Vanilla Smell
Discussion in 'Gibson Les Pauls' started by Dangitdan, Feb 4, 2018.
  1. ivandolz
    ivandolz Member
    60
    92
    Dec 4, 2017
    My 2015 traditional came with the gold case... And it had the strong Vanilla smell, as many of my other USA Gibsons.
  2. dspelman
    dspelman Senior Member
    10,098
    6,142
    Apr 30, 2009
    I think those "other threads" established that there's an aldehyde in one of the solvents used in (probably) a glue that has the same general chemical makeup as vanillin, the compound that gives vanilla its smell. You don't want to spend a lot of time sniffing that aldehyde; it's likely bad for your nervous system.
    dsmcl77 likes this.
  3. islandjimmy
    islandjimmy Senior Member
    159
    131
    Jul 7, 2013
    I just checked my gold case and it has very little to no vanilla smell. Maybe our cases were made at different factories? My Gibson USA standard issue black case has loads of vanilla smell. And the mystery continues.....:hmm:
  4. ivandolz
    ivandolz Member
    60
    92
    Dec 4, 2017
    It is a mistery for sure...
    Dangitdan likes this.
  5. SamMoor
    SamMoor Junior Member
    13
    10
    Jan 18, 2014
    Hi
    I used to work at a music store so I opened a lot of guitar cases over the years. There is a Gibson Smell, a Fender Smell and a Martin Smell (oooooh, the Martin Smell is amazing) and others. They are all kinda vanilly. I believe Martin and Gibson cases come from the same factory in Canada. Oh yeah, and Lakewood guitars are also fantastic.
    So I think part of the smell is from the case itself. The woodglues, the plush and probably the glue that is used for gluing in the plush.
    Then there is the instrument itself. The wood, the glues, the finishes. I am currently oiling the fretboards on around 50 classical guitars from spain and they come in cardboardboxes. And they all have a distinctive bananaish vanilla smell. Once I'm done with them there will be a hint of citrus added to that because I'm using lemon oil.
    emerald81 and islandjimmy like this.
  6. dexterchops
    dexterchops Junior Member
    2
    0
    Apr 5, 2011
    If I remember artificial vanilla is made from a wood product which is somehow connected to the smell that is oozing from our axes. It may be the bodies are soaked with a wood solvent prior to finishing and that is reacting with the finish in a weird way to smell as it does. Or maybe not.
  7. kiko
    kiko Senior Member
    1,134
    1,281
    Jul 16, 2015
    Its the guitar. I bought a brandnew epiphone LP case for my then new 2014 LP studio. When I openned the case the next day out came that vanilla smell. Wonderful! :)
    1all's Pub likes this.
  8. leofender55
    leofender55 Member
    71
    147
    Dec 26, 2013
    I recently bought a 1961 Reissue ES-330. It was from the Memphis plant and I am the first owner. When I got it and opened the case it had a strong odor, but not vanilla, more like clay. I traced the odor to a fairly large packet of silicone type of material for moisture control that was in the accessory compartment of the case. Every time I play the guitar I leave the case open and the smell is slowly dissipating. The ES-330 is a fantastic guitar. It looks like they won't be made much longer with the situation around the Memphis factory.
  9. Have FUN
    Have FUN Senior Member
    1,514
    1,650
    Apr 27, 2011
    Gibson cases are made by TKL in Canada and the case smell nothing. My 2015 SG is in a Gibson / TKL Custom shop case, the vanillia smell come from the Gibson SG
    rockstar232007 likes this.
  10. Curious George
    Curious George Premium Member
    1,357
    1,074
    Nov 23, 2012
    Think you might be onto something. Catalyzed lacquer is composed of urea formaldehyde or urea melamine and an alkyd that has some nitrocellulose resin added (to make it handle like normal lacquer). Traces of many aldehydes often contribute to their favorable odors, e.g. vanillin.
  11. zamdrang
    zamdrang Member
    91
    126
    May 2, 2009
    Interesting discussion, I have a Peavey Vandenberg that has always smelled vanilla-ish when you open the case and always been a mystery to me. I thought it was coming from the case but idk, I believe is poly coated but not sure.
  12. charlie chitlins
    charlie chitlins Senior Member
    2,799
    2,238
    Feb 8, 2011
    I had a new Firebird and the fellas in the band started calling me Cupcake.
    islandjimmy likes this.
  13. wmachine
    wmachine Senior Member
    613
    477
    Dec 4, 2015
    Goes to show you that a "lot of research" in itself does not guarantee any results. The *type* of research is what counts. Your proof of it being the case (sniffing the compartment) isn't even close to any kind of proof. Yikes.
    I don't know why your 2015 Trad does not have the smell. But my 2015 LP Trad (yes with the gold case) does have the smell, as does 5 other 2015 Gibsons (all different models) with gold cases.
    I have yet to see one single instance when any objective reason is given that the smell comes from the case. It comes from the finish on the guitar. The case smell is an Urban Legend that just won't die.
    1all's Pub and rockstar232007 like this.
  14. rockstar232007
    rockstar232007 Senior Member
    16,101
    12,595
    Jun 28, 2008
    Yep.
    My 2001 Classic has "the smell", but the case stinks of glue. Go figure.
    The vintage '61 SG/LP that my uncle just sold, same thing - the guitar smelled like candy, but the case smelled like old furniture.
    It's the buffing/polishing compound. Plain and simple.
    P.S. my 2002 Epi LP Standard (which I bought brand-new) smells like vanilla, even after I "aged" it, as there is still some buffing-compound in the pickup cavities. The case? Not so much.
  15. Wolfie
    Wolfie Junior Member
    20
    3
    Aug 14, 2011
    The Gibson pump polish is worth a try. I emailed Gibson & received a reply,
    "10/20/08 Thanks for getting back to me here at Gibson. Gibson USA says the "Glans" polish they use does not really have an odor. They believe what you smell is the "Betco Brite" cleaner used just before the guitars are shipped. Thanks. Best regards, Bob Burns" In another reply he states, "Gibson does not sell Betco Brite cleaner. I do not know if this product is commercially available, but you might find the product if you do a Google search."
    Doing a quick search I only came up with a lemon scent, a more thorough one might find it in vanilla?
  16. rockstar232007
    16,101
    12,595
    Jun 28, 2008
    In my MS shop-class, we had two, large buffing wheels, and TONS of buffing/polishing-compound. The whole area around the wheels smelled exactly like vanilla - it's the compound.
    DarrellV likes this.
  17. Reddog22
    Reddog22 Junior Member
    3
    0
    Oct 21, 2016
    I bought a brand new Gibson USA case for an SG and it definately had the vanilla smell without having a guitar in it before. Smelt beautiful.
  18. JesseXGibson
    JesseXGibson Senior Member
    255
    422
    Aug 24, 2017
    +1 for buffing, ive only owned a few gibsons, but there was only one where the case smelled like vanilla more than the guitar. I also know that’s not what nitro smells like. So just by order of elimination, my moneys on the polishing/buffing compound. Although it is still a mystery, I wonder if Gibson keeps their vacant cases by the buffing wheels...:hmm:
  19. The Ballzz
    The Ballzz Senior Member
    1,514
    1,007
    Mar 28, 2013
    Might we assume that said "long discussion" may have included some chemical and metaphysical experimentation and processes, such as "converting alcohol to urine and clear thought into bullshirt?" :rofl: :p :cheers2:
    Smell is likely a combination of buffing compound and polish!
    Just Teasin' & Welcome!
    Gene
  20. islandjimmy
    159
    131
    Jul 7, 2013
    "Yikes" is right. Wouldn't deductive reasoning lead one to conclude that it might be the case producing at least part of the vanilla smell if a closed compartment inside the case produces the exact quantity of vanilla smell as the open area inside the case? If it is ONLY the guitar finish producing the smell, then how could it permeate a closed compartment to the same degree as the outside area touching the guitar? Also, I can put any guitar in that case, even a guitar with no smell whatsoever, and it will come out smelling like vanilla after a few days.
    Nitrocellulose lacquer produces a vanilla like smell, but not always the same. For example, my Rickenbacker has what they call "Rick-o-smell", it's a vanilla-like smell but not like Gibson USA. My Gibson Custom Shop Les Paul has a vanilla like smell but it's more earthy smelling than the Gibson USA models. It has been scientifically proven that one of the scents most attractive to the male brain is the smell of doughnuts, which in my opinion come close to the smell of a Gibson USA Les PAul. I don't think it would be a stretch that a vanilla scent may be added to nitro, the case, or both, in order to make something more attractive to the main purchasers of said item.
