What Makes a High Gain Amp Sound Clear?
Discussion in 'The Squawk Box' started by Caoimhin, Sep 21, 2017.
  1. Caoimhin
    Caoimhin Senior Member
    8,389
    8,483
    Oct 12, 2009
    I have a few tube amps and one sticks out because with the gain maxed there's still a lot of clarity. All of the amps have EL34s and 12AX7s and I played them all through the same cab. What actually makes an amp sound "clearer"?
  2. Cjsinla
    Cjsinla Senior Member
    3,273
    2,405
    Jul 7, 2014
    What brands are we talking about? I know that my 100 watt Marshall has more clear headroom than either of my 50 watters. I've also seen that output transformers can be different. Some tube amp kits give you a choice of an OT with a saturated sound or one with more clarity and punch.
  3. NewDayHappy
    NewDayHappy Senior Member
    1,453
    2,255
    Dec 18, 2016
    This may sound odd but on my DSL I crank the gain to 2 o'clock and then adjust the volume to the desired level and I noticed way more clarity in the sound. Try it. I don't know why it works that way, I picked it up from another musician. Most of the time my volume isn't even turned up a quarter of the way and it sounds awesome.
  4. LPV
    LPV Senior Member
    8,760
    4,563
    Sep 23, 2008
    Dumping bass early in the preamp helps allot. Like allot.
  5. mmd
    mmd Senior Member
    2,432
    2,357
    Sep 24, 2012
    EQ placement in regards to gain staging can make a difference too.
  6. Caoimhin
    8,389
    8,483
    Oct 12, 2009
    Friedman BE
    JCM 800
    OR50
    Rockerverb
    Thunderverb
    Ironheart
    Dark Terror
    cherrysunburst00 likes this.
  7. northernguitarguy
    northernguitarguy SWeAT hOg
    27,480
    44,733
    Feb 22, 2009
    I wonder this myself. Both my VOX and Orange are 15W amps, but for some reason, the VOX has much more clean headroom (and a far sweeter clean tone, the Tiny Terror is not pleasing when clean-at all).
  8. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member MLP Vendor
    6,473
    14,877
    Jul 19, 2012
    I'm confused by the question. Are you asking why one amp may have more clean headroom than another amp? Or are you asking what's involved with designing a circuit that retains articulation, note separation, and harmonics when pushed into high-gain/distortion? Many high-gain amps become a hissy mess when cranked up.
  9. Caoimhin
    8,389
    8,483
    Oct 12, 2009
    This.
  10. Soul Tramp
    6,473
    14,877
    Jul 19, 2012
    High-gain is produced by cascading gain stages in the preamp. There are a lot of factors involved. The better the circuit designer addresses each one, the better the results.
    A couple have already been offered up.
    • LPV's comment about dumping bass is important
    • MMD's comment about tone stack placement
    A few other Factors to consider:
    • Waveform coming off each gain stage plate
    • Bias setting for each gain stage
    • Grid impedance for each gain stage
    • Oscillation filters
    • Signal path clarity
    • Tone stack design
    • Heater noise
    • Stability of power supply
    • Quality of transformers
  11. kiko
    kiko Senior Member
    1,087
    1,229
    Jul 16, 2015
    As a rule, as you go up the volume, you go down on bass, up on treble and mid range. Adjust to taste of course!
    Jymbopalyse and Kris Ford like this.
  12. Classicplayer
    Classicplayer Senior Member
    2,264
    1,230
    Sep 6, 2007
    I'm curious. Where about do you typically run your gain? I find it interesting that my 20-watt Orange Micro
    Dark (hybrid) and my new 15 watt Dark Terror (tube) seem to have the best "clear" sound when their volume and gain knobs are at about the same level. That being I set them at say 10 or 11 o'clock. I'm not talking about ear-tiring loud either.
    Classicplayer
  13. Classicplayer
    2,264
    1,230
    Sep 6, 2007
    Don, you listed 9 factors in amp design considerations. Do designers of mass-produced amps pay attention to all, or even a few of those factors?
    Classicplayer
    Rhust likes this.
  14. LPV
    LPV Senior Member
    8,760
    4,563
    Sep 23, 2008
    Yes anode follower too.
  15. northernguitarguy
    27,480
    44,733
    Feb 22, 2009
    I run my Orange purely as a gain amp. I use both amps with a Radial Headbone VT so I can use one cab while switching between the two.
    My TT is always set to volume between 10-12 o'clock, depending on the venue and the gain is always set to high noon. When I want more dirt, I kick in either my Bad Monkey or Soul Food pedals, depending on the song. When I want a heavier gain, I use my clean VOX with a Cornish G2 clone I scored off of member Batman.
  16. Soul Tramp
    6,473
    14,877
    Jul 19, 2012
    I don't know the answer to this. It would require a close look at the schematics and knowing what components were used to build the amps.
    I've gone to extremes trying to tame high-gain. Almost all amps use AC power for the tube heaters. A few will use elevated heaters, and even fewer will use DC power for the heaters. I've designed a "regulated" DC power supply for the tube heaters on V1 & V2 in an effort to lower the noise floor (VERY important in high-gain amps). I don't know of anyone else doing this.
  17. sonar
    sonar Senior Member
    2,866
    1,951
    Sep 10, 2008
    Playing with less gain.
    Stating the obvious, but unless you've got a really good FOH situation that can compress the sh*t out of your hi-gain amp in the mix, there really is very little other choices when playing at loud volume.
  18. Classicplayer
    2,264
    1,230
    Sep 6, 2007
    I can attest to playing with less gain to get a "clear" sound. And, do we mean clean/clear sound?
    I just bought and started using an Orange Dark Terror; noted for its high gain capabilities (for what its worth) at 15 tube watts. It sounds wonderful IMO, at lower gain
    and slightly scoped on the shape control. I use its gain side sparingly to keep my sound clear with lots of chime and sparkle, but still with some hair as a halo around that tone. I'm hinting tones reminiscent of tones of Page, Knopfler, and Kossoff.
    Classicplayer
  19. cherrysunburst00
    cherrysunburst00 Senior Member
    13,739
    23,917
    Mar 15, 2015
    DUDE!! That's some awesome fitepower ya gots
  20. Caoimhin
    8,389
    8,483
    Oct 12, 2009
    I was pretty familiar with all of them before I bought them but the one that surprised me the most was the Dark Terror. I run it through Orange PPC412 full stack and it sounds huge for being a little 15 watt amp. If you closed your eyes wouldn't know if I was using that or one of my 100 watt amps.
