Vintage Bees and 50's Wiring Tone Test/Comparison
Discussion in 'Tonefreaks' started by VastHorizon, Apr 8, 2010.
  1. jonesy
    17,207
    4,453
    Mar 28, 2008
    You can use the Bumble Bees capacitors with any type pickup, but the important thing is to get the right cap value. Somewhere from .022-.047 uf might be a good range for P-90's since they are just a big single coil and are often brighter than humbuckers.
  2. black sheep
    black sheep Junior Member
    23
    4
    Jul 7, 2011
    "Any two capacitors, no matter the construction will function exactly the same. Doesn't matter if it's a ceramic disc or pio...if they are both 22 micro farads they will sound identical.
    You think electrons care?:thumb:"
    That myth has been "BUSTED" :)
    Arzachel likes this.
  3. The Outlaw
    The Outlaw Senior Member
    792
    282
    Oct 26, 2011
    in cheaper epiphones (jr, studio) would just getting the bee's and wiring them 50's style with the stock wire and pots show much improvement like this?
    i dont mind buying a $100 harnes for higher end guitars (agile, epi custom) but it would seem a little crazy to buy a $100 harness for a $200 studio or $89 jr with stock pups just seems like a waste. or am i thinking wrong and the pot and wire upgrade would be so huge that it would be worth it even with stock pups?
  4. jonesy
    17,207
    4,453
    Mar 28, 2008
    If you plan on keeping the guitar investing in some CTS550K pots would be worth while. That alone will make a big difference in clarity and help get rid of the mud even more so then just swapping out caps. 50's wiring, some good Tone caps and a Switchcraft switch and jack would also help out a lot. Buy all the parts and wire it up yourself and you will save some cash
    2 people like this.
  5. milkyway77
    milkyway77 Senior Member
    147
    58
    Jul 1, 2010
    I was thinking for decades that blondes have more fun.
    I was wrong, either... :D
    1 person likes this.
  6. artguy47
    artguy47 Member
    84
    21
    Jun 10, 2011
    Yep, pretty noticable difference.
  7. R8.
    R8. Member
    55
    72
    Sep 22, 2012
    I'd like to apologize in advance 'cause I'm probably about to ask some really stupid questions :D
    For a R8, I need short shaft pots, right?
    I was checking out Jonesy's pre-wired LP harnesses, and it says "Comes with the best 10% CTS550K pots that have a smooth custom taper and a .022 Oil filled tone caps.". Are those caps the same as bees?
    Is it worth changing the output jack and toggle switch on a historic lp?
    Thanks!!
  8. matt@msscguitar
    matt@msscguitar V.I.P. Member
    9,675
    6,591
    May 5, 2008
    R8's require short shaft pots. No need to change out the switch or jack since both are already Switchcraft and wired with single conductor braid.
    As for caps, I don't want to comment too much on what others sell, but 1950's Bee's come in both Mylar and PIO. Paper in oil is by far more difficult to source, especially if your wanting one that still reads within spec.
    Here's a picture of an original late 1950's Mylar Bee .022/400V 20% Tolerance:
    These caps cost more than most prewired harness because they are rare and expensive to source.
  9. R8.
    R8. Member
    55
    72
    Sep 22, 2012
    Thanks martin6string!
    So, it'd better to buy new pots on one side and try to track down old bees on the other? If so, do you know who might have some?
    Soundwise, the difference between old bees and the ones offered in pre-wired harnesses would be noticeable?
    You mentioned PIOs that read within specs, what specs would that be?
    Thanks again! and sorry for my rookie questions, never been into caps and electronics
  10. matt@msscguitar
    9,675
    6,591
    May 5, 2008
    I'm a vendor who sells this stuff, so I can't say any more in this thread. Send me an email to info at martinsixstringcustoms dot com and I can answer all your questions.
  11. OBX351
    OBX351 Senior Member
    2,342
    2,633
    Jun 4, 2012
    I can't believe the difference...the bees sound great! Nicely rounded not as much treb on the second with great mids...I am doing the same thing to my '01 R8 and I can't wait!!
  12. talven
    talven Member
    76
    103
    Oct 12, 2012
    I just played both clips for my kids, age 12 and 15. They both said, without hesitation, that the Bees sounded better.
    I agree.
  13. dipstef
    dipstef Junior Member
    6
    1
    Mar 26, 2011
    I love original bees, I put some old pafs on my favorite les paul, but I wasn't extremely impressed by the sound, after putting a pair of vintage bumble bees it was instant mojo. To me they do add a lot of complexity, and allow you to play quite a bit with tone and volume knobs to get a huge range of sounds.
  14. Frogfur
    Frogfur Senior Member
    19,136
    33,673
    Jan 18, 2013
    Geez..I think i can actually hear the difference between the two myself. Sounds great!
    Thanks for the clips
    Peace
  15. gtr-tek
    gtr-tek Fumble Fingers
    2,589
    863
    Mar 24, 2010
    Gotta love the '50s wiring and any good PIO caps. It really opened up my Lesters and clones. The difference is like night and day to me.
  16. buffa d
    buffa d Member
    62
    35
    Mar 22, 2012
    Can you wire these "vintage" sets with bees in a modern style as well?
  17. stevesmith67
    stevesmith67 Junior Member
    1
    0
    Nov 8, 2011
    Very cool. Thanks for this clip. I have a 2010 58 RI with bees and love the sound. I thought your clip was 2 diff guitars and was wondering about diff in pups but now realize you used the same guitar with modded wiring. Yes?
  18. tubemania
    tubemania Junior Member
    11
    2
    Jan 22, 2011
    More patents here
    US 2739277 Capacitor eyelet construction
    US 2904733 Molded capacitors
    US 2940025 Electrical capacitor
    US 3156854 Wound capacitor with internal impregnating tube
  19. Northwinds
    Northwinds Senior Member
    3,625
    3,961
    Dec 27, 2010
    Bee's by a wide margin indeed. Glad I have a bunch of NOS Sprague .022 10% 400v's that I stumbled upon. I have heard the Luxe ones are decent also but have no experience with them. Thanks for the clips and this great thread :dude:
