The Effect CAB IRs have on the preset
Discussion in 'Amp Modeling' started by frankv, Feb 23, 2017.
  1. frankv
    frankv Have You Ever Lost A Love? V.I.P. Member
    14,564
    13,010
    Aug 25, 2011
    I have the time and desire to answer your question. :thumb:
    Problem is I don' the knowledge to address your question. You want to reach out to Cybermgk. He is the Kemper guru around these parts. Me? I'm an AXE FX2 player. :wave:
  2. cybermgk
    cybermgk Singin' the body lectric Platinum Supporter Premium Member V.I.P. Member
    13,970
    18,824
    Jul 7, 2011
    @kmaster68
    Just saw this. K, to load IRs to the Kemper, you need to get a software tool called Kemper Cab Maker. It takes IRs and converts them to a format that is useable by the Kemper. More to the point, it converts them into the same format that the Kemper creates when it profiles an Amp. Even when profiling an entire amp chain and making a 'studio profile' (amp and speaker and mic, useable straight too direct recording, FRFR solutions, the Kemper separates the amp portion from the cab portion while profiling. So i's converted to that same format.
    At any rate, once converted, you put them on your USB stick, formatted by the Kemper, in the shard folder, and then put that in. You'll get a prompt on the screen associated with a button to import. Once imported, you can see by pressing the CAB button, and using the Browse knob.
    Load any rig. Press the CAB button to bring the CAB settings into focus. Now use the Browse knob to roll through them. THis will include all the CABs from the different profiles you have loaded AND any IRs you have added. stop on one, try how it sounds, use the knob to select another, onward. If you find one you like, exit out and then save that rig as a new name.
    Cab Maker Download
  3. Pwrmac7600
    Pwrmac7600 Premium Member
    8,017
    6,262
    Jun 17, 2014
    So just because I am curious. Does the Kemper allow you to use more than one cab at a time?
    Like if i wanted to load a 4X12 with V30's and a 4X12 of T75's?
  4. cybermgk
    13,970
    18,824
    Jul 7, 2011
    Yes and no. Not if they were two separate IRs or (from profiles) Cab Modules. Think of it as having just ONE CAB block on the Axe. (See my Opus), and only in one particular place in the signal path. That is one of the Axe's big advantages, is the signal path of whatever you want.
    BUT, if you had a cab profile or converted IRs that were both, you could fill that one spot with it.
  5. Pwrmac7600
    8,017
    6,262
    Jun 17, 2014
    And I assume Kemper doesn't yet make anything like Fractal's cablab to blend your own ir mixes?
  6. cybermgk
    13,970
    18,824
    Jul 7, 2011
    Nope. But, could use it to mix and save as a new IR, then use the Kemper tool to convert and load that single IR.
  7. skysc
    skysc Senior Member
    686
    238
    Jun 1, 2013
    IMO; IR are magical . i was looking for Metallica tones and found a pack of IR for guitar rig 5 .. it has IR for almost each album . i load the IR into the Reflektor of the Guitar rig 5 and can get very close to hetfield sound for each album ( from Ride the lightning to black album with And justice for all dryness distortion in between . Before downloading IR i always thought patch and simulation from Guitar Rig and other guitar software were weak and i was barely using the software . Now it sound alot more profesionnal . For Axe fx II and Kemper .. silent underground studio does ¨Clone tones¨for many artist Metallica , megadeth , pantera etc.. . they sound really close from what you hear on the album . With IR i've found software sim and modelers achieving better result then using the ¨real amp and preamp¨that the artist use to record . I dont have a Axe fx II or kemper but i can only imagine how good they must be .
    frankv likes this.
  8. Bobby Mahogany
    Bobby Mahogany Senior Member
    21,276
    31,386
    Feb 25, 2012
    This here shows one big truth I have witnessed over the years:
    Many musicians develop their own tone (I call it "the tone in your head") and are after it no matter what.
    They will like any piece of equipment that has "that tone" inside of it.
    Whether a guitar or an amp, they will always try to "zero in" on "that tone".
    Sometimes it's theirs, sometimes it's an imitation of some other musician, popular or not.
    I remember Tony Visconti saying that "Marc Bolan could plug into anything and sound like himself".
    It's part of the same "the tone in your head" search saga.
    I find the fact that you ended up sounding like your Rivera gig with the Helix quite interesting.
    In fact, you completely succeeded with the Helix because you found "the tone in your head" with it.
    Congratulations!
    Still, many also want to experiment different tones for different songs and the digital possibilities
    are endless. Another plus for digital.
    Of course, like with anything, "Your mileage may vary".
    frankv likes this.
  9. jageya
    jageya Senior Member
    158
    8
    Oct 26, 2013
    tube amp limited compared to this
    ? oh yes of course.! but the ir's seem to me just eq variations really and there is something to be said about a tube amp just having what it comes with-easy peazy.
    Can you imagine EVH sitiing with his modeler going thru 1000 ir's? All that time wasted he could be playing
  10. frankv
    14,564
    13,010
    Aug 25, 2011
    If you are the type where you want what comes of the box... then tubes are for you. In my case I wanted more. This technology gives me more.
  11. mmd
    mmd Senior Member
    2,483
    2,451
    Sep 24, 2012
    I second Frank. Why are you over here talking so much about tube amps? I keep seeing people responding to you - and there seems to be a lot of mention, on your end, about tube amps. What would you like to know?
    There is A LOT of knowledge in this forum that can help you get going. But, a lot of it is similar to having complete faith in God....
    You just have to accept it and BELIEVE it is true - despite what your analytic mind tells you.
    If you can get there, no matter WHAT science tells you, you will have unshakeable faith. Same can be said for how to get the MOST from a high-end modeling rig....
    Just something to think about.
  12. frozenotter
    frozenotter Dumbed-Down Premium Member
    2,725
    5,035
    Mar 21, 2016
    Why does that sound like amp modeling and not an actual tube amp?
    (tongue and cheek, fellas)
  13. mmd
    mmd Senior Member
    2,483
    2,451
    Sep 24, 2012
    User error, more likely than not. As I continue to help people with theirs, they are setting it up wrong
    Mr Insane likes this.
  14. Mr Insane
    Mr Insane Senior Member
    10,793
    5,803
    Dec 8, 2008
    Nah, he wasted his time tearing apart old Marshalls and modifying them for a slight sound difference.
    As a person who went from digital boards to analog and tube amps, I will be making the switch to profiling/modeling.
    Tube amps are great when they work. But they are just so damn fussy.
  15. Stuff
    Stuff Senior Member
    664
    651
    Jul 28, 2013
    You can use both tube amps and digital modellers with cab IRs. They're very convenient for those of us who don't have somewhere to run a dimed amp through a physical cab - just like digital modellers can be.
    A cab IR is a cabinet + speaker + microphone(s) + mic positioning + room bleed. It's a lot more than just an EQ variation - both in what goes into it, and that it has a time element to it.
    Never changed out the speaker on an amp? Never changed the tubes? Never had a head and run it through different cabs? These are all things amp owners do to chase their tone. Amps are only stuck with how they are from new if you want them to be.
    Choosing an IR is the equivalent to taking an amp into a studio, trying out their cabs, going through their mic locker, and figuring out which combination you want for the session. That's something that any recording artist has had to go through.
    Apart from being digital, the main difference is that you have to be both artist and engineer when you're introducing any digital element to your signal chain - especially IRs. That's not for everyone. It's easy for folks who are comfortable with all this to forget that.
    As for EVH ... We're all products of our time. The things EVH did with the technology of the day, to chase his tone, are well documented. There's a whole industry or three that only exists today because of the innovations he came up with back in the day.
    If he was a kid today, maybe he'd have to use a modeller. Maybe he wouldn't have the opportunity to own or experiment with valve amps. Maybe he wouldn't want to. Maybe he'd prefer how immediate digital is for experimenting with. Maybe he just wouldn't be able to hear the difference.
    Some people prefer digital, some prefer analog, some prefer a hybrid approach. There are many reasons why, from what you can and can't hear, to preference, to circumstances, to opportunity. There's no "correct" or "superior" choice, there's only what's right for you at the time.
    frankv and mmd like this.
  16. KenG
    KenG Senior Member
    6,284
    3,352
    Sep 13, 2009
    I haven't tried IRs on the Helix yet. Changing cab selections, using dual cabs and blending, changing mics and mic distances also has the power to really change the sound. I'm finding I'm a fan of having at least a ribbon mic on the cab.
  17. flats750
    flats750 Senior Member
    416
    223
    Nov 12, 2012
    Dude, IR chasing is a rabbit hole of its own!! lol It's a whole new kind of GAS...
    Try the Ownhammer free pack in place of your dual cabs. You won't have the sliders to change the mic's, but go through the list and find one distanced the same as you have your current cab. The other trick I use is something Jason Sadites uses, is the split crossover. Gives you one more trick in your bag to level the EQ.
