the outer braid to the pot they have marked, Then they said to just use wire marked with white and connect just tip to output jack,, seem's wierd to me not having something on that other lug, does that make sense?? I understand what you said, I'm just trying to explain what I just read in my directions. Thanks again, let me know if that doesn't make sense
  9. jonesy
    17,171
    4,389
    Mar 28, 2008
    Output jack has to have hot from switch and ground to back of pots. Not sure what type of switch wiring you have, you could always contact whoever you bought it from if you are note sure how to install it ;)
  10. gadgetfreak
    230
    79
    Nov 27, 2010
    I have the switch in and all the wire's fished, I am putting in the assembly now, have to soldered the pup's and couple other thing's and will see how she sound's.
    For the hell of it I am wiring in the original epiphone pup's to see how they sound with a real wiring harness, I'm using all bournes 500k pots, vitaim T caps etc.. If I don't like the pups after this it will be because I don't like the pickups and not because of cheap korean electronics.
    THis epi was made in Korea in late 90's, plus top great neck, worth me doing all of this. Thanks again
  11. hillbilly
    hillbilly V.I.P. Member
    1,399
    275
    Jan 31, 2008
    This little diddy might help... :naughty:
    [ame="http://www.youtube.com/watch?v=UPvpLuSaOOQ"]http://www.youtube.com/watch?v=UPvpLuSaOO[/ame]​
