Vintage special project inbound!
Discussion in 'Vintage Les Pauls' started by deadlyweasel, Feb 11, 2017.
  1. deadlyweasel
    deadlyweasel Silver Supporter
    1,439
    1,101
    Mar 25, 2011
    Don't drink and luthier.... Well since it feels strong I'm not going to mess with it. In thinking of drilling down about 1/4" on each of the plugs and making some plugs out mohagany but not of end grain... And try and match the grain so they don't stand out too much when I fill and paint it. Any thoughts?
  2. capnjim
    capnjim Senior Member
    441
    420
    Nov 6, 2014
    I think you should leave it as is....a testament to someone who is obviously not a skilled luthier, but who still took the time to get it playing again.
    Just put a light stain and light finish over it.
  3. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Bushings pulled... My mojoaxe studs did not thread in to the ones it came with... Any idea of either of these are original?
  4. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    .... And it keeps getting more fun. The neck was reset at 2° so im not 100% sure if I will get my action down low enough with the wraparound bridge....
  5. TheZ
    TheZ Senior Member
    996
    609
    Nov 9, 2009
    That's a bummer. I saw this goldtop in another thread somewhat recently, not quite the same situation but it has been done. And I kinda dig it.
  6. Greco
    Greco Senior Member
    5,545
    8,214
    Aug 30, 2007
    You should be fine with 2 degrees. I think optimum is about 2 to 2.5 for juniors and Specials plus the pickups sit very low in these if you dont shim them. You should string it up with tuners, nut, bridge and a p90 before you go much further to test if it'll work for you.
    Mine is 2.5 with the brigde pickup shimmed with popsicle sticks and it has plenty of room. I could've gone with 2 degrees and still been fine.
  7. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Well, i started cleaning up the pup routed today and now all I can smell is acetone.... Anyway I found studs that fit the existing bushings and a nut to check the action and intonation. Intimates as well as can be expected from a wraparound bridge. The tuner holes are going to be troublesome... It seems that when they plugged what i am guessing was Grover tuner holes they did not drill them centered so my Jr style 3 on a plate tuners will not line up properly. Time to decide whether to drill it out again and re plug them then drill for them or drill them out and use grovers again....
  8. Xrun Morzov
    Xrun Morzov Senior Member
    501
    183
    Sep 16, 2015
    Have you decided to restore it to original condition or make it a players guitar?
  9. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    It would be way more than I am willing to invest to make this a full original restoration. I talked to BCR Greg about it, his opinion was it would never be TV or translucent finish will how much would have to be cut out and graphed in. I'm gonna go for a player. Possibly do aged pelham blue. I have original caps and a bridge pickup, everything else will be repop parts.
  10. ajory72
    ajory72 Senior Member
    1,124
    462
    Jun 16, 2010
    You never know - it could have once been in the hand of Johnny Thunders.... now theres a guy who could play! - Johnny might have been a hopeless junkie but man he was an entertainer!
    heres one of his:
  11. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    That is honestly one of my favorite looking guitars.
  12. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Incoming!
    [​IMG] Thanks Dan!
    stilwel likes this.
  13. capnjim
    441
    420
    Nov 6, 2014
    I hope you at least put it together as-is and try it out. I bet it will look bad ass.
    You don't want it shiny and new looking, and a fake relic job will look like a fake relic job.
  14. yamariv
    yamariv Senior Member
    1,341
    659
    Jul 26, 2015
    Any more updates OP? I'm impatient and can't wait to see this badboy as she gets restored!! :naughty:
  15. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Not much new, lots of acetone and cleaning out thick terrible finish. My parts should arrive tomorrow or Friday so by the weekend I will have it playing. Tomorrow I will be making a nut and leveling crowning and polishing the frets. Still torn on what finish to do. Part of me is thinking TV it with a stinger on the headstock and the heel. Uncle Greg suggested staying away from TV and doing it pelham blue... Choices choices. After I get it all setup I'll decide on wether to do new binding and inlays. Here are sone shots of it more cleaned up
    The tuner holes on this are bbbbrrrruuutal! Trying to decide if I should just clean them up and use grovers or plug them and go back to the 3 on a plate.
  16. The_Nuge
    The_Nuge Senior Member
    1,768
    1,183
    Dec 12, 2010
    I'd probably go for a solid colour - and Pelham is nice :thumb:
    BTW, did you manage to get some of your money back?
  17. none2low
    none2low Senior Member
    132
    97
    Nov 13, 2012
    Ouch!! I feel your pain. Going through this myself with a 59/60 LP Special. Mine suffered some similarly nasty home luthier work to the pickup routes and also the typical neck break/reset. I was able to rebuild the neck route, but ultimately settled on plugging and re-routing the bridge for a humbucker.
    Still undecided if I want to return mine to it's original TV yellow finish for similar reasons. Mine was refinished in black and I'm still trying to get all the finish out of the grain.
    Best of luck!! In the end it'll be a great players grade instrument doing what it was originally meant to do.
  18. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Custom guard made to fit. Made by Dan at Mojoaxe! Thanks Dan!
    Backplate.
  19. Danelectro
    Danelectro V.I.P. Member
    3,659
    5,196
    Sep 6, 2007
    Looks like its going to fit. I'm glad I could help to make the guitar whole again.
  20. deadlyweasel
    1,439
    1,101
    Mar 25, 2011
    Everything looks awesome thank you very much!
