Use any overdrive/distortion pedals?
Discussion in 'Historics & Reissues' started by 58VOSLESPAUL, Jun 8, 2010.
  1. 58VOSLESPAUL
    58VOSLESPAUL Junior Member
    22
    1
    Jul 26, 2009
    Do you guys use any overdrive distortion pedals with you reissues and amp or do use use the channels completely from amp? Just curious? If so what kind?
  2. capthowdy
    capthowdy Senior Member
    276
    42
    Apr 27, 2010
    Depends. My main amp is a Koch StudioTone 20 Head with 2.5 channels; clean, od and od+. I use a Bad Monkey TS clone with it. If I'm using my
    non-master volume Matamp Chino combo, which is a single channel amp, I'll use the Monkey and a Blackstar HT Dual. This is all regardless of the guitar (I rarely use single coils)
  3. Lemonhead
    Lemonhead Senior Member
    1,244
    331
    Mar 25, 2007
    Pedals, most definitely. I play through a old blackface Bassman head that has the bass channel modded to be like a Marshall, and I use an old Rat pedal and, recently, have been using a GGG Brown Sound pedal too.
  4. pippy
    pippy Member
    91
    16
    Jan 30, 2009
    No.
    Although twenty-odd years ago I had a Big Muff Pi.
    I play through a Music Man 2x12 and it has easily more than enough overdrive for my needs.
  5. Penny Dreadful
    Penny Dreadful Banned
    6,199
    6,218
    Feb 21, 2008
    I only use a pedal when using my Strat. A moded TS808 at the front of the chain.
  6. asmith9509
    asmith9509 Senior Member
    225
    2
    Jun 7, 2008
    Yes. I play through a Boogie Mark 2, and at reasonable volumes it is tough to get full crunch. I like a Monte Allums modded Blues Driver, and sometimes use a TS808 to boost for solos.
  7. lewddude
    lewddude Senior Member
    1,349
    246
    Aug 24, 2008
    I only use a BBE Boosta Grande with my Twin Reverb. My Marshall Mode Four needs no pedals...
  8. diceman
    diceman V.I.P. Member
    29,932
    5,214
    Jul 5, 2007
    Fulltone Fulldrive 2, original Marshall Bluesbreaker, Ibanez Tubescreamer TS9, Danelectro Fab Tone...
  9. Boleskinehouse
    Boleskinehouse Senior Member
    27,348
    2,250
    Feb 1, 2008
    I prefer whatever distortion the amp is capable of on its own. I've never been into pedals much and rarely ever use those that I have.
  10. dwagar
    dwagar V.I.P. Member
    7,735
    966
    Jul 14, 2007
    I think this is more of an amp question than a guitar question. My amp looks after the overdrive. I run through either a JTM60 or a JCM800.
  11. 59bluze
    59bluze Senior Member
    255
    2
    Apr 12, 2009
    I have a few amps, but mainly I use Two tube Screamers,one for a mild boost and one for more boost, I have a Boss DD2 Delay,Keely Compressor, an Orig, UniVibe, I just picked up a new OKKO Diablo Pedal,Its like a Tube Screamer with more control, Very nice for a clean boost. Some Gigs I just go straight into a Kendrick Tweed Bassman Clone amp, It has great Tube reverb, It all depends on what music/gigs to what Effects or amp needed.
  12. AngryHatter
    AngryHatter Senior Member
    17,185
    13,096
    Jun 19, 2009
    Fulltone OD
    Bluesbreaker
    Satchurator
  13. uburoibob
    uburoibob Senior Member
    1,580
    422
    Aug 4, 2009
    I generally use the built in Tube Screamer or 808 built into my Digitech RP-500. But I rarely use distortion.
    Also, I use channel two on my Mesa Express 5:25 12". It's marvelous.
    For recording, I generally will use my 1958 Gibson GA-20T amp. Great Tube saturation and weep.
    Bob
    mre828 likes this.
  14. BEDLAM_1
    BEDLAM_1 Senior Member
    1,006
    326
    Sep 11, 2009
    I use a speedbox by Modtone,,,not all the time..must for that push, they ARE great pedels for the money i think...i found pushing an over driven valve amp the best way to use um..
    but they are great for low volume drive too.!..
    [ame=http://www.youtube.com/watch?v=_s7OOKEA1Sw]YouTube - Boss DS-1 Modtone Speedbox Distortion pedal shootout[/ame]
    Can be a bit noisey though
  15. BEDLAM_1
    1,006
    326
    Sep 11, 2009
    oh yeh!...and the tone on the MTis SO much better/versitile than the Boss..i think,
    Had both
  16. Micky
    Micky Senior Member
    1,164
    34
    Mar 4, 2010
    I generally use the crunch channel on my Marshall, but I recently modded my DS-1 pedal and it sounds pretty good.
  17. mraajr
    mraajr Senior Member
    1,534
    25
    Oct 9, 2009
    This holds true for me as well. I continue to buy them thinking that will be the "one" that makes a believer out of me but that has yet to happen.
  18. bluefrog
    bluefrog Senior Member
    945
    228
    Mar 15, 2009
    yep for a JTM45 Clone or AC 30 or Class 5,
    I have both Fulltone OCD and a ZVEX Box of Rock in front of the amps (alternative!).
    The class5 just needs a BOR.
    OD just sounds killer, no harm to the tone less is more and true by pass of course.
    my Englstraight doesn't need any pedal maybe a soloboost sometimes...
  19. tele52
    tele52 Senior Member
    1,280
    146
    Apr 19, 2009
    Marshall 1974x, I use the volume knob for overdrive. But if I want dirt at low levels OCD, and Fulldrive 2.
  20. Liam
    Liam V.I.P. Member
    5,951
    2,403
    Nov 19, 2007
    Hmm, let me see...
    Ibanez TS-10 (in 3 different flavours of modification)
    Boss BD-2
    Rat 2
    Colorsound Supa Tonebender
    JHS Fuzz
    Boss OD-1
    Boss SD-1
    Boss DS-1
    Si Fuzz Face
    Small Bear Bear Face
    Danelectro Daddy-O
    Danelectro French Toast
    GEO Foxx Tone Machine Clone
    Electro Harmonix Big Muff Pi
    Ibanez TS-9
    Russian Electroharmonix Big Muff Pi
    Boss HM-2
    I'm pretty sure I've got some others, but those are the ones I regularly get out, in rough order of preference. The TS-10s are the favourites, with the BD-2 close behind.
    As far as overdriving amps is concerned, I occasionally use the drive from the amp in a big way (Marshall 2203/2204) but I'll quite often use a fairly "straight" amp and just let the power tubes give me the crunch I want (Marshall 1987 or 1962, Fender PR, Epi VJ, Diason). I'm not really into channel switching amps.
    Unfortunately once you've tried a few of these things, you'll realise they're all good, so you'll want all of them. At least that's what happens to me.
    Liam
