The Drama Queen
Discussion in 'Luthier's Corner' started by Barnaby, Mar 20, 2012.
  1. Seamus
    Seamus Senior Member
    129
    58
    Mar 29, 2011
    How's the finishing coming on this beauty?
  2. Barnaby
    Barnaby Senior Member
    8,621
    10,095
    Nov 5, 2010
    A basic layer sprayed, more to be sprayed in early July. :thumb:
    2 people like this.
  3. Skyjerk
    5,977
    7,123
    Feb 9, 2014
    I see. So you let each single coat harden for a couple/few months before applying the next?
    I guess that'll insure that when you are done there just ain't any off-gassing left to do ;)
    Yer takin "epic build" a bit literally don't you think? ;-)
    1 person likes this.
  4. Open_Book
    Open_Book Senior Member
    1,180
    683
    May 26, 2014
    You've ordered a crop-duster, haven't you. :)
  5. pshupe
    pshupe Senior Member
    3,390
    2,208
    Jan 19, 2012
    I have heard it's not a great idea to let it cure completely and then spray more?? The idea is that you create thin layers on top of each other which are much more prone to chipping. You may want to try and soften the lacquer with mostly thinner for the first coat. That may help. Is there a reason you are waiting so long Barnaby? Maybe so you can spray a few guitars all at once??
    Cheers Peter.
  6. Barnaby
    8,621
    10,095
    Nov 5, 2010
    Yes, the reason is to do with timing and opportunity in the workshop. Basically, I need to cover everything in plastic and turn the space into a devoted spray area. I also need the right weather and conditions, and can't do any other work for a few days. In fact, in early July I will be doing several guitars at the same time for this very reason. There's a long story behind the lacquering of this guitar...
    Thanks for the thinner tip, by the way. I will try that. :thumb:
  7. Barnaby
    8,621
    10,095
    Nov 5, 2010
    ...well, something a vowel away from that, at least. :naughty:
  8. pshupe
    3,390
    2,208
    Jan 19, 2012
    Don't take my word for it! ;-) I'd wait to get some more advice from some of the seasoned pros around here! I figured as much for the lacquer spraying. Beats spraying in the apartment though! ;-)
    Cheers Peter.
  9. Skyjerk
    5,977
    7,123
    Feb 9, 2014
    For this very reason I ended up shooting 3 guitars at once. Unfortunately the result of shoehorning the job into a smaller window than was ideal resulted in 3 less than perfect jobs :)
    I rushed the prepping and grain filling, and spraying as well.
    All 3 guitars are OK, but I know for a fact I could have done better.
    I'll only do one at a time from now on...
  10. Seamus
    129
    58
    Mar 29, 2011
    Bump for a progress report. Barn, you out there?
  11. Open_Book
    1,180
    683
    May 26, 2014
    B told me he's taking a break from here. So don't hold your breath for a possible month, Seamus
  12. Seamus
    129
    58
    Mar 29, 2011
    How about now? :hmm:
  13. Barnaby
    8,621
    10,095
    Nov 5, 2010
    It's all ready for new lacquer. The last coats reacted with the stuff underneath, so it all got scraped off and I had to begin again (sigh). Now, I simply wait for the temperature to be warm enough and can spray the clear, then buff and polish. Everything else is done.
  14. El Kabong
    El Kabong Senior Member
    5,793
    7,608
    Aug 12, 2013
    If this winter is anything like last, that should sideline you until May... :laugh2::laugh2::laugh2:
  15. Barnaby
    8,621
    10,095
    Nov 5, 2010
    Well, it's on to the re-refinish. Sanding away all the traces of the Z-Poxy as I will redo the mahogany with a different pore filler. I wonder if there'll be any guitar left by the end? :hmm:
    9 people like this.
  16. Skyjerk
    5,977
    7,123
    Feb 9, 2014
    Time flies. Seems like you only started this build four years ago ;)
    Have fun sanding that Z-Poxy. Only ever use it once.
    Never again!
    2 people like this.
  17. Freddy G
    Freddy G V.I.P. Member
    11,332
    23,633
    Mar 18, 2007
    Drama Queen indeed! :)
    2 people like this.
  18. Open_Book
    1,180
    683
    May 26, 2014
    hehe - Round 54, B. Don't let her get you on the ropes and watch her upper-cut. ;)
    [ame]http://www.youtube.com/watch?v=S-IkWpm7TS0[/ame]
  19. Seamus
    129
    58
    Mar 29, 2011
    Progress! :laugh2::thumb:
  20. Barnaby
    8,621
    10,095
    Nov 5, 2010
    Two steps forward...four back. At least my students get their instruments made! :laugh2:
