Trad Pro split-coil P90s wiring diagram?
Discussion in 'Gibson Les Pauls' started by honeychrome, Jan 1, 2018.
  1. honeychrome
    honeychrome Junior Member
    6
    0
    Mar 24, 2017
    I’ve got a LP Traditional Pro that originally had P90s with push-pull coil tapping on the vol pots. Initially didn’t really get along with the P90s and had some TVJ Powertrons put in it- shop also put in new, non-switch pots, etc. I want to go back to stock with the P90s & tap, but can’t find a wiring diagram- anyone have any ideas? Thx
  2. guitarjoem
    guitarjoem Senior Member
    497
    258
    Dec 15, 2014
    The wiring diagram for split coil humbuckers is the same:
  3. Justin_Case
    Justin_Case Senior Member
    6,000
    3,430
    Apr 29, 2009
    JMHO - but coil tapping on a P90 is not a lot of add value.
    The net effect is a about the same as just rolling back, or bringing up the volume knob.
  4. honeychrome
    6
    0
    Mar 24, 2017
    Yeah, I'm not adding it- the coil tap was a stock function on this particular model, just putting it back to stock.
  5. honeychrome
    6
    0
    Mar 24, 2017
    OK, that makes sense... puzzle now is which lead is which on the P90s- they each have a black, a grey and a ground...
  6. guitarjoem
    497
    258
    Dec 15, 2014
    Well then I don't know how they do a coil tap with that. It would seem the grey is signal + and the black is signal - in your description. Up the grey wire is there a split?
