What's the earliest Norlin three pickup Custom??
Discussion in 'Norlin Years' started by capnjim, Mar 7, 2018.
  1. capnjim
    capnjim Senior Member
    439
    418
    Nov 6, 2014
    So I have this 1974 LP Custom..pots date to 1974. It has three pickups. The weird thing is, the third pickup is an Epiphone. But, the ring, screws and cover match the others exactly. The guitar has everything else original down to the last screw, so it hasn't been messed with. (Slight headstock crack)
    Is it possible its a factory order? Or just a really really good job.
    Cheers
    aalpcustom.jpg whitelproute.jpg custompupswear.jpg lpcustomback.JPG lpcustomhead.JPG lpcustomtuners.JPG
    scozz, garybaldy and mudface like this.
  2. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,244
    6,023
    Nov 17, 2012
    i know they used some leftover epi stuff for some minibuckers etc. etc. but I have never heard one word about full size.
    I would think someone robbed it.....not a big deal, you can pick up a period T-top fairly easy and since you have all of the trim...baddaBAM!
    done......
    nice looking guitar, can we get some more pics?
    I would like to see the neck pocket straight on, if you can......
  3. DarrellV
    14,504
    27,724
    Nov 1, 2016
    ^^^ Yup, almost has to be a sub!
    Epi for all accounts didn't last long enough to develop their own hummers, and as HCT said, minis were all the rage then.
    How does the switching work to bring in the center pup? Neck and middle or Bridge and middle?
  4. capnjim
    439
    418
    Nov 6, 2014
    The middle PUP looks like it was never even hooked up, which is weird. All the pots and wiring are stock. I'm pretty sure it was not factory done, I am just curious if anyone else has seen three pickup customs from that era,
  5. chasenblues
    chasenblues Senior Member
    20,381
    29,636
    Apr 2, 2007
    Why do you think the perimeter's of the bridge/neck routes look to be raw/unfinished wood(rerouted??) but the center route looks painted?
  6. kakerlak
    kakerlak Senior Member
    1,513
    557
    Feb 5, 2014
    Man, this is interesting and that's a neat-looking Custom! I have to say that route looks factory perfect to me. I'd also love to see some top-down pics of the routes -- curious how much tenon is extending into the neck cavity and would like to see the middle one, too. Could be somebody stole the middle pickup and replaced it with a "junk" one as a place-holder, just for looks and left it out of the circuit. I'm no expert, but I feel like '76 is where you start to see lots of factory 3-p/u Customs.
  7. kakerlak
    1,513
    557
    Feb 5, 2014
    Spraying angle? If they were fanning the spray up/down, they might not have caught much of the edges on one side or the other.
  8. capnjim
    439
    418
    Nov 6, 2014
    I do see the route is painted, and looks different. I bought the guitar knowing it was done after. To me, the weird part is how the covers, rings and screws, even the tiny little chips in the finish the screws make, are all identical.
  9. HardCore Troubadour
    8,244
    6,023
    Nov 17, 2012
    Refinish?
    DarrellV likes this.
  10. capnjim
    439
    418
    Nov 6, 2014
    I'm pretty sure the finish is original. The neck might have been re-sprayed when the crack was fixed, but, judging by the cavities, its the original finish. I have looked at lots of pics of white '70's customs and they all look the same general color.
  11. Redfish
    Redfish Senior Member
    487
    213
    Jul 6, 2007
    How DOES the switching work on a normal 3 pickup custom? I've always wondered. Does it have a 5 way switch or is it just all pickups on in the middle position?
  12. kakerlak
    1,513
    557
    Feb 5, 2014
    IIRC, it's like neck-neck+middle-bridge. Been a while since I've had a 3-p/u Gibbo, though
  13. chasenblues
    20,381
    29,636
    Apr 2, 2007
  14. capnjim
    439
    418
    Nov 6, 2014
    I rarely use my tone, I was going to wire it up with three volumes, and one master tone. Middle position will be all three on.
  15. moreles
    moreles Senior Member
    2,651
    1,272
    Apr 16, 2011
    Would have to examine closely in person to (maybe) figure this out, since the possibilities range from careful unoriginal mod to original Gibson (special order or regular issue.) For some reason, many players claim that the middle PU is not really usable (I ttally disagree) and so the original easily could have been removed and replaced with a newer Epi. There are no old Epi full-sized humbuckers. The ones Gibson recycled (in Deluxes) after buying Epi are the mini-hums that were the old Epi standard. Very interesting post! A good builder could fix, fake, mod, etc. pretty successfully, in ways hard to show in pics. I would get a period-correct PU in place of the Epi.
  16. moreles
    2,651
    1,272
    Apr 16, 2011
    Sorry to double-post. I have an '87 reissue '61 LP SG Custom, and the 3 PUs are located with the rings touching ea. other. Can't vouch for the singlecuts, but I know some of the ones I've encountered are similar to my SG with no space between the pickup rings. Surely someone must know if the (non-SG) Customs have as much space b/w PUs as yours does.
  17. scozz
    scozz Senior Member
    3,186
    3,550
    Sep 3, 2007
    This is a very interesting Custom @capnjim. It’s also a beautiful Custom! Sorry I don’t have any answers for you, but I love your LP!
    I’m pretty sure that there is less space from the end of the fretboard to the bridge on a SG than a LP.
  18. ARandall
    ARandall Senior Member
    11,717
    7,048
    Apr 16, 2012
    ^ This is impossible. They are exactly the same scale length so that space cannot be anything but the same.
    The typical SG does however have a moved neck pickup.....due to the body shape and the bevels making the typical 'under 24th fret node' positioning impossible. This means the pickup spacing is of course tighter
  19. scozz
    scozz Senior Member
    3,186
    3,550
    Sep 3, 2007
    I stand corrected...thanks @ARandall.
    You’re right the difference is the neck pickup is back off the end of the neck more.
    kakerlak likes this.
  20. kakerlak
    1,513
    557
    Feb 5, 2014
    Yep. 3p/u LPs have the neck and bridge pickups in their normal spots with the middle one centered b/w them. Ends up being a little gap b/w each pickup.
