Video About How to Solder
Discussion in 'Tonefreaks' started by 5F6-A, Dec 9, 2008.
  1. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    [ame=http://www.youtube.com/watch?v=I_NU2ruzyc4]YouTube - How and WHY to Solder Correctly[/ame]
    interesting and useful
  2. Gordon Gekko
    Gordon Gekko Member
    97
    1
    Sep 23, 2008
    Definitely, thanks!
  3. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    I'd share some info about how I solder.
    - I use an Italian soldering iron Ewig with temperature selector. I set it just above 300ºC.
    - I wait until the iron is hot enough and in the mean time I put a TINY bity of extra flux over the area we are soldering onto. I mean a very thin layer. :rolleyes:
    - Then I heat the part to solder and as soon as the flux "burns" ( you'll see the fumes ) I add some solder which will be atracted to the iron tip. Positioning the solder wire and the iron tip in opposite directions (ie facing each other) will result in a "centered" solder union.
    - Then it's time to take away the solder and a spilt second after the hot iron. Count to three. Do NOT blow over it and voilà! perfect, shiny result.
    Soldering it's not difficult but like anything else needs some instruction, patience and practice.
    Blackegg likes this.
  4. b-squared
    b-squared Banned
    21,123
    9,172
    Jan 21, 2008
    Great post!
    BB
  5. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    as always, glad to help!!
  6. b-squared
    b-squared Banned
    21,123
    9,172
    Jan 21, 2008
    I made it a sticky; that's a great vid.
    BB
  7. peter679
    peter679 Senior Member
    2,418
    580
    Nov 18, 2008
    b-squared thanks for stickying this I'm trying get edumacated
  8. PMcG No.6
    PMcG No.6 Senior Member
    1,020
    24
    Jul 22, 2008
    Great vid. Thanks. :thumb:
  9. Zoshquin
    Zoshquin Senior Member
    2,796
    153
    Nov 22, 2008
    thanks! I learned something! :D
  10. BigJza
    BigJza Senior Member
    315
    48
    Dec 8, 2008
  11. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    that's the key factor...the more you do it, the better you get at it.
  12. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    BTW, this is what I use for soldering pots
    I stuck an old speed knob on to a wooden square ( I use a drop of Franklin's hide glue ) and left it to dry. Then when I need to hold a pot properly to solder a cap onto it or whatever I have a stable base to work on.
    Raiyn, jay1williams, Phelan and 3 others like this.
  13. KP
    KP Senior Member
    16,556
    18,442
    Apr 30, 2008
    I went a slightly different direction...
    I measured out the placement of the holes and created this....
    Tonemeister and Deftone like this.
  14. calibud
    calibud Senior Member
    4,486
    159
    Aug 6, 2008
    :thumb:
    great video!
  15. rockitmarty
    rockitmarty Junior Member
    20
    0
    Oct 3, 2008
    That's interesting, I found that very useful, thanks.
  16. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    something I¡'ve postd somewhere else, but I think it's important:
    "wattage and temperature has little to do with each other. To cut a long story short, a 40 watt iron won't be necesarily twice as hot as a 20 watt one, but it'll be twice as efective at keeping the set temperature"
  17. ck42
    ck42 Junior Member
    15
    0
    Nov 9, 2008
    Excellent tutorial. :thumb:
    Having worked in the electronics manufacturing industry for many years before, and actually being what would be considered an industry expert in the field of soldering (process engineering with customers and teaching soldering classes) I can tell you that everything that was covered in the video was spot-on accurate.
    He covered pretty much every key point too....and did an very nice job of explaining things and gave good visual representations.
    So...my contribution here would be to say that take what has been covered in this video as being very accurate and very reliable information!
    To the tutorial author, whoever you are, kudos!
  18. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    thank you to you too!!
  19. randelli
    randelli Senior Member
    6,060
    6,341
    Jul 26, 2008
    Hey great tips!
    I have done my share of soldering but this really taught me the right way. I knew about heating the work first; but tinning the tip was new for me. Well, I knew you should tin the tip, I guess I thought it was just for new tips. I didn't know that you should do it all the time.
    This would explain why there is one small spot on my iron that heats enough to melt solder...........
    Thanks for the great post!
    jonas335 likes this.
  20. Marto
    Marto Senior Member
    346
    8
    Nov 10, 2008
    Hey, thanks. I really want to learn how to solder. The vid you posted will be a big help.
    Marto
