Thoughts Please...
Discussion in 'Gibson Les Pauls' started by 46&TWO, Dec 7, 2016.
  1. 46&TWO
    46&TWO Senior Member
    367
    129
    May 22, 2013
    Intelligent opinions on this one much appreciated. I have my opinions, but would like to hear others.
    Maybe someone whose electronics are not being difficult can post the pics in the thread. Otherwise, this album should be public.
    Thanks!
    http://s904.photobucket.com/user/swissautopro/library/Les Paul Temp?sort=3&page=1
  2. Dineley
    Dineley Senior Member
    333
    96
    Apr 23, 2016
    What sort of opinions are you after??
  3. kmasters68
    kmasters68 Senior Member
    1,317
    345
    Aug 6, 2015
    What he said.
  4. TheX
    TheX Voice of Reason
    18,198
    28,627
    Jan 10, 2008
    Definitely a guitar!
  5. Side Burns
    Side Burns Senior Member
    696
    778
    Aug 28, 2013
    I assume u want thoughts on this guitar?
  6. 46&TWO
    367
    129
    May 22, 2013
    Yes and thank you.
  7. gnappi
    gnappi Senior Member
    375
    305
    Aug 12, 2012
    Are you looking for thoughts on its authenticity, originality? Do you own it, or are you looking to buy it?
  8. elephantrider
    elephantrider Senior Member
    2,491
    2,050
    Oct 23, 2015
    dry well, fellas... dry well.
  9. 46&TWO
    367
    129
    May 22, 2013
    Authenticity, originality, and any other observations. Clearly, it's missing a serial number. I do not own it, and I am not considering buying it. I was asked to provide some info on it by the owner, if possible.
  10. jc2000
    jc2000 Senior Member
    6,212
    2,973
    Jul 16, 2013
    :wow::wow::wow:!!!
  11. Cjsinla
    Cjsinla Senior Member
    3,189
    2,276
    Jul 7, 2014
    Pots look to be dated to 1978 and 1981
  12. Cjsinla
    3,189
    2,276
    Jul 7, 2014
    A few things don't look right; the gaps between the neck pup and the neck and pickguard. The lack of serial number and "Les Paul Model" on the headstock, and the green wires that go to the jack. We need pics of the bottom of the pickups to see if they are Shaws or not but I'm thinking this guitar is a good copy.
  13. 46&TWO
    367
    129
    May 22, 2013
    Thanks for the input. You and I are seeing the same things.
  14. chasenblues
    chasenblues Senior Member
    20,411
    29,689
    Apr 2, 2007
    Perfectly round wiring channel route?
    The overall shape of the Cavity route looks off to me.
  15. Detector
    Detector Gold Supporter
    491
    866
    Aug 29, 2012
    Neck volume knob looks off to me. Not where it should be.
  16. kakerlak
    kakerlak Senior Member
    1,518
    561
    Feb 5, 2014
    Looks kind of like a veneer crack at the upper bout, yet the underside of the top (in the control cavity) looks pretty flamey, so I'm not sure what to think. Speaking of the cavity, it looks very much like early '80s Gibson to me, with the sort of flattened-out lobes on each side and that little convex/quarter-round ridge around the base of the route. Wiring looks messed with, so pot codes and wire colors might not be of much importance here. Is it possible it's been refinished? Could explain the loss of model name silkscreen and S/N ink-stamp (or some heavy-handed polishing).
    Check out the cavity shape on this 1982 Leo's reissue:
    EDIT -- here's a clearer picture I snagged of another Leo reissue from our own mrfrett:
    The route looks dead on to me, but I don't think this is one of those, as they'd all have that S/N pressed into the edge of the cavity shelf
  17. kakerlak
    1,518
    561
    Feb 5, 2014
    Been poking around, looking at other Leo's reissues... Check out the pickup/fretboard gap on this other Leo's reissue I found:
    ^Also note the ramp-up/bevel at the tip of the pickguard where it mounts near the fretboard -- looks like OP's.
    I've also since found one without the stamped-in S/N in the control cavity:
  18. Christosterone
    Christosterone Premium Member
    2,709
    2,297
    Jul 12, 2016
    What's up with the lacquer?
    It looks like a grandfather wall clock I made in 7th grade wood shop..
    -Chris
  19. kakerlak
    1,518
    561
    Feb 5, 2014
    I think it might just be dirty, though it could be a refin -- the photos look funky. I'm also wondering whether there actually is an ink-stamped serial number that just got washed out by the flash reflecting off and camera focusing on all the tiny swirl marks, fingerprints, misc. grime, etc. It's sure centered up in the photo as though somebody was trying to photograph a serial number.
  20. chasenblues
    20,411
    29,689
    Apr 2, 2007
    Finish crack/separation following the wood grain?
