The Truth about Tone Capacitors
Discussion in 'Tonefreaks' started by Rodolphe, Dec 4, 2013.
  1. woolenmammoth
    woolenmammoth Senior Member
    960
    303
    Nov 29, 2011
    This has absolutely been a civil discussion for sure.
    As a professional working in audio the only responsible thing that can be done is to ask clients to listen. EVERYONE from a professional recording engineer to a Doctor with an after work hobby has an entirely unique monitoring situation. Each of those people also brings their own personal level of scrutiny to their unique monitoring. It is a liability to ensure results. I would never suggest our products make you better, simply, give it a listen at home or at work and see what you think.
    When you take a position on these things it blows up on you both ways. First you say "it makes no difference" because on your monitoring it made no difference. Client trusts you, is happy for some time, has means to go to a different tech and says "last guy said it made no difference" tech sits him down, shows him on his system beyond any reasonable doubt there is change and then you are forever wrong in that clients eyes.
    You say to clients "makes a difference", client trusts you, brings it home to his monitoring, reads something on the internet, tinkers to his best ability, hears no difference and pronounces you a snake oil salesman.
    The advice, as simple as you can make it, is to listen. The absurdity about this entire discussion, from top to bottom, is that some people somehow perceive this advice as "build a skyscraper". It is not difficult for the curious to listen to caps and they will either hear a change or not and move on. To the guy that will NEVER spend $30 on a cap, why would that guy even CARE if something he is never going to buy works or not? The whole discussion is just so silly to me. I say this of course looking at this whole topic from a water is wet, world is round perspective.
    One classic example I can offer is years ago I was helping someone with a old integrated hifi from the 50's. This is when hifi was designed by white labcoat guys and the designs are absolutely perfect. Well, my friend was trying to make some changes to the phono preamp and I made some suggestions to this guy, he took my word, bought some caps, spent all this time with it and called me one day all pissed off claiming that I didnt know wtf I was doing, he spent all this time working on the thing and its just as muddy as before, blah blah blah. So I never asked the dude what kind of speakers he had and it turns out he had some modern two way thing. These old low watt amps were in every way designed to drive very very very high efficiency horns and the amps performance with modern speakers, to put it mildly, is less than ideal. I invited this guy over with his amp, told him to bring all the parts. When he got there, I first reinstalled his old components (this was a minor change he was making) and hooked it up to 3 way horns at the shop. "Whoah, sounds amazing, what did you do??" I put your old parts back in. Silence. Let me now show you what the new parts I told you to get do. Put them in. Oh wow. Whats going on here? Next day, dude went out and got a set of old horns for his system and couldnt be more delighted. Problem was his amp couldnt drive the speakers well and the minute changes the caps were making on an efficient setup were completely swamped out under load by his speakers. Either that or his speaker didnt have the high end extension to reproduce the change he was making, never made it through the crossover, but more likely was the first scenario.
    You never know what your customer's circumstances are. Even if you can measure all the valid proof in the world, there are a million reasons and two why the average guy out there does not hear your product as an upgrade or change from their current thing and using science to prove something to that guy, in his world only makes you suspect. There are no points for being "right" because the bottom line is that if end user's cant hear the change, there is no change and thats the end of the discussion. All you can say then is ok, cool, thanks for listening. And realistically, its all you should be asking, hey, take a listen, see what ya think.
    Some people are more critical than others, not everyone has a playback that is equivalent, many playback systems can mask the very changes you are making. Arguing with I dont hear it guy is a waste of time. What is repugnant is when I dont hear it guy tells you you are a fool for hearing it regardless of the fact that %100 of the people that have heard it on I hear it guy's system heard it too.
    It's just a silly, silly, silly thing to debate. Just go listen for yourselves if you are curious, it is so not that much effort. And you dont need to build devices or do double blind tests or anything else that makes for good television. Go buy 25 caps. Record 25 clips. Label the clips in your computer 1-25. Write down some where what caps were used in 1-25. Turn off the session and forget about it for a month. Then come back to it, play 1-25 and see which ones you like the best. Then go find your piece of paper and stick that cap in your guitar. Or if you dont hear a difference just pick any cap and put it in your guitar.
    You can take a simple LC filter, hook it up to an AP and watch the curves change. This is not voodoo. At the end of the day, if you never really leave your hometown for your entire life, it just doesnt matter if the world is flat or not. Yeah, science guy might be "right" but REALLY, what impact does it have. If you are happy with your guitar sound move along. But this is a truly silly thing to debate because for every single person you might sit down and show change for, there is another guy out there that cant find that change in his monitoring and for that guy, there is no difference. Sometimes its just like putting high performance tires on a 1987 ford taurus. When THAT guy gets out of his POS and says "this high performance stuff is nonsense, these tires didnt make my car go faster or handle better this is snake oil, I want my money back" what do you say? Sir, racing is measures in the hundredth of a second?
    4 people like this.
  2. Stinky Kitty
    Stinky Kitty Senior Member
    6,843
    8,852
    Oct 31, 2012
    Thank you for the lucidity of your perspective wooly.
    (The irony of your username has never been lost on me :thumb:)
  3. Brocko
    Brocko Senior Member
    5,003
    4,839
    Jul 13, 2013
    I don't think anyone has been bickering. The article stems from someone trying to warn others away from falling for the snake oil cap thing and wasting £112 on a set that were dipped in the sweat of Marc Bolan or something. Most of the 'bickering' has come from the snake oil lobby trying to defend it!
    You are right though, do your own tests and pick the cap you like.
    I would like to hear some of the music people on here are making - I'm expecting some revolutionary sonic delights with delicate tonal sweeps as they roll off their boutique caps - lol
    1 person likes this.
  4. Brocko
    5,003
    4,839
    Jul 13, 2013
    And I certainly wasn't suggesting anyone should actually bother with doing a double blind test as described above - it probably won't convince anyone whose mind is already made up - I was just advising on how to best conduct a scientific study that would hold up to scrutiny if someone was going to go to all that effort.
  5. matt@msscguitar
    matt@msscguitar V.I.P. Member MLP Vendor
    9,628
    6,486
    May 5, 2008
    It's all snake oil :laugh2:
    Some play with calculators but I'll stick with playing guitar.
    2 people like this.
  6. Stinky Kitty
    6,843
    8,852
    Oct 31, 2012
    That is the same spirit in which I was suggesting David doing his test with the tone at zero.
    But my real truth about tone capacitors has already been stated a few times:
    People need to hear it live for themselves, most everyone already has their mind made up, no matter what someone says, someone else will disagree.
    The tragic part is that people can't allow others the validity of their own views simply because they are different. Too bad it has to be 'either or' for some rather than 'yes and..'
    Cheers!
  7. Quill
    Quill Senior Member
    4,548
    3,037
    Sep 15, 2009
    woolenmammoth, I admire your perspective on this, you are a lovely and generous writer and I really enjoy your posts. I'm only quoting these short bits to highlight them. I try to make a similar point when these discussions come up, but your experience is broader than mine and can do it better. But I can point at the points that I think hit the best notes, and hope that the skimmers and skippers go back and read the whole thing.
    2 people like this.
  8. Ginger Beer
    Ginger Beer Senior Member
    4,171
    6,833
    Feb 15, 2012
    My point is that the fake bees did indeed "subjectively" change the sound. Objectively, they couldn't have but, at the time, they were reported by many guitarists to sound noticeably warmer. Worth the price.
    This is what happens when peoples expectations influence their perceptions. They listened with their eyes. They wanted to hear a difference so they convinced themselves that they actually did. They stood as hard in their conviction as some in this thread until the curtain was finally pulled away.
    Snake oil for top dollar. Gibson knew people would convince themselves that they would hear a difference. That is the only reason they could charge as much as they did. Because they were "worth it".
  9. Brocko
    5,003
    4,839
    Jul 13, 2013
    there is a great example of this on you tube - look up andertons guitar test - they do blindfold tests where the guys who work in the shop have to pick out the custom shop models compared to squier classic vibes (they don't ghet them all right)- then they do a sound test between a gibson and epiphone les pauls - they do a sustain test and when the Epiphone guitar absolutely batters the other two gibsons (after lots of sneery remarks about expecting it just to plink) they start making excuses for the gibson and saying the test wasn't valid. Some people make there mind up before hearing the evidence (politics is based on this - how can a reasonable human claim to be a democrat or republican - surely the wise thing to do is listen to the options and choose the one you agree with, not just blindly follow)
