Ya know, I never really got into modding my amps after I built them. Maybe a value tweek here or there. The only one that I might play around with is the JCM800 2204. The tubes from Eurotubes are still in the shipping box. To be honest, I am not a hard core amp theorist. I just love to build'em, and the amp building community is great.
Sorry Bill...I blame nubencience and failing 50 year old memory Anyways, this is a great place to hang and share. I'm still a noob though.
Yeah, there are a lot of ways to do it. I do laminate sides. So I use a bending iron and a form. I pre-bend the side (1.65mm thick) and a laminate (1.15mm thick) to get it close to the shape, but it doesn't have to be perfect. Gluing the two pieces together and pulling it into the form make the side perfect. I've also just done a one piece side that's about 1.9mm thick and just bent it on the iron. But you've got to be perfect with the bends... So bending the zebrawood at 1.65mm thick wasn't too bad. It bent easier than expected.
Sorry to you too Opus for interupting the info on that beautiful classical. Words for such a build are hard to find. It's one of those pieces that scream "play me damn it!".
Thanks for the info opus. Did u make the mold yourself? What are the advantages of laminating the wood vs not? If you didn't laminate it would it be best to use a bending machine like this one: Side Bending Machines - Information and Pricing at LMI ??
I may attempt a few side profiles yet. The neck joint will be based on the attached photo. I'll do a PDF but probably limit it to a C-size (17-22") so not much else will fit besides the body.
Since my workbench is the computer I thought I'd share some renderings of a pretty cool guitar I've been working on for a couple of days for a old friend of mine. A '63 Everly Brothers inspired guitar, all chambered and sporting a sound hole. One P90 soapbar and a wraparound. 3 degree neck angle. It's obviously smaller then the original, about 20 millimeters wider than a Les Paul. Leif Jacobson @ Jacobson GuitarWorks are going to CNC cut the maple top and mahogany bottom/neck.
This is an awesome thread. I'm new to the forum here so I thought I would post a couple of my projects. This 5 string bass has been on my workbench for awhile. I still have a ton of work left to do on it. Once that's done I will start work on this 7 string guitar that I am designing.
I'll take a crack at the wood. Padauk, purple heart, wenge, cocobolo, maple and the white pinstripes between the wenge and purple heart are probably also maple. The wenge might be kingwood.
