Truss rod adjustment on new guitar
Discussion in 'Gibson Les Pauls' started by Nate Henderson, Nov 9, 2017.
  1. Leña_Costoso
    Leña_Costoso Senior Member
    733
    687
    Aug 28, 2017
    Depends on where its buzzing. Buzzing under fret 5 usually means the neck is a bit too flat, needs more relief. Buzzing up higher usually means bridge too low.
    The measured relief is so important in 12th fret tolerable action height. Nut slot depth makes a difference too. Then again playing style - how heavy you pick, matters. If fretting out on bends is an issue, the neck radius matters.
  2. Malikon
    Malikon Henshin! V.I.P. Member
    65,207
    178,922
    Jan 21, 2010
    Not hold the nickel in place like it wouldn't fall out if i tilted the guitar, but touching enough to balance it on the fret with the guitar laying flat.
    It's a good trick plus it works for stuff like fenders where you have to match the strings to the radius of the fretboard. You just have to use the nickel on each string and you'll match the fretboard radius.
  3. Nate Henderson
    Nate Henderson Member
    74
    26
    May 24, 2017
    Makes sense. But neither of those things are problems with the guitar, right?
  4. endial
    endial Senior Member
    2,201
    1,883
    Oct 23, 2014
    Nope. All is good so long as it can be adjusted. That guitar is killer. Now go play it.
  5. moreles
    moreles Senior Member
    2,661
    1,279
    Apr 16, 2011
    I have no idea if Gibson or its dealers are really doing any decent setup anymore. I encounter guitars all the time -- all the freaking time -- that have way too much relief, and almost always it's because the truss rod hasn't been adjusted, or even brought up tp minimal tension, since the thing was built. Most owners don't know how to do a really decent setup, and many dealers don't bother, so there are loads of poorly set up guitars out there.
    endial likes this.
  6. Mr. Pickles
    Mr. Pickles Mr. Pickles loves you. Mwah! ♥ Premium Member
    4,077
    3,426
    Jul 6, 2015
    Rarely have I pulled a Gibson off the shelf that has a great setup.
  7. RicOkc
    RicOkc Senior Member
    107
    58
    Jul 8, 2015
    Considering humidity /weather changes from where the instrument was made to wherever it's being shipped to adjustments of any kind is not unusual.
    As to the statement made previously about Fender micro adjuster vs shims. I have a Strat that I've owned for 22+ years and it's neck angle is adjusted using the micro-tilt and it's not had any negative effect at all.
    Consider the source.
