What is this ?
Discussion in 'Gibson Les Pauls' started by Greeley, Nov 8, 2018.
  1. Greeley
    Greeley Member
    51
    89
    Nov 26, 2017
    My 2018 traditional Les Paul has developed this milky hue on the bridge and tail piece ? I can wipe it off and wipe it off but it always returns ? Last 3 times I haven't even touched it, ive wiped it off each time and it is quite hard to remove, it has just been sat in the case each time, i have also left it out of the case to but it still re-appears ? lts hardly been played and only comes out occasionally, has anyone any ideas what could be causing it it's driving me mad, no other guitar does it, my other Les Pauls are fine and shiny. IMG_20181108_195127.jpg IMG_20181108_195118.jpg IMG_20181108_195153.jpg
    cherrysunburst00 likes this.
  2. kakerlak
    kakerlak Senior Member
    1,878
    932
    Feb 5, 2014
    Nickel hardware just tends to dull like that. Perhaps your other guitars have chrome hardware?
    cherrysunburst00 and mudface like this.
  3. Greeley
    Greeley Member
    51
    89
    Nov 26, 2017
    AHH that may be a good point? My other Gibson Les Paul doesn't do it though, my epiphone doesn't do it, high end tokai doesn't, nor does my prs ? Would these be chrome plated ? I also upgraded the bridge on this to a Faber abrh 59 which I believe is nickel plated to, it's just weird how my other traditional Les Paul doesn't do it ? Which also has Faber fitted, if it's normal I can live with it, cheers for the reply.
  4. PierM
    PierM Premium Member
    4,072
    7,183
    Aug 19, 2016
    Also depends on the plating quality and roughness.
  5. edselman
    edselman Senior Member
    1,241
    679
    Mar 19, 2010
    Gibson has been using nickel hardware on the Traditional since 2017.
  6. Greeley
    Greeley Member
    51
    89
    Nov 26, 2017
    That would explain it then thankyou, my other traditional is a 2016.
  7. scozz
    scozz Senior Member
    3,962
    4,826
    Sep 3, 2007
    Yup, it’s a nickel hardware thing.
    cherrysunburst00, Greeley and mudface like this.
  8. Dick Banks
    Dick Banks Senior Member
    723
    929
    Apr 27, 2017
    Nickel (II) Oxide
    You can polish it out, but on collectible Gibsons, it's a mark of the vintage.
  9. mudface
    mudface Non-Deadbeat/Non-Prominent Double Platinum Supporter Premium Member
    6,376
    20,578
    Aug 29, 2016
    Nickel was the plating type before chrome became popular and cheap enough to use,... So it's a "traditional" old school look that does indeed tarnish.
    I happen to like both,... but not mixed on the same guitar, either Chrome or Nickel.
    Chromium is a resource that is abundant in Africa, Turkey, and India,... not so much in the USA. That’s why nickel was used in the early years,.... USA sourced making it cheaper to plate with.
    scozz, cherrysunburst00 and Greeley like this.
  10. Tone deaf
    Tone deaf Senior Member
    22,536
    35,207
    Apr 12, 2011
    I'd try wiping on a thin coat of wd-40 (or similar product).
  11. redcoats1976
    redcoats1976 Senior Member
    9,456
    6,075
    Feb 2, 2009
    let that finish yellow a bit more,dont wipe the tailpiece...that looks the buisness.
  12. Cjsinla
    Cjsinla Senior Member
    3,707
    3,042
    Jul 7, 2014
    To me, the look of tarnished nickel beats regular chrome.
    scozz and cherrysunburst00 like this.
  13. judson
    judson Senior Member
    3,379
    3,828
    Jan 26, 2016
    its mojo
    embrace it
  14. Pappy58
    Pappy58 Senior Member
    2,355
    4,723
    Dec 2, 2014
    Actually it might be indicative high moisture content in the air. Nickel seems to attract moisture quicker than other platings. And it will start to oxidize if left there. Any idea what your humidity level is? A little lemon or mineral oil would provide a good barrier.
  15. zombiwoof
    zombiwoof Senior Member
    393
    297
    Feb 24, 2008
    It's probably where you rest the palm of your hand. If it bugs you get a tube of metal polish, I got some from a motorcycle supply for about $8, it will shine that right up.
    Al
    Edit: actually probably where your forearm hits the TP, not your palm. Whatever, it can most likely be polished away with the metal polish if you want.
  16. JeffH66
    JeffH66 Pelham Blue Addict Premium Member
    963
    1,531
    Oct 31, 2010
    Everyone else nailed it. Nickel hardware, and nickel will almost always do this. You'll pay more for aged nickel hardware, like Faber and Callaham. I like it aged, but not all do.
    You can replace the bridge and tailpiece with chrome if you like. Up to you.
  17. Greeley
    Greeley Member
    51
    89
    Nov 26, 2017
    Thanks for the help and responses everyone, glad to know it's a normal ocurance then, I do like worn or aged looking guitars but because the pick up covers are shiny and still look like new it looks a little odd to me, with uneven wear ? I can live with it no worries now I know it's normal, I might just have to invest in some new distressed pickups like SD antiquities, again thank you everyone.
  18. scozz
    scozz Senior Member
    3,962
    4,826
    Sep 3, 2007
    I changed out the stock gold hardware on my 2006 Studio to nickel about two years ago. You can see the tarnish that has started in this pic.....
    I think it’s aging very nicely!
    Greeley likes this.
  19. jstarr823
    jstarr823 Senior Member
    3,545
    5,057
    Aug 15, 2011
    Get some metal polish. Bam! Looks like new again with a tiny bit of elbow grease. Or leave as-is. Bam! Instant mojo.
    Tobaccoburst83 and scozz like this.
  20. zombiwoof
    393
    297
    Feb 24, 2008
    Metal polish gets the crud off, but still leaves some "old nickel mojo" to the metal.
    Al
    Tobaccoburst83 likes this.
