Whens the RIGHT tubes replecement time
Discussion in 'The Squawk Box' started by picoman, Feb 8, 2015.
  1. Paragon
    Paragon Senior Member
    1,288
    41
    Apr 10, 2008
    Indeed. The chances of tubes aging the same is slim. Some places will burn them in to reduce the amount of drift.. of course you pay for it.
    In the end, as long as the tubes are properly biased, matched/unmatched doesn't matter. My guess is that you will get a greater difference in tone from different brands of tubes than matched/unmatched.
    3 people like this.
  2. EndGame00
    EndGame00 Senior Member
    872
    479
    Sep 1, 2013
    When I used to gig regularly, I only did a full retube on my Mesa just twice and I used to ran the amp hard.
  3. mdubya
    mdubya Senior Member
    17,357
    27,300
    Jan 25, 2010
    Keep a spare set. Only change them if one dies or sounds bad. Otherwise, let 'er rip.
    There is no need to change them unless there is a problem which needs to be addressed.
    1 person likes this.
  4. ScottMarlowe
    ScottMarlowe Senior Member
    3,294
    2,796
    May 2, 2014
    Matched means they have the same bias point and response curve, or very close. For audiophile stereos maybe it's nice. For guitar amps it's pure snake oil.
  5. RAG7890
    RAG7890 Premium Member
    14,887
    23,781
    Jul 11, 2010
    + 1, this is important. :thumb: :applause:
    Not all Amps are equal. Hit the Tubes with very high Plate Voltage & you get killer tones (loads of even order harmonics) but the Tubes do not hold up as long.
    IMHO the tone is more important that how long the Tube lasts.
    For example, the Bogner Shiva runs very high plate Voltages so very hot & therefore, a shorter life span is to be expected.
    :hmm:.........................so if anyone has a Tube in a Pedal, running off a 9 Volt Battery it will last about a millions years. :laugh2:
    :cheers:
  6. RAG7890
    14,887
    23,781
    Jul 11, 2010
    Just for laughs I had to put this one in as I am sure most of you have never seen the venerable 4CX 10000. :wow:
    We used to recondition these suckers at AWA in Sydney in the 1980's. I worked on these & used to check how well the carburising was performed on the tungsten filaments under immense Vacuum (to produce Tungsten Carbide).
    That was in the fun days when we made all sorts of great stuff. We were one of ~ 9 locations in the World that could pull this Vacuum, which is a must when Valves are sealed under Vacuum to ensure efficient thermionic performance.
    For those that are interested this Valve puts out 10,000 Watts. Enough to fill a Stadium. :laugh2:
    These were used by National Radio ABC for broadcasting all over Australia & for Military applications in HF Amps.
    If any of you saw the NOS Valve Store we had, your mind would have, well simply imploded. :wow: :wow: :wow:
    About the size of two Bowling Balls & heavy. The Body is Ceramic, with massive Cooling Fins.
    :cheers:
    5 people like this.
  7. rabidhamster
    rabidhamster Senior Member
    6,146
    6,006
    Jun 4, 2008
    When could be a better time than right now?
  8. picoman
    picoman Senior Member
    564
    69
    Feb 4, 2010
    And what if my fues is Dead and I dont know that...:slash:
    Thanx for opening my eyes on PREMIUM MATCHED PAIRS :thumb:
    Is there any difference in sound if your running 2 power tubes that are brand new with 2 power tubes that lets say have 30% life in them left....compare that to the full new set....I mean is it stupid if one of you tubes dies and other still have life in them...need to replace the whole set...
    Man couldnt they make like an "duracel check test" for bateries
    https://www.youtube.com/watch?v=k6Gz5Gom5NI
    :naughty:
  9. InsertUsernameHere
    InsertUsernameHere Senior Member
    978
    840
    Jan 8, 2011
    That's awesome as hell. Get Marshall on the line, I've got a great idea.
    :slash:
    2 people like this.
  10. bilbarstow
    bilbarstow Premium Member
    2,731
    3,817
    Apr 1, 2011
    RAG7890,
    You bring back memories for me with this picture. Back in the late 70's I worked at Varian - actually BUILDING these types of tubes and even BIGGER ones. We made them for MIL use as well as Klystrons for X-Ray use and really big (some were 6 foot long :wow:) high power transmission tubes for Radio and TV broadcasting use. My job was to braise them together in hydrogen vacuum Retort furnaces at up to 2100 degrees F. That was a great job, paid for my college education !
    That little cap at the top that covers the vacuum pull-down nipple ? I must have arc-welded on about 100000 of them.
    2 people like this.
  11. Marshall & Moonshine
    Marshall & Moonshine Senior Member
    21,531
    37,798
    Jul 21, 2010
    When do you replace one tube rather than both (in a pair)?
  12. THDNUT
    THDNUT Senior Member
    15,496
    21,935
    Feb 5, 2012
    I always imagined this is what a flux capacitor would look like. :laugh2:
  13. picoman
    564
    69
    Feb 4, 2010
    You mean If one of my tubes goes Dead I nead to replace two of them:shock:
    I curently have 4 x JJ EL84 power tubes.
    Why cant I replace just one that gone dead?
  14. THDNUT
    15,496
    21,935
    Feb 5, 2012
    you can
  15. picoman
    564
    69
    Feb 4, 2010
    I Know I can and I did.
    BUt why did Marshall & Moonashine said change a pair...
  16. THDNUT
    15,496
    21,935
    Feb 5, 2012
  17. Marshall & Moonshine
    21,531
    37,798
    Jul 21, 2010
    No, no, no....
    I asked.....;)
    And I'm just talking about pairs, as I've no use for quads.
    If only one tube is bad, should you replace the pair, and does it make a difference if it's fixed or cathode biased?
  18. northernguitarguy
    northernguitarguy SWeAT hOg
    29,151
    49,067
    Feb 22, 2009
    I'd like to know this as well. Do unmatched power tubes make a difference in an amp? The manufacturer always seems to say the pair needs to be matched in a cathode biased amp.
  19. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member
    6,528
    15,065
    Jul 19, 2012
    Far worse than that can happen with a blown power tube. Things like a cooked transformer and other scorched components.
    3 people like this.
  20. johan.b
    johan.b Senior Member
    183
    196
    Jan 2, 2015
    Can happen, sure. But as long as the user doesn't replace a blown, sensible shosen fuse with something less .. eh. .fusible, it rarely does.
    12years repairing amps for a living, three of them fulltime for Marshalls scandinavian distributor, with very few exeptions the only time i needed to replace an output transformer was when someone replaced the fuse with something beefier.
    I'm not disputing you, shit happens, but a good design blows the fuse, not the iron
    J
    2 people like this.
