Tube amps not having power tube distortion? - Blackstar HT5R
Discussion in 'The Squawk Box' started by CosmicEnergy, Feb 18, 2014.
  1. CosmicEnergy
    CosmicEnergy Senior Member
    197
    50
    Feb 7, 2014
    HI, i'm sorry if this has been asked before but i don't seem to find the answer. I have a blackstar ht 5 and the other day i had the chance to crank the OD channel volume but it doesn't breaks up, it doesn't distort with the volume up like a tube amp should, i leave the gain knob at 1 and 2 or 3 and it still doesn't get power tube distortion, it's just preamp gain. So how cain i get power tube distortion with this amp? i'm kinda dissapointed with my amp :(
  2. babatube
    babatube Senior Member
    4,620
    4,307
    Oct 1, 2010
    try to crank the clean channel to 10, that should bring you power amp distortion.
  3. CosmicEnergy
    197
    50
    Feb 7, 2014
    I already did but it's not enough, the distortion there is too soft, but thanks anyway :)
  4. Marshall & Moonshine
    Marshall & Moonshine Senior Member
    21,555
    37,893
    Jul 21, 2010
    Crank the volume, then bring up the preamp until the amp starts to distort. It might get loud, but that'll be it.
    I find that with my 800 (a vastly different amp, but a MV amp...), I like a mix of preamp and power amp distortion.
    Everything around noon, is what I really like.
    Just keep twisting knobs until you find it. If you can't get it to break up with everything dimed, it might need to be checked out.
  5. slagg
    slagg Senior Member
    587
    212
    Apr 5, 2010
    Not gonna happen.The "Power section" uses a 12bh7 Preamp tube as it's power tube.In the 12--- world it is a very clean strile tube mostly used as a reverb driver.All the B.S. on the blackstar HT5 is diode clipping.Don't care what anyone tells you,that's what it is.
    3 people like this.
  6. babatube
    4,620
    4,307
    Oct 1, 2010
    that's true the blackstar HT series are hybrid amps.
    their dirt come from opamps and diode clipping.
  7. Marshall & Moonshine
    21,555
    37,893
    Jul 21, 2010
    Hmmm. Surprised I haven't heard that by now. (Surprised, not shocked....)
    I just thought they were EL84 MV amps.
    So that's why people dig them as bedroom amps. :hmm:
  8. CosmicEnergy
    197
    50
    Feb 7, 2014
    It didn't work neither, it just got louder, but thanks for your help :)
  9. sonar
    sonar Senior Member
    2,891
    1,988
    Sep 10, 2008
    Because people like how they sound.
    It's a low powered amp designed for low volume gain, not power tube overdrive.
    If you want a small single-ended amp that you can crank, look into the Champ circuit (or one of its many derivatives) AC-4, Class 5, Blackheart, boutique whatever...
  10. sonar
    sonar Senior Member
    2,891
    1,988
    Sep 10, 2008
    Can you prove this?
  11. CosmicEnergy
    197
    50
    Feb 7, 2014
    Damn, i didn't know that, but if i change that tube for an EL34 it will do the same thing, right? damn, manufacters shouldn't lie about specs! this is like the third time that something like that happens to me :mad:
  12. CosmicEnergy
    197
    50
    Feb 7, 2014
    Crap! they should say it's a hybrid amp intead of lying
    2 people like this.
  13. sonar
    sonar Senior Member
    2,891
    1,988
    Sep 10, 2008
    You trolling?
  14. Barabus
    Barabus Senior Member
    1,222
    1,209
    Oct 19, 2012
    Gain all the way up, volume all the way down, then just slowly up the volume you'll get all the distortion you want, careful though as it's bloody loud!
  15. CosmicEnergy
    197
    50
    Feb 7, 2014
    No, blackstar says it's an "all tube" amp, but is a hybrid but it costs more than a hybrid
  16. CosmicEnergy
    197
    50
    Feb 7, 2014
    Thanks, i'll try that later! but, isn't that trick used to have lots of sustain at low volume?
  17. Marshall & Moonshine
    21,555
    37,893
    Jul 21, 2010
    Way ahead of ya.....
    (5f2a-ish homebuild :)
  18. sonar
    sonar Senior Member
    2,891
    1,988
    Sep 10, 2008
    Do you have any real evidence to back up your comment?
  19. stealthelephant
    stealthelephant Senior Member
    1,460
    769
    Feb 1, 2012
    Careful now, u will be showed a pic of the circuit as evidence. But u won't understand it and in reality it could be a toaster circuit.... At least that's what happened me ;)
    Blackstar say its tube distortion and the OPamps don't distort. So does my buddy.
    Peeps here say it isn't. In the end u gota decide if its that important for u to care enough about
  20. slagg
    slagg Senior Member
    587
    212
    Apr 5, 2010
    open it,see for yourself.Opamp drives the signal,diodes clip the waveform creating distortion from da tube.It is technicly tube distortion,but it gets there a lot different then a true tube driving a tube curcuit.Take two diodes together reverse polarized.solder both ends together.solder one end in the signal path after a coupling cap and the other end to ground,WOW distortion!
    Never said they suck,just tain't my thang.
