The Trading Post
Discussion in 'Member Classifieds' started by FLICKOFLASH, Dec 12, 2008.
  1. Nicky
    Nicky On The Road Less Traveled Premium Member
    16,912
    24,976
    Aug 28, 2007
    Anyone got a Fulltone Tube Tape Echo, Echoplex EP-x, or Roland Space Echo to trade for my Pete Cornish NG-2? These are insane fuzz pedals.
    From Pete Cornish website:
    "In the range of generally available fuzz boxes covering a scale from 1 through 10, this one goes to 15! Specifically designed to simulate “imminent amp death” this custom built unit features several separate stages so that the user may tune it to his or her own degree of "I.A.D."
    The first stage is a linear DRIVE with up to +26dB of gain feeding the second stage, a stabilized “germanium” preamp which overloads smoothly when overdriven. The third stage is where the NG magic takes place. It simulates a tube amp that has been over biased or has suffered serious tube or output transformer failure (The sound just before the fuse blows). The SUSTAIN control adjusts the signal level into the third section and can be adjusted from "tired output tubes" to "melted tubes and shorted output transformer."
    TONE and VOLUME controls complete the ensemble to allow matching to your bypassed signal. To glory in the sound of this pedal, feed it into an amp capable of delivering huge amounts of clean, pure tone into your speakers.
    DETAILS:
    The NG-2™ features easy battery replacement via the "drawer." The battery is switched on when you insert the “INPUT/PWR ON” jack and to ensure long battery life unplug this lead when the unit is not in use. If the unit is not to be used for a long length of time it is recommended that you remove the battery. Preferred battery type is MN1604.
    Also fitted is an input for a DC adaptor: the size of the connector is M2.1 and the tip is negative (-VE). The voltage rating of the adaptor should be fully stabilized at 9.6V and capable of supplying 20mA. Cornish recommends the use of the BOSS PSA series adaptors (PSA-100/110/220 or 240 depending on your local AC supply voltage) as meeting the above criteria and cannot accept any liability for damage caused to this unit by the use of any other type of AC/DC adaptor.
    Although the current consumption of Cornish stand alone pedals is extremely low, giving an extended battery life, it may be appropriate to use an AC/DC Adaptor for long term usage. If a single pedal only is in use then the Boss PSA series will be cost effective but Cornish does not recommend this unit for powering multiple effects as ground loops can become troublesome.
    After extensive testing for both noise, stability and reliability Cornish recommends the Voodoo Lab Pedal Power 2 Plus as being suitable for powering their range of stand alone pedals - particularly when multiple effects are in use. The isolated outputs of the Pedal Power 2 Plus prevent the occurrence of ground loops and the noise level is too low to measure.
    ABOUT CORNISH PEDALS
    Pete Cornish, the creator of integrated guitar effects and amp routing systems for the worlds best known performers has revolutionized the way music is performed. Pete's creations allow you to "Free The Tone" and enjoy the artistry of music making both live on stage and in the studio. From integrated effects boards to power distribution units, guitar cables to custom speaker cabinets, Pete's individually handcrafted products are rugged, dependable and free from ground loop noise, using only the best available components for maximum durability."
    Specs:
    INPUT AND BYPASS BUFFER: RFI rejecting
    CONSTRUCTION: hand built, hand wired, hand tested
    HOUSING: rugged die-cast box with "chicken-head" pointer knobs
    FOOTSWITCH: heavy duty custom made all-metal
    LED: Hi-Brite
    DIMENSIONS: 171mm X 121mm X 55mm
    WARRANTY 1 year, non-transferable
  2. TexasFlatpicker
    TexasFlatpicker Senior Member
    239
    92
    Mar 9, 2015
    I have a 2011 Les Paul Studio Deluxe Heritage Cherry Sunburst with the 60's neck for trade. Pup's have been replaced with Seymour Duncan SH59/SH11. Has split coil too. Excellent condition.
    I believe it was one of the Guitar Center exclusives.....
    Looking for a PRS
    Thanks!
  3. Tangerine
    Tangerine Guitaraholic Premium Member
    1,929
    1,295
    Jan 17, 2010
    I went through some stuff in my jam room today and dug out all the stuff I'm not using. I'm open to trades for music/guitar related items for any of the straps. As you can see I don't need another strap. :laugh2: I don't know the brand on the black leather one but it's a really nice padded one. For the strings I'm looking for 10-46 electric strings or 11-52 acoustic.
    EDIT: One of the packs of strings is spoken for.
  4. tigerfan22001
    tigerfan22001 Senior Member
    727
    16
    Jun 12, 2008
    I have two guitars that I'm not playing at the moment.
    First is a tele partscaster. I got from a guy that did a "relic" on it. I'll be honest looks like crap but sounds good. I'm not sure of the origins of all the parts but it looks like at least a mexican tele body and it supposedly has a mahogany neck. It has a p90 in the neck (supposedly a seymour duncan) and a gfs pro series overwound tele bridge. All the pots are of good quality and so is the switch. Comes in a hard case (ibanez).
    Next is an Ibanez AGR73T. Basically a thin white falcon. Sounds really nice, but I just don't care for the bigsby all that much. Immaculate shape basically brand new, but it does not have a case.
    I also have a duncan hot rails bridge that has pretty short leads that I took out of the tele for trade.
    I'm looking for an amp. Would love a fender custom vibrolux or something tweed or brownface style. Would also be interested in a marshall style amp or d style amp. Really open to anything except blackface style.
    I'd also be interested in a Les Paul or PRS style guitar. I'd also like a lava retro coil cable. Maybe some strat pickups or parts that will fit a classic vibe.
    I also have some pedals on the pedal trade thread too.
    I"D TRADE ANY COMBINATION OR ALL (including the pedals) FOR A PRST DGT OR THE RIGHT AMP.
    I'm in North Alabama and don't mind shipping, but being that I don't have a case for the Ibanez, I wouldn't mind driving up to four hours to swap.
    If you have any questions let me know.
    Really just looking for some different stuff so make me some offers.
  5. integra evan
    integra evan Senior Member
    1,116
    495
    Nov 7, 2007
    Putting up my built Stratocaster for trade. I'm looking for a large combo tube amp - Marshall, Fender, etc...or a decent half stack.
    2011 Roadhouse Strat body
    AllParts USA neck, C profile, jumbo frets
    EMG HSS pickups - great sounding and a lot of flexibility in tones with this setup
    All Fender hardware, softail tremolo bridge
    Fender pearloid pickguard
    Set up and plays nicely
    Comes with Road Runner hard case
    [​IMG]IMG_0040 by ejrj6586, on Flickr
    [​IMG]IMG_0051 by ejrj6586, on Flickr
    [​IMG]IMG_0065 by ejrj6586, on Flickr
    let me know what you have. Would even consider another Les Paul lol.
  6. questionman
    questionman Senior Member
    3,837
    3,695
    Jun 2, 2014
    I am looking for a blank Les Paul truss rod cover.
    Trade it for a potentiometer or something. Would prefer it to be a little on the older side or aged. Nothing brand new
  7. Tangerine
    1,929
    1,295
    Jan 17, 2010
    All gone.
  8. steamer70
    steamer70 Member
    93
    22
    Jun 27, 2013
  9. lususnaturae
    lususnaturae Junior Member
    25
    9
    May 31, 2009
    I have a 1967 (made in Kalamazoo, MI) Epiphone Casino that I'm placing up for trade for the right 60's Fender Custom Shop Strat, or possibly a 70's Strat. The guitar is a 'players' grade instrument with an old, and perfectly stable headstock break. Replaced parts include a new Gibson ABR-1 bridge and repro Kluson tuners. Stock frets are in very good condition. No pickguard and an old Guild made hardshell case is included. The Epi has been professionally setup and plays and sounds superbly well.
    1 person likes this.
  10. SrDeMaFp
    SrDeMaFp Senior Member
    579
    128
    Nov 21, 2009
    Looking for some passives. I just can't seem to get along with the EMG DG-20 singles/control set-up. Noiseless, stacked pups, single sized pups, etc. are more than welcome. Shoot me some offers.
    Thanks,
    -Mike
  11. RainbowPunk
    RainbowPunk Senior Member
    1,351
    230
    May 17, 2010
    This is a Peavey Raptor Plus that I rescued from a pawn shop. I gave her a deep cleaning, replaced a lot of the smaller hardware (new tremolo springs, new saddle springs, new pickguard screws, new jackplate, etc.), and put in new pots. I'll include a Fender backpack-style gig bag.
    I'm looking for pickups, pretty much any effects pedals, or a LP-style hard case.
  12. o0sanity0o
    o0sanity0o Senior Member
    1,375
    1,588
    Sep 22, 2011
    I'm really looking for a set of Bareknuckle Piledrivers for my Tele.
    What I have FT is a set of Fender Texas Special pups. all still wired to the pickguard they came with which includes a rotary s-1 switch (kinda pre amp boost)
    These were around 6 months before I replaced them so there's no visible signs of wear.
    Sorry for the crappy iPhone pics
    Always open to offers if you have other Tele pups up for offer that would be along the same lines as the Piledrivers. Although I'm not really interested in hot rails etc.
  13. northernguitarguy
    northernguitarguy SWeAT hOg
    26,833
    42,948
    Feb 22, 2009
    I have an EHX Deluxe Electric Mistress to offer for an Eminence Reignmaker speaker.
  14. Electric Funeral
    Electric Funeral Senior Member
    2,593
    1,664
    Dec 9, 2010
    I'd like to swap the chrome Grovers on the 50's Tribute SG I just got.
    Open to any kind of Kluson-Deluxe type tuner, bolt bushing or vintage style (I'd use conversion bushings). Also open to the "3-on-a-plate" type.
    Thought I'd put it out there in case anyone has an SGJ/LPJ or something and wanted to trade/upgrade their tuners.
    Like the guitar itself, the Grovers are brand new and barely used. Would sell them for $40 shipped as well.
  15. RainbowPunk
    1,351
    230
    May 17, 2010
    Just wanted to mention it's longer available for trade, I'm selling this now. (I would just edit the original post, but it won't let me)
  16. tigerfan22001
    727
    16
    Jun 12, 2008
    After messing around with the tele, I've decided to keep it and try to repaint it.
    Still have the Ibanez and pickup, along with two TC pedals in the pedal trade thread.
    I'm also interested in Amp in a Box pedals and looking for a big clean amp (Hot Rod Deluxe or something, although I would prefer a head and cab).
    Let me know if you're interested in anything. Make me an offer.
  17. soma1975
    soma1975 Member
    30
    21
    Mar 18, 2015
    UK based but happy to send to EU or US as well.
    I have an old original Marshal Guv'nor
    The pots are scratchy when you turn them and need a clean but once set it sounds great.
    I have a Wampler Plexi-Drive so this is a bit redundant.
    Looking to trade for any one of:
    a decent true-bypass wah (not vox or standard crybaby)
    decent true bypass tremolo pedal
    some sort of rangemaster clone - BYOC or HBE etc..
    Please PM with any offers.
  18. northernguitarguy
    26,833
    42,948
    Feb 22, 2009
    Still got it!
