Which sounds better to you?
Discussion in 'Tonefreaks' started by 5F6-A, May 6, 2017.
Which one do you prefer?
  1. First half
    6 vote(s)
    40.0%
  2. Second half
    9 vote(s)
    60.0%
  1. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    Recorded two sloppy (sorry) clips changing the first preamp valve... all the settings stayed the same.
    Listen to the first half and the to the the second half. Which one do you prefer? Why?
    Thanks.
    https://soundcloud.com/5f6-a/chords
    bulletproof likes this.
  2. freefrog
    freefrog Senior Member
    1,242
    686
    May 21, 2011
    The first one has more gain and a "compact" mid range.
    The second one has less gain and more airy mids.
    I prefer sample 2. The first one is too boxy for me.
    I don't know what you have used but sound 1 reflects what I personally obtain from typical short plates ECC83's. Sound 2 reminds me the tone typically obtained from the long plates 12AX7 models that I've tried... But there's exceptions so maybe I'm totally wrong. :)
  3. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    Thanks for the reply....
    Don't forget to vote! I'll be revealing the answers soon.
  4. Guitar Rod
    Guitar Rod Senior Member
    1,478
    778
    May 29, 2016
    I'm not an expert on tubes, but just sound-wise I like the first half. A bit more chimey and clear. Nicer breakup. The second half seemed cloudy by comparison.
  5. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    Bear in mind that it was played with a Strat / neck pickup.
  6. ARandall
    ARandall Senior Member
    12,007
    7,466
    Apr 16, 2012
    I am hearing the first half seemed to have more chime on top, the second half seemed more 'restricted'.
    First half for mine.
  7. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    Amp is a JTM45 style head with Greenbacks in a closed back cab.
    For the first half I used a Mazda ECC83 silver plates and a Mullard ECC83 short plates in V2
    The second half uses two Mullard ECC83s
    bulletproof and Guitar Rod like this.
  8. freefrog
    1,242
    686
    May 21, 2011
    I did listen through another computer and it made me realize that the first soundcard had its EQ enabled...
    Yes, the first section has a more extended high range, finally. The other one cuts the treble sooner (as did an oddball Sovtek LPS that I've tried a while back in V1 of various amps). But it doesn't change my own feeling: even if it has more chime, the first part has a straighter midrange and more gain, making it thicker but also less refined to my ears. I still prefer the softer part 2 with more complex mids. YMMV. :)
    EDIT - I hadn't seen your answer. Which kind of Mullard's did you use in the second part? Short plates too? Do they look like one of those pictured in the answer 11 here?
    https://www.thegearpage.net/board/index.php?threads/mullard-ecc83-knowledge-needed.175919/
  9. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    [​IMG] All the Mullard ECC83s were the same type , short plates from the mid to late 70s.
    http://img.photobucket.com/albums/v671/5F6-A/mullard2_zps7f3680f4.jpg
    The Mazda sounds great too but brighter and less rich in the low end of the spectrum.
    Toying with the idea of having a Mullard in V1 for the complex mid range and the Mazda in V2 to add some chime.... what do you think?
  10. freefrog
    1,242
    686
    May 21, 2011
    So I was wrong to hear long plates in the part 2. LOL. It shows once again how generalizations are dangerous when it comes to guitar tones (and I should have remembered how inconsistent tubes can be). :applause:
    I suppose that a lower gain is what gives to these short plates the airy mids that I use to hear in long plates models...:hmm:
    Regarding tubes in V1 and V2: IME, they are interactive, and this interaction tends to change according to the circuit involved. The only way to know is to try them IMHO.
    Let us know which duet you prefer. :cheers2:
  11. bulletproof
    11,524
    27,409
    Jun 1, 2011
    I like'em both....the first one with its chimey,open type thing. And the second one for the clear type warmth....Its the 2nd one for me.
  12. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    I think I'm going to stick with having both Mullards on. I have to reduce the bass a tad and up the high and presence a notch on the amp (it was EQd to suit the Mazda-first valve arrangement). I have to agree with my pal Freefrog, the complex midrange of the old Mullards is very appealing in a Marshall-esque circuit.
    Anyway, find below another clip that might help confirm your vote:
    http://soundcloud.com/5f6-a/punteado
    Again, first half is Mazda+Mullard and then both Mullards.
  13. korus
    korus Senior Member
    1,068
    364
    Apr 10, 2007
    So, no recording of Mullard as V1 and Mazda as V2? Have you tried them in that configuration, and is it like part 1 or more like part 2?
    I voted part 2 even before I read it's a Strat neck. Freefrog is right about more complex mids. Actually treble on part 1 is too biting for a Strat neck pickup, masks mids and lows. It would be even more pronounced with more drive, like playing live.
    bulletproof and 5F6-A like this.
  14. Freddy G
    Freddy G V.I.P. Member
    11,323
    23,603
    Mar 18, 2007
    I like the hotness of the first half. But I love the warmth of the second half. I'll say second half is my fav. Easy to dial in more gain if needed....not easy to dial in more warmth.
  15. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    The amp was set at 3/10 (gain). Master volume maxed out.
  16. bulletproof
    11,524
    27,409
    Jun 1, 2011
    :thumb:
  17. rogue3
    rogue3 Senior Member
    1,454
    1,815
    Apr 22, 2017
    I prefer the first one for the clarity.More depth to the soundstage,more to play with with your fingers.Once you turn the amp up,there will be lots of bottom end punch,but with more definition than number 2.Number 2 will mush out.imho.
  18. SlyStrat
    SlyStrat Senior Member
    1,813
    907
    Jan 24, 2009
    First. More depth and more 3D sounding.
  19. 5F6-A
    5F6-A Senior Member
    9,473
    2,026
    Aug 16, 2007
    Seems like the Mazda is catching up.....
  20. Guitar Rod
    1,478
    778
    May 29, 2016
    Mazdas aren't usually good off the line. It's the rotary tubes. More top end power.
