Using Voodoo Labs Pedal Power 2 Plus for Recording Gear
Discussion in 'Recording Studio' started by Buzzin_Cousin, Mar 2, 2018.
  1. Buzzin_Cousin
    Buzzin_Cousin Senior Member
    862
    312
    Dec 14, 2013
    I've got a Tascam DP-008ex that eats batteries pretty good. I've got the Voodoo labs pedal power that I'd rather use to power it than buying a separate power supply. The voodoo labs is 9v and the Tascam is 5v. Can I use it safely? There is also a SAG that you can dial from 4v to 9v but I've never used that function before..
    Thanks,
  2. AllTheSound
    AllTheSound Senior Member
    766
    664
    Oct 5, 2013
    I would not recommend it your Tascam requires 5v 2 amp output even if you could dial the sag down to 5 volts the Voodoo Lab PP does not even come close to the amps requirement. It tops out at 250ma which is about 1/10 of what you need. You also need to match the tip polarity.
  3. Buzzin_Cousin
    862
    312
    Dec 14, 2013
    Thanks for your response. I think I'm going to buy a dedicated adapter for this.
    Mockbel likes this.
  4. Mockbel
    Mockbel Senior Member
    2,365
    2,175
    Nov 2, 2015
    With such odd power requirement (5V) I would look for vendor supplied power supply or at least something that matches ALL power characteristics (volt, current, polarity)... i wouldn't to rely on such variable voltage adapter
    Buzzin_Cousin likes this.
  5. Buzzin_Cousin
    862
    312
    Dec 14, 2013
    Yeah, the tascam model is $25!
    Amazon 4.5 star rated off brand is $10. Not sure which I'm going with yet.
    Mockbel likes this.
  6. Mockbel
    2,365
    2,175
    Nov 2, 2015
    Get the tascam and forget about it
  7. Freddy G
    Freddy G V.I.P. Member
    11,315
    23,567
    Mar 18, 2007
    Not odd at all. In fact....ubiquitous! 5V is a defacto standard for logic circuits.
    Mockbel likes this.
  8. Mockbel
    2,365
    2,175
    Nov 2, 2015
    I consider anything but 9V as odd :)
    May be due to my limited exposure.. all pedals i have are 9V and all I have seen were whether 9V or 12V
