Truss rod adjustment on new guitar
Discussion in 'Gibson Les Pauls' started by Nate Henderson, Nov 9, 2017.
  1. Nate Henderson
    Nate Henderson Member
    75
    26
    May 24, 2017
    I was in a local guitar shop today and started playing a 2017 LP traditional that caught my eye. I immediately realized that there was way too much neck relief, so I asked the tech there to tighten the truss rod on it. After that it played and sounded great. My question is, if a brand new guitar needs a substantial truss rod adjustment, could that be a sign of some underlying problem or is that within the realm of normal?
  2. endial
    endial Senior Member
    2,335
    2,104
    Oct 23, 2014
    I think it's within the realm of normal. I gotta tell you, I wanna take tools with me every time I go to GC for that very reason. Every Gibson I seem to try out has high action (easy enough to tweak while nobody's looking) and needs a neck adjustment.
    jstarr823 likes this.
  3. RichBrew
    RichBrew Senior Member
    4,999
    7,605
    Aug 14, 2010
    I have yet to buy a new guitar that hasn't required adjustments to set it up to my preferences.
    jeff_farkas, Who, 1all's Pub and 2 others like this.
  4. kiko
    kiko Senior Member
    1,122
    1,272
    Jul 16, 2015
    Nothing out of the ordinary, most new guitar needs an adjustment of sort. Becomes a problem only when the new guitar's trust rod is maxed out or stuck.
  5. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,925
    185,792
    Nov 28, 2010
    It's usually no worry, but do take the time to see where the bridge is -- if it's decked, that relief could have been dialed in to accommodate an improperly-set neck.
    bungle, BBD and endial like this.
  6. Nate Henderson
    75
    26
    May 24, 2017
    What does "decked" mean?
  7. endial
    2,335
    2,104
    Oct 23, 2014
    As far down as it will go. The "deck" being the guitar body.
    Thumpalumpacus likes this.
  8. Nate Henderson
    75
    26
    May 24, 2017
    Oh, no I checked the bridge and there was still a good amount of room to go down with the action set pretty low.
    Thumpalumpacus and endial like this.
  9. endial
    2,335
    2,104
    Oct 23, 2014
    Then you're golden.
    BBD and Thumpalumpacus like this.
  10. The Ballzz
    The Ballzz Senior Member
    1,480
    986
    Mar 28, 2013
    In the Fender world, it is often considered "normal" for a new guitar to require a fret level/crown/dress/polish, :facepalm: in addition to truss rod adjustments and full setup. :wow: Of course even the fender factory considers it normal practice to shim their necks with credit card type material (or "yuck" micro tilt systems) to correct for improperly/poorly routed neck pockets in the bodies. :run: Now don't get me wrong, I love a good Tele or Strat, but one with a shimmed neck certainly doesn't qualify as "GOOD" to me and definitely won't be coming home with me!
    On the other hand, Gibson necks and frets tend to be a little better when leaving the factory, though still usually require a good setup!
    Just My $.02,
    Gene
    endial likes this.
  11. Nate Henderson
    75
    26
    May 24, 2017
    The bridge on this one was actually pretty high on the low e side. Could that also indicate an improperly set neck?
  12. Thumpalumpacus
    75,925
    185,792
    Nov 28, 2010
    <edited, see following post>
  13. Thumpalumpacus
    75,925
    185,792
    Nov 28, 2010
    It could indicate a few things -- poor neck set, unleveled frets, dumb tech still learning his trade.
    Malikon has a good setup rule, of dropping the bridge 'til it holds a dime on the high E-string and a nickel on the low-E. Perhaps start there and then check for fret buzz on the bass side of the neck? If it's buzzy on the lower strings, it could be a bum neck, or poor fret-levelling.
    endial likes this.
  14. Slick
    Slick Senior Member
    2,504
    2,722
    Aug 18, 2009
    Absolute rubbish. Fret work on a new Fender is no more considered normal than it is on a new Gibson which is just as likely to require attention.
    RichBrew likes this.
  15. Nate Henderson
    75
    26
    May 24, 2017
    This is a picture I took of the bridge on the low e side. Is that a normal height?[​IMG]
  16. Thumpalumpacus
    75,925
    185,792
    Nov 28, 2010
    It looks normal to me, most Gibbys I've owned have looked about like that. If your bridge is there, and your action is satisfactory after taking out the relief, then yeah, I'd say you're good.
    ETA: Bridge p/u seems mighty close to the strings, though.
    Nate Henderson likes this.
  17. ARandall
    ARandall Senior Member
    12,013
    7,478
    Apr 16, 2012
    There are many variables with guitars, especially Les Pauls. Neck angle is one that has a tolerance and will affect bridge height.
    Another is the finishing work on the carve.....meaning that you might have slightly more or less wood sanded away around the bridge stud area.
    Both of which make an isolated picture of a bridge pretty much useless.
  18. Valkyrie
    Valkyrie Senior Member
    305
    219
    May 23, 2011
    I have had to tweak every guitar I ever owned, from $4k PRSs to $350 Squires. My LPs all needed a good setup but I do it myself. I deck the tail piece on all of them and have no issues with string clearance on the bridge at all. Each guitar is different. I just keep tweaking them until they are right. Fortunately I haven’t ad any fret problems but I do polish the frets on all my guitars after I buy them. I tape up the fretboard and hit them with 1200-2000 paper. The strings play like they are on greased rails.
  19. 1all's Pub
    1all's Pub Senior Member
    3,329
    3,360
    May 26, 2015
    Yep totally normal for a new guitar to need an TR tweak. Neck relief preference is subjective in the first place, so who knows if A) the guy setting it up at the factory likes them with more relief or B) he really wasn’t paying attention to the neck relief on that particular guitar or C) he set it fine, but in the packing/shipping/unpacking/etc process from one climate to another it just turns out that it needs readjustment.
    If you like the guitar and the TR adjustment set the relief where you like it (and the bridge isn’t “decked” as mentioned above) you should be good to go. Enjoy... looking forward to your NGD thread! ;)
    endial and Thumpalumpacus like this.
  20. Nate Henderson
    75
    26
    May 24, 2017
    Yeah the reason I asked about the height is that I wondered if that height was normal with respect to a normal neck angle or if it indicated a problem with the neck. The action was about right with the bride there.
