Tweed 5E3- Amp settings, how do you like yours
Discussion in 'The Squawk Box' started by ac/dcfan87, Dec 4, 2017.
  1. ac/dcfan87
    ac/dcfan87 Senior Member
    1,889
    1,428
    Feb 5, 2013
    Tweed Deluxe amp (5E3) owners come in!
    How do you like to set your amp to get different tones?
    As you all may know, the tweed 5E3 is a very simple design but one that yields a versatile array of tones if you use the controls to your advantage. To those that don't know how this amp operates, it can be very confusing and hard to find the exact tone you're looking for.
    One of the ones I've heard a lot is the Marshall tone 10-10-10 setting. It works! Really well surprisingly. I was playing it earlier today and it eerie how much it sounded like a Marshall.
    A good clean sound I find is the bright channel on about 2.5 and the unused normal channel at about 6.5 and tone anywhere from 8-10. Also, another good way is turn the bright volume to about 6-8 and the normal unused volume to 12, tone on 8-10. It has a similar amount of clean volume, but the way it responds is quite different.
    I like to use the unused channel to load down the signal and clean it up. I also like to jumper the channels and come out of the normal channel. Gets a really fat sound and then dial the bright channel to bring the highs back in to taste.
    I also like to dial back the tone pot on my bridge pickups to about 6.5-7 to cut some of the high end. This allows me to run the amp tone control higher than I would otherwise- which makes the tone sweeter.
    Please share your tones and amp settings! Might give us all new some ideas.
    cherrysunburst00 likes this.
  2. sonar
    sonar Senior Member
    2,874
    1,963
    Sep 10, 2008
    Both volumes around 7, tone cranked, bridge pickup on a Les Paul, control amount of dirt with guitar's volume pot...
    Happy Place.
    ac/dcfan87 likes this.
  3. ac/dcfan87
    1,889
    1,428
    Feb 5, 2013
    Nice! Thanks buddy, I'll try that. Interesting that you don't find it too bright with the tone pot cranked. Do you lower your guitar tone control when doing this?
  4. scmglotr
    scmglotr Junior Member
    26
    18
    Apr 19, 2012
    Depends if I'm running the amp by itself or with my Princeton reverb. If it's by itself I'll run into the bright volume and run it with the bright colors on about 7 and the normal volume on about 6 and the tone about 8 or 9. With a humbucker or p90 I get righteous classic rock and blues tones and with single coils I get a little cleaner and lean sound. Gain is adjusted by guitar selection and volume manipulation.
    If I'm running it with my Princeton reverb I run both amps at edge of breakup. So bright volume on 4 and normal volume on 11 and tone at 7. Princeton volume at 5. Glorious. I get why Mike campbell runs them together. They compliment each other so we'll. At these settings I use a combination of low to medium gain overdrives and there isn't a tone I can get.
  5. bridger
    bridger Senior Member
    149
    90
    Oct 27, 2014
    For "sparkly" clean I plug into "bright" or instrument channel volume @3-4 with unused normal channel at 10, tone @9. Glorious cleans with a Telecaster, & a tiny bit of bite with P-90's.
    For dirt, Instrument (bright) channel at 3 or above, tone at 10, unused channel at zero & ride guitar volume to clean up.
    Incredibly responsive amp I must say.
  6. Cjsinla
    Cjsinla Senior Member
    3,584
    2,827
    Jul 7, 2014
    I pretty sure these amps don’t all respond exactly the same way. I built a 5e3 clone. For me, I was looking for less flabbiness in the bass and more headroom so I used a 12ay7 in V1. I am new to tweed Fenders, played Marshall for years and only use it in my living room. I have been really enjoying the chime of these old Fender designs.
    I did try the 10-10-10 setting for the hell of it. A little to flabby sounding with my setup, could be that the speaker has something to do with it. I usually set mine this way; the bright channel on 4, the normal channel on 10 and the tone on 6 or 7 and plug into the bright channel. Turning down at the guitar, this amp is plenty loud but really sweet sounding. Turning up yields great grind and enough volume and bass response to shake the floor and piss people off.
  7. NotScott
    NotScott Silver Supporter
    2,109
    4,555
    Nov 25, 2012
    On my 1960 Deluxe, I use a 12AY7 in the front end and plug into the high instrument input. I set the tone around 7 and the instrument volume between 3-9 depending upon how much crunch I want. I then dial up the mic input to tighten up the bottom and dial out the flub. Anything else I need comes from my guitar controls.
  8. ac/dcfan87
    1,889
    1,428
    Feb 5, 2013
    Yeah these 5E3 all react VERY different. Even right down to the tubes and tube brand it will react very differently. The flubby bass is a common complaint about these amps and are even more prevalent in newer clones. If you build a new one exactly to the schematic, it won't sound as good as an old one. I think part of this is due to the higher voltages today versus back then. Also the components in the old ones tend to drift over time, maybe for the good maybe for the bad. It just depends on which one you get. Even the transformers used play a large role.
    Definitely keep the 12AY7 in there. 12AX7 gives too much gain in this amp IMO and it will make it sound even flubbier in the bass. Speaker can make a big difference too. What speaker are you running?
  9. ac/dcfan87
    1,889
    1,428
    Feb 5, 2013
    Check out this video if you all haven't seen it.
    It explains the three main components of achieving your tone with the 5E3.
    1. Frequency response
    2. Overall gain/distortion
    3. Envelope of the waveform
    I was gonna try to explain it but Ron does a way better job than I ever could.
    Cjsinla likes this.
  10. Cjsinla
    3,584
    2,827
    Jul 7, 2014
    Speaker? The Jensen MOD 12-50, 50 watt speaker that came with the Tube Depot kit. I tried a Celestion greenback at one point. I couldn’t hear the difference but I also still had the 12ax7 in there, a different circuit board and did not know that the two channels interacted.
  11. ac/dcfan87
    1,889
    1,428
    Feb 5, 2013
    Interesting. Could probably do with a better speaker but... hey. What's good is good. The 50W rating probably helps keep the bass in check a little bit.
    I am using a Scumback M75 paper voice coil at 20 watts. Mine is a Mojotone kit that I bought off the Bay.
    Do me a favor: don't ever do what I did. I got tired of the flubby uncontrollable bass and so I had the amp modded with lower coupling caps, which is a common mod that people suggest. Do not do this. It ruined the amp. It did remove a lot of the flabby low end but in the process neutered everything good about the amp.
    Rather than going back to stock, I decided to send my amp to Ron, the guy who made the video posted above. Best decision I ever made. It turned it into a very special amp. That worked well for me for awhile, until I started having some issues with crackling. I sent it back to Ron to have it fixed... turned out the Mojotone OT had blown. So Ron replaced it with a vintage unit. Not the same vintage OTs that he sells in his amps, but a very old one. Sounds great and it made the amp compress a little earlier even and it made the highs a bit sweeter.
    I've rolled a lot of tubes in this amp. This is an amp... that changes for the better with old tubes. It really does. I don't buy into a lot of the NOS hype, but for the 5E3 it really makes a huge difference. The circuit is so simple that small changes yield large results.
    Now I am running old RCA 12AY7, old RCA 12AX7, old RCA rectifier, and old RCA 6V6GTAs. The power tubes make the biggest differences. Then the 12AY7. Then the 12AX7 last. The rectifier I don't think matters as much, as long as you get one with voltages like the old ones. The Sovtek 5Y3s have higher voltages. The only new 5Y3 with voltages comparable to the old ones are JJ afaik.
  12. Cjsinla
    3,584
    2,827
    Jul 7, 2014
    Yeah, the most modding I would probably consider is speakers or tubes. I was thinking about replacing the trannies but the Tube Depot kit came with decent ones it turns out. My Weber tweed Super kit came with some cheap Chinese stuff so I did change those.
  13. charlie chitlins
    charlie chitlins Senior Member
    2,761
    2,182
    Feb 8, 2011
    Plug into the inst channel and turn the mic channel until I find the sweet spot. Usually around 8.5-9.5.
    Works with my Bassman, too.
    Plug into inst channel, mic chamnel on 12.
    Glorious cleans.
    Now unplug from inst channel and plug into that inst channel. Sag and sustsain that is almost like a cello.
  14. Axis39
    Axis39 Senior Member
    1,001
    495
    Dec 1, 2009
    Cox Ultimate 5e3 owner checking in... When i got mine, it had a Celestion Gold in it and was very dark at lower volumes. I took a chance and picked up an Eminence 1228. What a great match for this amp!
    I run my guitars into the Bright channel. Instrument Volume: 5-10 Normal Volume: 10 (unless I am playing a quiet gig, then I move it up beyond 10 to get some attenuation and additional breakup) and my tone knob usually sits around 9-10. 98% of the time, I am only running a Topanga Reverb pedal into the amp. Wah, Univibe, Delay and a couple of dirt/boost pedals share the other 2%.
  15. charlie chitlins
    2,761
    2,182
    Feb 8, 2011
    BTW...great speakers are available for these amps ALL DAY LONG for $15 on Ebay.
    Organ and stereo pulls...alnico, ribbed or not, Rola, Magnavox (it's CTS!), etc...
    I've got one I can't find on the EIA list that I like better than the original P12R.
  16. Cjsinla
    3,584
    2,827
    Jul 7, 2014
    What makes a good speaker?
  17. charlie chitlins
    2,761
    2,182
    Feb 8, 2011
    I like the way it sounds.
    That's why I was careful not to say I found a better speaker.
  18. jwinger
    jwinger Senior Member
    2,252
    847
    Apr 7, 2008
    Bright channel on 10 to 11 (depending on compression I want) , normal a hair over 10 and tone on about 11. Everything else done via guitar controls
  19. Oatie
    Oatie Member
    44
    25
    Dec 5, 2017
    The V1 has the 12AY7 ( 44% gain ). You can use a 5751 tube in V1 and raise the gain to 70%. The ,12AX7 is 100% gain, so the 5751 is a fun tube for ZZ Top tones. I use the 6087 rectifier and in this amp some old Mullard 6V6GTY ( Brimmer ).
  20. Bill Hicklin
    Bill Hicklin Senior Member
    7,838
    11,043
    Nov 3, 2014
    Besides the lower-gain V1, a common mod to control flubbiness is to put a grid stopper on the PI.
