The Official Historics & Reissues Modification Thread
Discussion in 'Historics & Reissues' started by Barker, Nov 1, 2011.
  1. Barker
    Barker Senior Member
    2,857
    1,997
    Feb 21, 2010
    Killer!!
  2. kungpow!
    kungpow! Senior Member
    1,459
    485
    Jan 7, 2009
    Just some DIY wiring work. Russian PIOs .015 neck and .022 bridge into a Special. Pots are stock. Limed mahogany.
    Mojotone 500K pots and PIO .022 cap into a Doublecut junior. TV White.
  3. les strat
    les strat Senior Member
    163
    6
    Dec 20, 2007
    Guitar - 2004 R8, faded cherry, gloss, or was lol
    Tuners/Tips - RS aged Klusons
    TRC - stock
    Nut - stock. Vinyl coming soon with refrett and plek
    Inlays - stock
    Fretboard - stick
    Switch Ring (aka.. Poker Chip) - stock
    Switch Tip - RS
    Switch Nut - RS
    Pickup Rings - Creamtone vintage M69
    Pickups (and Covers) - SD Antiquities w/A4's, 8.2K bridge and 7.3K neck
    Pickguard - Mojotone vintage fit
    Pickguard Bracket - stock
    Bridge (posts, and thumbwheels) - stock post (nickel-coated brass, and Creamtone aged wheels
    Tailpiece - stock
    Tailpiece Studs - Pigtail
    Knobs - aged RS
    Pointers (knob) - stock
    Jackplate - Creamtone
    Pots - RS CTS 500K
    Caps - vintage bumblebee PIO
    Backplates - stock
    Refinished - stock
    Other Mods - 50' wiring, straplocks
    Future Mods - nylon nut, refret, new easier to turn pots
    I Made The Mods To My Guitar Because - tone and looks
    LPJR likes this.
  4. sapi
    sapi Senior Member
    894
    72
    Jun 8, 2007
    '07 R9 aka 'Ghostburst'
    HM A (Dave Johnson)
    Nice plastics (Vintage Haven pu rings)
    Uncle Lou Premium tuner tips
    Correct TRC
    DMC Jackplate
    TusQ nut
    RS solid Aluminium TP
    Callaham steel ABR-1
    Pigtail steel TP studs + correct bushings
    Correct thumbwheels (Retrospec, brass)
    Pigtail heat-treated steel ABR-1 posts
    SD Dave Stephens '59 NOS wire pickups
    Throbak pu covers
    Jensen Copper foil PIO caps
    Calibrated Dr Vintage pots w/ '59 wiring
    Sorry cannot remember all the plastics! I prefer lighter pu rings and a darker (yellowish) pickguard.
    I did the mods primarily for tone, second for looks. I'm very happy with the results!
    [iPhone pic]
  5. d1m1
    d1m1 Senior Member
    2,359
    2,556
    Oct 30, 2012
    Guitar - 2010 R5 Goldtop Wraptail
    Weight - 8.1 lbs.
    Tuners/Tips - Standard
    TRC - Wizz
    Nut - Standard
    Inlays - Standard
    Fretboard - Standard Rosewood
    Switch Ring (aka.. Poker Chip) - Wizz 1954
    Switch Tip - Wizz
    Switch Nut - DMC
    Pickups (and Covers) - Orig. 1952 Gibson P90
    Pickguard - MojoAxe
    Pickguard Bracket - Standard
    Wraptail - MojoAxe Compensated
    Studs - MojoAxe
    Knobs - Orig. 1954 Gibson
    Jackplate - Wizz
    Harness - MSSC Holy Grail
    Caps - Orig. 50ies Bumble Bees
    Backplates - Standard
    Refinished - no
    Other Mods - none
    Future Mods - Tuners (Fake58)
  6. d1m1
    d1m1 Senior Member
    2,359
    2,556
    Oct 30, 2012
    Guitar - 2010 R5 Alnico Custom Wraptail
    Weight - 8.6 lbs.
    TRC - Standard
    Nut - Standard
    Inlays - Standard
    Fretboard - Standard Ebony
    Switch Ring (aka.. Poker Chip) - Orig. 1958 Gibson
    Switch Tip - Wizz
    Switch Nut - Standard
    Pickups (and Covers) - Orig. 1956 Gibson P90 and Alnico Staple
    Pickguard - Standard
    Studs - MojoAxe
    Knobs - Orig. 50ies Gibson
    Jackplate - Standard
    Harness - MSSC/ECP Holy Grail
    Refinished - no
    Other Mods - none
    trapland likes this.
  7. d1m1
    d1m1 Senior Member
    2,359
    2,556
    Oct 30, 2012
    Guitar - 1993 R6/R7 Historic Goldtop
    Tuners/Tips - NOS PAT. PEND. Grovers
    TRC - Wizz
    Nut - Bone
    Inlays - Cellulose Nitrate Inlays
    Switch Ring (aka.. Poker Chip) - Wizz 1959
    Switch Tip - Wizz
    Switch Nut - DMC
    Pickup Rings - Wizz
    Pickups (and Covers) - Wizz ltd. 50ies Wire
    Pickguard - MojoAxe Custom Made
    Pickguard Bracket - DMC
    Bridge - DMC
    Thumbwheels - DMC
    Tailpiece - DMC
    Tailpiece Studs - DMC
    Knobs - DMC
    Jackplate - Wizz
    Pots - MSSC/ECP Holy Grail
    Refinished - no
    Other Mods - Routed for Humbuckers (by first owner Mick Ralphs)
    Future Mods -Nope. It´s Perfect :)
  8. Shawn Lutz
    Shawn Lutz Senior Member
    5,155
    4,966
    Mar 26, 2012
    I only have 2 RI's/ In my BB7 I changed the Gold Grovers to waffle backs with vintage tulips. I aged the covers and went with a SD Custom in the bridge. On the R7 Goldtop I have a set of SD Antiquities. Both guitars look, play and sound great to me so I don't have any further plans except wiring the BB7 for one PU hot in each of the 3 toggle positions.
  9. asapmaz
    asapmaz Senior Member
    1,344
    1,381
    Oct 13, 2011
    1997 R8 (nicknamed "Great White Buffalo")
    • Aged DMC jack plate
    • Aged DMC knobs
    • Aged DMC pointers
    • Aged Retrospec offset steel tailpiece studs
    • Aged DMC aluminum tailpiece
    • Aged MGL/CreamTone TruVintage brass bridge stud and thumbwheel set
    • Aged OTPG/Vintage Haven bone rings
    • OTPG DW pickups with aged OTPG covers
    • Aged Vintage Haven poker chip
    • Mojoaxe PGV59 Vintage Replica pickguard
    • Aged Retrospec knurled nut
    • Vintage 1959 catalin switch tip
    • Historic Makeovers/Retrospec inlays
    • Holy grail wiring harness with Nos bumblebee capacitors
    • Aged Retrospec truss rod cover
    • DMC tuner ferrules
    • Vintage 1959 Kluson Deluxe tuners with aged Vintage Haven tips
    gvon and PermissionToLand like this.
  10. ashbass
    ashbass V.I.P. Member
    661
    499
    May 3, 2007
    Shawn Lutz likes this.
  11. Burty459
    Burty459 Member
    52
    103
    May 29, 2017
    IMG_7675.JPG IMG_7674.JPG I just added some double cream Monty's PAF's into my 2008 R9, sounds awesome looks great!
    Shawn Lutz and syscokid like this.
  12. Unionjack515
    Unionjack515 Member
    65
    93
    Feb 26, 2014
    ECC8EBB9-BB84-4718-8219-5546615DB785.jpeg My 2013 R8 is currently 100% stock, but I’m about to drop in Haeussel ‘59s. Custom in the neck and Standard in the bridge.
    I also just sent a project 2010 Traditional off for a diet historical renovation after changing out every conceivable part. But it’s a Traditional, not an historic, so I’ll keep it off this thread...ha.
  13. Unionjack515
    Unionjack515 Member
    65
    93
    Feb 26, 2014
    Also just ordered clear cavity covers from Creamtone and a MSSC Holy Grail wiring harness for my R8.
  14. King Loudness
    King Loudness Senior Member
    655
    242
    Mar 1, 2009
    My R7 is a 2010, and I've changed the following:
    Pickups are a custom set by Sanford Magnetics done in double creme. Bridge and tailpiece are a Faber Tone Lock set. Knobs are reflectors. Also put a metal jackplate on it after I ruined the original plastic one at a gig. I still want to install locking tuners and put a new wiring harness in there with some matched caps and pots that have a better taper. They're stock aside from the bridge volume pot, which had to be changed when I had the new pickups put in.
    W.
