What is the Rhythm and Tremble switch for?
Discussion in 'Epiphone Les Pauls' started by niguy1, Nov 2, 2009.
  1. snaredrum
    snaredrum V.I.P. Member
    23,056
    13,769
    Feb 14, 2009
    :laugh2::laugh2:
    i must have one. in cream though. anyone know where i could get one made?
  2. standard man
    standard man Senior Member
    4,326
    220
    Apr 4, 2009
    Mabe post count?
  3. River
    River Senior Member
    57,250
    91,254
    May 19, 2008
    Do you have a guitar with one of these switches on it?
  4. Sirzach
    Sirzach Senior Member
    2,846
    1,367
    Jul 21, 2009
    ah sorry, i forgot that thats the way I use it, and not everyone uses it that way. Boy,did i make an A## of myself :laugh2:
  5. snaredrum
    23,056
    13,769
    Feb 14, 2009
  6. kmk108
    kmk108 Senior Member
    12,903
    8,333
    Oct 18, 2009
    All of the above. To the OP, The rhythm direction turns on the neck pickup, and the treble turns on the bridge pickup. In between selects both.:naughty:
  7. River
    River Senior Member
    57,250
    91,254
    May 19, 2008
    But he says he can't hear the difference.
  8. dennistruckdriver
    dennistruckdriver V.I.P. Member
    26,085
    2,759
    Apr 3, 2008
    Maybe he should plug it into the amp and turn it on.
  9. Atomic
    Atomic Senior Member
    1,848
    71
    Aug 13, 2009
    you made an A##? wouldnt that be a B?
  10. Gsanso97
    Gsanso97 Senior Member
    108
    0
    Jun 11, 2009
    :lol:
  11. rockstar232007
    rockstar232007 Senior Member
    15,487
    11,487
    Jun 28, 2008
    Maybe they're senile?
  12. 4Boogie
    4Boogie Senior Member
    156
    1
    Sep 11, 2009
    I have mine hooked up to one of these
  13. lukemacauley
    lukemacauley Mac Guitars Premium Member
    1,307
    32
    Oct 3, 2009
    If you can't hear a difference then surely it doesn't matter. None the less, I'd go with some of Mr Truck Driver's advice, turn the amp on (and play something), no matter how crap your guitar is, you should definitely here something. If not, then maybe it's f**cked.
  14. mlepage
    mlepage Junior Member
    26
    0
    Oct 7, 2009
    Yes, that is what I intended to say: that if the pickups were identical, they'd still sound different due to position; but of course they are not identical, to balance out the sound more.
    If the comments about duplicate answers were aimed at me, they're mis-aimed. I read the entire thread, I don't care about post count, and I'm just trying to be helpful. The question may have been answered, but putting it another way may help the OP, or anyone else who reads this later. Surely that's OK?
  15. River
    River Senior Member
    57,250
    91,254
    May 19, 2008
    It's fine by me.
    And the string tension is not higher at the bridge. The string tension is the string tension, period. The physics involved when a string is plucked are just a wee bit more complex than that.
    For a Rhythm/Treble switch to have no effect on output whatsoever would require that the switch be broken such that it did nothing to change the pickup configuration, or an accident of pickup characteristics that would be one in a billion. That's why I asked "do you have a guitar with that switch?".
  16. rockstar232007
    15,487
    11,487
    Jun 28, 2008
    Your right. I was talking about string length. This is what happens when I try to multi-task! but anyway.:eek:
  17. Quill
    Quill Senior Member
    4,548
    3,036
    Sep 15, 2009
    The op hasn't posted again ... niguy1? are you still out there?
    If the switch doesn't seem to do anything, there could easily be something wrong. I once saw a pickup switch on a friend's cheap LP copy that had the contacts stuck together on one side and a broken lead on the other, so no matter how you fiddled with it, you only got signal from one pickup.
    You could try tapping on each of the pickups with the switch in different positions to see what might be creating a signal and what might not, and it's also well worth having a look inside the switch cavity and see if anything looks corroded or broken.
  18. River
    River Senior Member
    57,250
    91,254
    May 19, 2008
    Understand. What I think you meant (and I'm digging myself here, not dictating based on some great knowledge) is that the resistance to deflection is higher the further one picks/strums from the 12th fret - in either direction. That changes the harmonics, and the fuller, deeper, and louder sounds come from picking at the 12th. Move away from it and you lose volume and low harmonics. That's why bridge pickups are usually wound for higher output, and sometimes even greater bass response. I think. :hmm:
  19. rockstar232007
    15,487
    11,487
    Jun 28, 2008
    Yep! That's it!:applause:
    I was half asleep when I posted, so...
    At least somebody around here can decipher my half-assed attemps to post usefull information!:thumb:
