Who Likes the Coil Tap Option, and How Often do You Use it?
Discussion in 'Gibson Les Pauls' started by scozz, Sep 30, 2017.
  1. Stuff
    Stuff Senior Member
    464
    316
    Jul 28, 2013
    I have coil splits on my Les Paul Sig-T (new harness + Monty's Guitars' PAFs) and my PRS 594 (completely stock). It's a feature I use all the time on both of those.
    I mostly prefer playing in the middle position. I split the neck pup and dial the volume down to around 4 or 5. Keep the bridge pup in full humbucker, volume rolled back to between 8 and 9. Middle position is a nice rhythm tone, and I can just flip the pup selector down for lead tones, with the option of rolling up the bridge humbucker if needed. Works for me.
    I don't use the Sig-T for purely split tones. Not a fan of how that sounds.
    This weekend, I started exploring using the PRS 594 for purely split tones. Very early days with that. First impression was positive.
    notabot likes this.
  2. TheWelder
    TheWelder Senior Member
    1,412
    1,896
    Jan 12, 2011
    My Epi 339 had coil splits. It was my first experience with them. I found that the split sound just wasn't usable in any way. Kind of a 'wet blanket over the amp' sound, which obviously isn't desirable.
    It's currently at the shop getting wired up with a pair of Parson Street Golden Age humbuckers and a 50s style harness. No more screwing around with split coils, trying to figure out a way to make them usable. If I want a single coil sound, I'll grab my Strat.
  3. Pop1655
    Pop1655 Premium Member
    5,568
    9,255
    Aug 25, 2014
    Sounded like a much better idea in the ad than it did in real life for me.
    mdubya likes this.
  4. 1all's Pub
    1all's Pub Senior Member
    2,948
    2,553
    May 26, 2015
    I've had it on a few guitars (currently have it on two)... was never more than a novelty for me. It's never been a positive factor in influencing me to buy a guitar, just the opposite in fact (ie, I always wish they weren't there, just a hassle).
    If one (or more) of the split pots were to die in either of the two guitars I have it in, I'm sure I'd just use it as an excuse to yank them all and replace them with normal pots/wiring.
    Maybe some day in the future I will discover the joys of coil-splitting and recant this post as pure naïveté... but I doubt it. ;)
  5. Fudaa
    Fudaa Senior Member
    138
    96
    Nov 4, 2011
    I play a 2014 studio with the coil taps. I only use the coli tap option on a couple of songs in the middle positon with the bridge tapped... gives a descently aggressive tone.
  6. T22
    T22 Member
    97
    33
    May 24, 2011
    Never use it. Don't like the loss of punch. If I want single coil, I'll pick up one of my strats.
    Veeing Fly and Dick Banks like this.
  7. jc2000
    jc2000 Senior Member
    5,728
    2,478
    Jul 16, 2013
    I have a 2013 Pro II and I never use them. I even took the battery out to make the tone knob a mute switch.
    Veeing Fly and mdubya like this.
  8. Figo
    Figo Member
    88
    117
    Feb 15, 2014
    Humbuckers can't Coil Tap, that option is only valid for Single Coil Pickups.
    Coil Tap is when the Pickup is wounded lets say 12,000 times and a selector is soldered at that point (the Coil Tap) and then the same pickup is wounded another extra 5,000 times (Hot Wound).
    When you have the coil tap unselected the pickup only drives the output of the 12,000 (brighter/crisper sound) and when the Coil Tap is on the pickup drives the output of the 17,000 (warmer/thicker sound some kind like a Humbucker)
    You are meaning Coil Splitting.... A completely different animal!!!!
  9. Donal
    Donal ¯\_(ツ)_/¯ Premium Member
    13,120
    12,145
    Aug 25, 2009
    Ok, So how do you explain this?
    mdubya likes this.
  10. Figo
    Figo Member
    88
    117
    Feb 15, 2014
    Extracted from Gibson site: http://www.gibson.com/News-Lifestyl...lit-and-Tap-2017-Gibson-Les-Paul-Pickups.aspx
    "What Do You Hear? Tap vs Split Explained
    Tap = Accesses the pickup coils through a filter. Effectively accents a particular frequency range for a “tuned tap”.
    Result = Fatter, P-90 style voice with balanced output. Also offers lower noise and hum than true single-coil.
    Split = Isolates one coil in the humbucker pair. Effectively changes a humbucker into a single-coil pickup.
    Result = Brighter single-coil sound with lower output than humbucking."
    This means that the Taping feature is not real (physical) taping it is electronically simulated. The frecuencies are manipulated with a circuit to filter them and let sound either the crisp/bright or muddy/hot frecuencies (depending if the taping feature is on or off)
  11. Figo
    Figo Member
    88
    117
    Feb 15, 2014
    Explanation extracted from Seymour Duncan Web page: https://www.seymourduncan.com/blog/the-tone-garage/what-is-coil-tapping
    "Coil tapping is when a wire runs off of the pickup windings at a certain point, somewhere short of the full amount. This means you can install a switch to select between a single coil pickup’s full output or a lower output, giving you two distinct levels of power from one pickup"
  12. Zoobiedood
    Zoobiedood Senior Member
    788
    219
    Sep 1, 2015
    Yeah, many people say 'tap' when they mean 'split'. Both have their uses, but electronically, they are very very different.
  13. Zhangliqun
    Zhangliqun Senior Member
    1,586
    745
    Apr 10, 2007
    A tap and a split are variations on the same idea -- cutting out part of the pickup. If you think of a humbucker as one pickup (and of course it is), a split is just a tap that happens to be at the joint between this one pickup's two coils.
  14. Zhangliqun
    1,586
    745
    Apr 10, 2007
    Guess I had the last word...
    (EDIT FROM CAPT OBVIOUS: Clearly not as you see below...)
    mdubya likes this.
  15. IndyLP
    IndyLP Senior Member
    249
    164
    Aug 16, 2010
    My 10 month old is very entertained by pulling and pushing the knobs on my 2016 Studio T....that's the most use they get.
    When I decide what pickups I want to swap in, I'll replace the circuit board w/coil taps with 50's wiring and normal pots.
    The volume taper on my current pots suck, and when "full up" there is an unacceptable amount of wiggle in the knobs.
  16. jaycoyoyo
    jaycoyoyo Senior Member
    556
    449
    Jul 2, 2013
    I also have a Custom Lite, and I had two push/pull tone pots installed to do the splitting. I didn't have much reason to keep the split functionality, but I figured if I was adding the 2nd tone pot that I might as well change both to push/pull.
    To my ears the split is only really noticeable when I dial back on the volume. As others have said, I have other guitars that I'll pick up when I want a single coil sound. I suppose if I was playing live I would consider bringing one less guitar and using my LP for the single coil sound.
    --Jay
  17. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    764
    1,009
    Oct 29, 2017
    What a great thread! I've wondered about how this would work in reality. Sounds great on paper.
  18. SHERIFF
    SHERIFF Senior Member
    487
    550
    Mar 22, 2015
    Got rid of it in my guitar long time ago, cause I never used it.
  19. scozz
    scozz Senior Member
    2,150
    931
    Sep 3, 2007
    What I really meant when I started this thread is "coil split". My bad for using the wrong phraseology. :cool2:
  20. CCK
    CCK Senior Member
    389
    187
    Jan 5, 2013
    Never heard one I liked.
    C_Becker and mdubya like this.
