Vintage Bees and 50's Wiring Tone Test/Comparison
Discussion in 'Tonefreaks' started by VastHorizon, Apr 8, 2010.
  1. Electric_Sunshine
    Electric_Sunshine Senior Member
    3,386
    492
    Oct 12, 2008
  2. roknfnrol
    roknfnrol Senior Member
    362
    100
    Jan 16, 2009
  3. onehippie
    onehippie Senior Member
    8,008
    37,240
    Apr 28, 2010
    a Jonesy review could be interesting
  4. takeitslow
    takeitslow Member
    60
    138
    Mar 27, 2011
    Hi to all,
    Sorry if you already talked about it (I've searched the forum but couldn't find!) but as I want to upgrade the electronics of my 2010 Gibs R0 with buying the RS premium vintage short shaft kit, there's one with Paper & Oil Jensen Caps and another one with Luxe bumblebee caps.
    Which kit should I buy? And why? For I see a small difference in price but what about tone?
    Thanks for your replies.
  5. matt@msscguitar
    matt@msscguitar V.I.P. Member
    9,655
    6,518
    May 5, 2008
    Luxe Bumblebee Repros are simply new old stock paper in oil capacitors in a very well done jacket. I'm not sure what NOS caps Donovan is using currently, but for a good while, he used NOS Russian K40Y9's.
    Luxe's are the best reproductions available, IMHO.
  6. takeitslow
    takeitslow Member
    60
    138
    Mar 27, 2011
    Thanks for your answer Martin6string.
    When I was about to order, I realised that the Luxe Bumblebee kit has two .022 caps while the Jensen kit has one .022 and one .015 cap.
    So, as I read that a lot of players use the .015 for the neck... What to do?:hmm:
  7. Wraptail
    Wraptail Senior Member
    2,170
    1,427
    Jul 23, 2007
    I wouldn't waste any $$$ on Luxes... unless the looks/outer wrapper is really important to you. Sounds like you don't even know exactly what kind of cap your getting from Luxe anyway.
    For the same amount of $ you can get some American made Vitamin Qs AND some Russian PIO caps; or and/other old American made PIO caps.
    Then you can swap around to see what you like.
    You can also run caps in parallel to double the value - ie 2 .01 caps in parallel = .022.
    -.01s are typically cheaper as they are deemed less desirable.
    From *my experience* different caps of the same measured value sound and feel different.
    And don't forget, some highly regarded guitar tone has involved ceramic disc caps (ex:Clapton's 335 & SG from his Cream days had them OEM) so I wouldn't just write those off either.
    jonesy likes this.
  8. jonesy
    17,190
    4,411
    Mar 28, 2008
    What Rude Dog said, don't waste money on repro caps when you can get the real thing.
    New Old Stock USA PIO & Ceramic disc caps...word ;)
  9. takeitslow
    takeitslow Member
    60
    138
    Mar 27, 2011
    Hi to all and thanks for your answers.
    I've read a lot about RS Guitarworks vintage kit (with CTS superpots) but also discovered a real nice guy (the one from above, that has the Mojo:D) with 550K audio pots.
    What are the changes brought by superpots, comparing to "550 audio"? Why should some people buy the RS superpots and some other just the "simple" Jonesy 550 pots? I dunno what to choose...
    I'm not a huge user of guitar pots but what I dislike about the pots in my R0 is that when the volume pots are on 0, there's no sound (that's great!!!). Then, you just begin to hear a whisper at 2. It becomes soflty louder on 3.5. Then, nothing up to 5 where it's louder. Nothing at 6 but gets louder at 7. Then louder at 8 and 9 and just a slight difference from 9 to 10. In fact, shoul I be rude, it just like having a volume from 10 to 6 and then it's so light a change that it's almost useless to have the numbers back to 0...
    For the tone pots, it goes like: 10, no big difference, a real change at 6, slight difference, 4,..., 2,...,0...
    I guess that it's the pots and not the fake Gibson Bees that create that, no? Otherwise, I just could get some PIO caps...
    I've ordered some Seymours APH2 for I also found my bridge burstbucker too harsh and now, I'm just hesitating for the upgrading pots...:jam:
  10. matt@msscguitar
    9,655
    6,518
    May 5, 2008
    The CTS550K's have a very responsive audio taper. When wired 50's style, they roll off evenly, so if you want to clean up your sound, you can roll the volumes back without your sound getting muddy.
    As far as Luxe goes, they are in fact the most accurate reproductions of the real deal. They are all paper in oil and very high quality.
  11. matt@msscguitar
    9,655
    6,518
    May 5, 2008
    You can get a harness with Luxe Bee's in .015/.022 or .022/.022. Just depends how much highs you want to roll off the neck position.
  12. jonesy
    17,190
    4,411
    Mar 28, 2008
    The Luxe caps look nice and the Russian caps they use inside the wrapper are paper in oil, but IMO they just don't have that "Woody Tone" like the real 1950's Bees do. Tone wise the Sprague (maker of the original Bees) and Cornell Dublier pio .022's come a lot closer YMMV ;)
  13. matt@msscguitar
    9,655
    6,518
    May 5, 2008
    Yes, I agree, Dave. I love the original Bee's. I really like the K40Y-9s and have them in some of my guitars, but the 50's Bee's are definitely a step above :)
  14. Wraptail
    2,170
    1,427
    Jul 23, 2007
    I really wish people would stop referring to Luxe caps as "reproductions" because they are not.
    They're existing caps (that you can get MUCH cheaper else where) that are repackaged. There's a reproduction of the outer casing and that's it.
    From what I've seen in photos of the ones dissected they can be Russian PIO or something else like General Instruments PIO.
    So you don't even know what you're getting.
    And the ones I've seen are 200v, not 400v as the original Bees.
  15. matt@msscguitar
    9,655
    6,518
    May 5, 2008
    The are reproductions, both by virtue of the fact that non Mylar Bees were paper in oil and by cosmetics. What's the issue?
  16. takeitslow
    takeitslow Member
    60
    138
    Mar 27, 2011
    Hi,
    I'd like to thank you all for I met a real nice guy, David-Jonesy from whom I'm getting a 50's kit with 550K pots and PIO caps (.022 for bridge & .015 or .018 for neck). Never met someone answering so nicely and quickly to all questions... Great man!!!
    Can hardly wait to have that stuff in the R0 with its new Seymours APH2 to see (hear in fact) how it sound...
    :thumb:
  17. takeitslow
    takeitslow Member
    60
    138
    Mar 27, 2011
    Hello,
    Here's the kit I just got from David today
    BV 574 BT 546
    NV 573 NT 559
    .022 Sprague Hyrel for bridge
    .018 Cornell Dublier for neck
    Aerovox .022 and Russian .015 not soldered...
    What do you think? Looks great, no?
    Jonesy is a great man!!!!!
    Hope it'll sound good in the R0 with the APH2 Slash I also got three days ago...
    jonesy likes this.
  18. southpaw219
    southpaw219 Member
    61
    1
    Sep 20, 2011
    Did you mention where you got your bees? I didn't see it. If not, could you let us know? Thanks.
    Edit: Nevermind; I got to the post where you link to the thread where the bees were sold. I think I'd rather cut off my own hands than pay $50 for a capacitor, no matter whether it sounds like God's own voice or not.
  19. roknfnrol
    362
    100
    Jan 16, 2009
    I got some of these, they sound really good. However, I should have purchased the real thing from Jonesy.
  20. jimbob137
    jimbob137 Senior Member
    367
    83
    Oct 11, 2011
    I have an 09 137classic with P90's in it. Are bumblebees a good upgrade with p90's?
