Why Never Any POD HD Talk
Discussion in 'Amp Modeling' started by frankv, Oct 31, 2015.
  1. affordablehearing
    affordablehearing Senior Member
    623
    308
    Apr 24, 2014
    Awesome! Can't wait to hear your review. I think you will be happy.
    Also interested in hearing about the cabs
  2. Sp8ctre
    Sp8ctre Senior Member
    4,173
    6,021
    Jan 8, 2014
    Wow, I just listened to a demo of the Xitone powered wedge. They did not color the sound at all. They just reproduced exactly what was fed into them.
    I need to find some similar demos of the Line 6 and the Friedman...
    1 person likes this.
  3. frankv
    14,528
    12,930
    Aug 25, 2011
    Why bother? the XItone stuff is top shelf. I wouldn't steer you wrong brother. I did all the research for you..
  4. Sp8ctre
    4,173
    6,021
    Jan 8, 2014
    Noted and appreciated, only thing is I'm really curious how the Line 6 sounds since I have a Variax Guitar and a POD HD500X...then again do I really need a chain of 3 pieces that model???
  5. dspelman
    dspelman Senior Member
    9,802
    5,711
    Apr 30, 2009
    On the other hand, this research was pretty much limited to internet forums, no? I think once you have one of these in hand, you may be less enthused once you hear it against alternatives.
  6. dspelman
    9,802
    5,711
    Apr 30, 2009
    The Line 6 StudioSource doesn't model. It's just a good PA-style speaker.
  7. Sp8ctre
    4,173
    6,021
    Jan 8, 2014
    Correct. I guess I was referring to the ability to select a source such as Electric Guitar, Acoustic Guitar, Keyboard. More of an equalization thing.
  8. frankv
    14,528
    12,930
    Aug 25, 2011
    Hey DS, do you have direct experience with XITONE.. Are you telling me to cancel my order?
  9. dspelman
    9,802
    5,711
    Apr 30, 2009
    I looked at the Eminence speaker that's inside these things (with a couple of different HF drivers) in *other* boxes some time ago. It's not killer expensive ($75 or so for the 12" LF driver). Do you know what HF driver they're using?
    You probably shouldn't need to have separate "baked-in" equalizations for Electric/Acoustic/Keys. That's more than likely just a bulletpoint for marketing. I'm using my current speakers for all three of those ("acoustic" guitar coming from a Variax Acoustic 700 and the JTV-89s, Keyboards are Korg Kronos and PA3X) plus bass. If the speakers are truly flat response, EQ is coming from further upstream. If you're running guitar/acoustic/keys, you're probably not going to want to be reaching down to a wedge to tweak EQ anyway.
    The good news is that they're pretty compact boxes, and they ARE coated with LineX, so they should be tough.
    I'm not telling you to cancel your order (it may be perfect for what you're doing).
    Have you had a chance to try one of the Atomic Amp active-amp coax boxes designed by Jay Mitchell yet? They're not bad.
  10. frankv
    14,528
    12,930
    Aug 25, 2011
    Thanks DS, Much appreciated. I certainly value your opinion as I know you are a PRO performer.
    For me, anything is better then the crappy AVT412 cab I'm stuck using since selling everything. So I think the XITONE wedges are going to be just the thing for my office. Thanks for the insight, it's because of you and a couple of others that I decided to go FRFR cabs.
  11. KenG
    KenG Senior Member
    6,268
    3,335
    Sep 13, 2009
    There's more to a speaker cab than the speaker. The dimensions and porting affect the overall response as well. The main issues are frequency response, SPL sound pressure levels (projection) and of course dispersion (area covered). I don't think any amplified or passive speaker will be totally flat, many will color the sound differently to a minor degree. You'll be able to tweak global settings on things like resonance and presence for your system and if you don't change the system once set up there should be no issues.
    BTW expect to change any sounds you currently liek through the guitar cab once you use full range stuff. Guitar cabs typically have less than half the audio range of good quality speaker systems (Mostly top but also bottom end as well).
  12. LeftyF2003
    LeftyF2003 Senior Member
    7,352
    8,484
    Mar 2, 2010
    For recording my "modeller" is an ADA MP-1 through a Hughes and Ketner Red Box III into a TC Electronic G-major. I've tried several modelling amps but nothing cuts it for me live but a real tube amp. It just thumps...
  13. frankv
    14,528
    12,930
    Aug 25, 2011
    Yes, I have read that there are differences between the two. Some guys actually don't like the full range stuff. I hope I am not one of them
  14. frankv
    14,528
    12,930
    Aug 25, 2011
    I suppose to really benefit from an AXE live you would need DI to a high quality PA system.Speaker cabs just for stage volume.
  15. Inside Guy
    Inside Guy I am no longer @ Gibson V.I.P. Member
    1,616
    2,024
    Mar 26, 2007
    The Line 6 speaker ( and most other powered speakers these days) contains DSP to perform all kinds of cool things.
    The different setting options actually do much more than just provide selling points. Might want to dive deeper into the specs. One really cool feature is "Virtual tilt-back" on the guitar setting. If you have the speaker standing upright and it's on Keyboard or Guitar....the DSP will tilt the sound up to your ear. Pretty cool stuff going on.
    2 people like this.
  16. TheWilly17
    TheWilly17 Senior Member
    2,473
    2,039
    Apr 22, 2011
    Just picked up a POD 2.0 tonight, booya!
  17. frankv
    14,528
    12,930
    Aug 25, 2011
    I'm going to post this video in both this thread and the other one running about kinda the same thing.
    Maybe this video will show just what the AXE FX2 is really capable of. This is especially helpful to those interested in clean tones. You really need to listen to the entire video because it's all important to the points that were made in this thread.
    http://youtu.be/dt5bOCP1Wag
  18. LeftyF2003
    7,352
    8,484
    Mar 2, 2010
    Adrian Belew uses one into a pair of powered monitors and it sounds really good. Also keeps the stereo effects spread.
    2 people like this.
  19. homenote
    homenote ROCKSTAR INC (T.M) V.I.P. Member
    2,877
    1,243
    Jan 15, 2010
    :wow: Country???
    Oh, my lady is gonna LOVE you, brother! :laugh2::laugh2::laugh2:
  20. homenote
    2,877
    1,243
    Jan 15, 2010
    There is that word again! :laugh2:
