Truss rod adjustment on new guitar
Discussion in 'Gibson Les Pauls' started by Nate Henderson, Nov 9, 2017.
  1. Nate Henderson
    Nate Henderson Member
    75
    26
    May 24, 2017
    Not sure what you mean by this. Comparing the height of the bridge to the width of a dime/nickel?
  2. brianbzed
    brianbzed Senior Member
    2,244
    1,128
    Aug 14, 2008
    Not usually a problem, ALL my Gibsons needed a little tweaking when I first got them. I've only bought one new guitar (solidbody) that didn't need any adjustment.....my Carvin DC.
  3. chasenblues
    chasenblues Senior Member
    21,199
    31,882
    Apr 2, 2007
    Something like this,
    Leña_Costoso and Thumpalumpacus like this.
  4. Nate Henderson
    75
    26
    May 24, 2017
    Just bought the guitar, I'll post pics when I get the chance.
    I measured the action directly and it's about 5/64" on the low e and a hair under 4/64" on the high e (I start getting too much buzzing on the b string of I go lower), so pretty good to me.
    endial likes this.
  5. Cjsinla
    Cjsinla Senior Member
    3,467
    2,660
    Jul 7, 2014
    I used to take a tuning fork in. They play slinky in the store and differently at home i found out they frequently tune down 1/2 step.
    endial likes this.
  6. endial
    endial Senior Member
    2,335
    2,104
    Oct 23, 2014
    We'll need photographic evidence. (Congratulations!)
  7. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,928
    185,814
    Nov 28, 2010
    Nah, what he does is lays a nickel on the 12th fret low E and lowers the bridge until the strings hold it in place, then repeats the process on the high E with the dime. I don't do it that way myself -- I use the Mk I eyeball and a little playing -- but I end up spec'd out pretty much as he describes his setup, maybe a tad higher.
    endial likes this.
  8. PierM
    PierM Black & Gold Premium Member
    3,323
    5,322
    Aug 19, 2016
    Totally normal. Guitars are using a trussrod because they need it.
  9. Nate Henderson
    75
    26
    May 24, 2017
    Here she is!
    Thumpalumpacus, endial and fry like this.
  10. fry
    fry Senior Member
    2,171
    2,803
    Jan 10, 2011
    LIKE
  11. marksoundguitars
    marksoundguitars Chief Paint Sniffer
    690
    1,051
    Jan 24, 2017
    Every new build I ship has a basic setup. I advise my customers that a new guitar needs to settle in and might need further adjustment. If they have a favorite tech, they should take it in for a full custom setup to their preference.
    Thumpalumpacus, endial and mudface like this.
  12. Leña_Costoso
    Leña_Costoso Senior Member
    733
    691
    Aug 28, 2017
    US Dime - .054 inches. As close to 3.5/64ths as you can do by eye.
    US Nickel - .077 inches. Just an RCH shy of 5/64ths.
    Nice trick. Not bad starting points at all! Dunno about the "holds the coin in place" thing, that would imply tension, which would upset the measurement. To me its more like "just rests on the coin". But still... nice pocket gauge to go by.
    Thanks for mentioning that!
    Thumpalumpacus and endial like this.
  13. Nate Henderson
    75
    26
    May 24, 2017
    I've been playing with the action a little more and I can get the high e down just a little under 4/64", then the b string starts buzzing more than I'd like. Is that normal?
    endial likes this.
  14. grayd8
    grayd8 Senior Member
    1,382
    1,122
    May 5, 2014
    Completely normal, seems like the longer I have a guitar the less I adjust the truss rod.
  15. endial
    2,335
    2,104
    Oct 23, 2014
    Yup.
    That, to me, is the signal to stop. Adjust it right around where you can tolerate the "buzzing" (plug in and check what your amp tells you, too), and from that point is where you can tweak the truss rod to give maybe juuuussst a liiiiiiiitle more relief to get the action a hair lower, IF at all necessary. Ultimately, you should begin with the neck straight(ish) and do this.
  16. Thumpalumpacus
    75,928
    185,814
    Nov 28, 2010
    You'd have to ask @Malikon how he does it exactly, and whether he prefers pre-1964 silver dimes. :p
  17. Thumpalumpacus
    75,928
    185,814
    Nov 28, 2010
    That's a handsome guitar, Nate.
  18. Thumpalumpacus
    75,928
    185,814
    Nov 28, 2010
    You should be able to get 1/16" action there. Can you isolate the fret where it's buzzing?
  19. Nate Henderson
    75
    26
    May 24, 2017
    You mean 1/16" at the high e? I can get to 1/16" (4/64") on that string. When I go much lower the b string starts getting too buzzy, mostly around the 12th fret. 1/16" feels like a good height though. I checked my other guitars and it's about the same.
  20. Thumpalumpacus
    75,928
    185,814
    Nov 28, 2010
    I mean 1/16" 12th fret high E. But trust your ears and fingers, rather than some schlub online.
    Nate Henderson and endial like this.
