Why no love for the Line 6?
Discussion in 'Amp Modeling' started by Big Mark, Jun 4, 2010.
Thread Status:
Not open for further replies.
  1. Big Mark
    Big Mark Senior Member
    275
    30
    Apr 14, 2010
    Hi all, Just been reading through a few threads on amps and keep hearing a lot of negative comments on the Line 6 amps. This confuses me a little as I have a Spider 4 75W with express board and could not be happier with what it gives me.
    I must state, I am not a gigging axeman so this is home use only which may be a reason for my satisfaction but would be interested in any comments [​IMG]
    kat likes this.
  2. Barber
    Barber Senior Member
    647
    42
    Feb 9, 2010
    This:
    is all that matters.
  3. Big Mark
    275
    30
    Apr 14, 2010
    Thanks Barber, I could not agree more. Just curious as to why people seem to be anti Line 6?
  4. lukemacauley
    lukemacauley Mac Guitars Premium Member
    1,307
    32
    Oct 3, 2009
    Play a decent tube amp and you'll see.
  5. ext1jdh
    ext1jdh Senior Member
    9,521
    6,195
    Apr 19, 2010
    I've played a Spider III and found it to be either muddy or harsh. The onboard modeling was both wanting and more difficult to use than a multiFX pedal. After spending three hours trying to dial in a clean sound to run my pedal through, I simply could not get a sound that was pleasing out of it. Instead of pounding my head against the Spider, I went to a Marshall MG15 simply because I could get a clean signal through it and use my pedal.
    Then I got a Handsome Devil and never used the MG again.
  6. Big Mark
    275
    30
    Apr 14, 2010
    Hi Luke, I have played through a few over the years and they are enjoyable but for home use?? you really cant drive the tubes at domestic levels IMO. then you have the cost difference...
  7. Big Mark
    275
    30
    Apr 14, 2010
    Very constructive. thanks for your input
  8. ext1jdh
    9,521
    6,195
    Apr 19, 2010
    Plenty of low wattage tubes out there. 1/4, 1, 2, 4, and 5 watts are plenty quiet for home use with good tube saturation. And the low-watters are significantly cheaper than the hi-watt versions.
  9. 180gROC
    180gROC Senior Member
    5,712
    6,093
    Dec 24, 2007
    The one my bandmate kept here, a spider 3, was harsh and on it's own and hated pedals. It sounded weak in the overall band mix, and was missing a HUGE chunk of frequency range on recordings.
    It was the kind of amp you could get a decent sound with by yourself, if you weren't too picky or attached to pedals, but it didn't play well in a band environment at all.
    He replaced it with a 50W Peavey Tube combo, and never looked back. Vast improvement.
  10. lukemacauley
    1,307
    32
    Oct 3, 2009
  11. lukemacauley
    1,307
    32
    Oct 3, 2009
    Ah, now that is where you're wrong.
    You can use a passive attenuator, which allows you to crank your tubes (usually a very loud sound) then turn down the passive attenuator, to get the same sound at domestic levels. Amazing.
    I'm not talking about diming an 100W amp though, maybe a 15W or 30W.
  12. Big Mark
    275
    30
    Apr 14, 2010
    thanks, will have a look at some of the sub 1W amp.
    Please dont get me wrong, tube is king, i am not disputing that, sounds like a lot of issues so far are base on the Spider 3, which I can understand.
  13. Big Mark
    275
    30
    Apr 14, 2010
    mmm, never heard of this, thanks so much for the info!
  14. Deftone
    Deftone Senior Member
    12,312
    9,584
    Feb 22, 2008
    If you like it, that's all that matters. You have to make you happy, 1st. Good for you for not being a lemming and following trends.
    I'm HUGE fan of low watt tube amps. I run a 20w, 14w, 5w & a 2w. For home use the 2 & 5 watters rule.
    I also have a Fender G-DEC modeling amp that I still enjoy playing for a variety of sounds. They all have their place.
  15. lukemacauley
    1,307
    32
    Oct 3, 2009
    It's really simple:
    - Ground the normal lug you would on a volume pot
    - Connect some braided wire to the other two lugs on the pot
    - Solder two jacks onto those two lugs, and they're your input and output.
    - And remember to ground your jacks!
  16. Throwing7
    Throwing7 Senior Member
    384
    45
    Jun 7, 2009
    For home practice I am sure they're great.
    But as for why they aren't loved by many people here; When you go hunting, do you bring a Rifle or a Water Pistol.:dude:
  17. ext1jdh
    9,521
    6,195
    Apr 19, 2010
    Pleez, we're not hunting anything here.
    except cougars :naughty:
  18. b-squared
    b-squared Banned
    21,123
    9,169
    Jan 21, 2008
    I use a Pod X3Live for my weekend work--I own great tube amps, but for that gig the Pod is perfect. Incredible tone that I'd stack up against anyone.
    BB
  19. ext1jdh
    9,521
    6,195
    Apr 19, 2010
    Oh yes, the Pod's are good. I like the big Pod floor pedal a buddy of mine has for his bass work is great. I just dont like the modeling amps.
    *edit* upon google search I think he's got the X3 or whatever their bass version is.
  20. csparks75
    csparks75 Senior Member
    304
    3
    Jun 22, 2009
    I think that's where the Line6 stuff is really good, when you have to cover many different styles and material. It's also nice to be able to get a similar sound to a <insert amp here> without having to go buy that amp.
Thread Status:
