What is the radius tuning peg in LP 1975
Discussion in 'Norlin Years' started by paco1976, Jan 1, 2018.
  1. paco1976
    paco1976 Senior Member
    2,248
    1,597
    Oct 24, 2013
    Hi, I have a 1975 les Paul custom, with original waffleback tuners. Does someone have an idea what radius I should look for in a replacement tuner?
  2. chasenblues
    chasenblues Senior Member
    18,974
    25,220
    Apr 2, 2007
    Do you mean the turning ratio?
    I think they are 15:1
    paco1976 likes this.
  3. The Ballzz
    The Ballzz Senior Member
    1,260
    828
    Mar 28, 2013
    Take a string off and count the number of turns of the knob it takes to achieve one full turn of the post. :doh:
    You're Welcome! :cheers2:
    Gene
  4. ARandall
    ARandall Senior Member
    11,211
    6,346
    Apr 16, 2012
    Replace with whatever you want. Just because it was put on in the factory doesn't mean the makers somehow had some perfect knowledge of precisely the right part to put on.
  5. paco1976
    2,248
    1,597
    Oct 24, 2013
    So that number means that? Always thought it was the drilled hole diameter, radius or something...
    In that case I do not care much about the number of turns, provided it is something reasonable.
    Thanks!
  6. PierM
    PierM Premium Member
    1,939
    2,048
    Aug 19, 2016
    Hmmm, could be there is a bit of confusion about terms used. :)
    To me sounds you were asking about the diameter of the bushing, which is 11/32" (.346"/8.79mm).
  7. HardCore Troubadour
    HardCore Troubadour Senior Member
    7,891
    5,543
    Nov 17, 2012
    I think that also, and radius/diameter was the correct term......brother wants to know the hole size so he can order replacements without having to drill his head-stock.
  8. The Ballzz
    1,260
    828
    Mar 28, 2013
    Yeah, sorry folks. I was responding to chasenblues' assumption that "paco1976" was referring to the ratio. :doh: Radius is indeed a valid aspect of the diameter of the required holes in the headstock. At least now, the OP understands both aspects! :cheers:
    Gene
    HardCore Troubadour likes this.
