The Bear has a Helix!
Discussion in 'Amp Modeling' started by matthew bear, Oct 3, 2017.
  1. matthew bear
    matthew bear Senior Member
    4,295
    4,836
    Nov 9, 2008
    And so far it's pretty promising, actually! I'm getting used to the layout and such but I think it'll do quite nicely :thumb:
    I think the higher gain sound is better than my kemper (well, some of the kemper profiles) due to the user error of micing a cab being eliminated... I think some of my profiles have mic distortion coming through or something. Overall, I think it'll be a fun week ahead!
  2. mmd
    mmd Senior Member
    2,432
    2,356
    Sep 24, 2012
    Killer!! Hope you enjoy it as much as I do :D
  3. matthew bear
    4,295
    4,836
    Nov 9, 2008
    I am digging it, it's much easier to get good sounds from than my brief time with other line 6 stuff. I may start throwing up some quick videos tomorrow as a total newb just to demonstrate the you don't have to know much to get started.
    mmd and Donal like this.
  4. matthew bear
    4,295
    4,836
    Nov 9, 2008
    I think there may be less menu diving than the kemper in some ways :hmm:
    pretty straight forward :thumb:
    mdubya, Donal and El Pablo like this.
  5. Splattle101
    Splattle101 V.I.P. Member
    8,641
    4,146
    May 30, 2008
    What amp are you playing it through?
  6. matthew bear
    4,295
    4,836
    Nov 9, 2008
    I have QSC PA speakers that I use.
    mdubya, Pop1655 and Splattle101 like this.
  7. matthew bear
    4,295
    4,836
    Nov 9, 2008
    A video for spattle... I remembered the question about dual amping from the other thread, so I slapped this together this morning. no EQ editing, no fancy anything. just stock amps and stock cabs. though it's not a marshall (I can't remember the specific marshall you had mentioned, sorry!) it's an idea what you can do... I also don't know how to use this yet, it's really as raw as possible. I think it speaks to the improvment of the tech that I don't have to know how to do anything to get a passible sound :)
    mdubya and Splattle101 like this.
  8. matthew bear
    4,295
    4,836
    Nov 9, 2008
    I also realized I could assign a footswitch for the amps, so I can cancel either one or play both at the same time... channel switching and channel blending all at your feet, too cool!
    this may be a good foundation for my sound,(whowatt and tweed) once I get some boost and delay going :hmm:
    honestly, I don't think the kemper has any magic power over this, amp sound wise... I'm kinda shocked!
    mdubya likes this.
  9. matthew bear
    4,295
    4,836
    Nov 9, 2008
    I've assigned a delay and reverb to the who watt path, and left the tweed path bare, it's pretty rad to use the tweed amp as a overdrive of sorts, sounds huge!
    I'll post a video once I'm done refining this preset
  10. Rocco Crocco
    Rocco Crocco Senior Member
    6,573
    7,776
    Feb 8, 2013
    But how can it sound good without tubes???
    /purple.
  11. frankv
    14,528
    12,930
    Aug 25, 2011
    It cant. MB is out of his mind..
    hahahahaah
  12. matthew bear
    4,295
    4,836
    Nov 9, 2008
    Actually, I put a valve in my ass every time I plug in... that's why it sounds like ass!
    :laugh2:
  13. MusicLaw
    MusicLaw Senior Member
    748
    395
    Oct 13, 2015
    Quick Tip: Press the Parameter's Knob (for example the Amp's Master Volume) to revert to the default value setting. You may have already known this. If not it comes in really handy for most of the Parameters. Also don't overlook digging into Pedal Edit Mode which is brilliant!
    matthew bear likes this.
  14. matthew bear
    4,295
    4,836
    Nov 9, 2008
    Will do! I don't know how to use this thing yet, so I'm welcoming any tips for sure!
    MusicLaw likes this.
  15. James R
    James R Premium Member
    5,088
    8,775
    Apr 27, 2013
    You can also assign each parameter to a footswitch.
    Example:
    You would like to use the whowatt clean, but also use it as it's breaking up.
    Push in and turn the gain knob at the same time, the numbers will turn white and have brackets around them.
    Hit footswitch assign (or something to that effect, not in front of my Helix right now) and pick a footswitch.
    It will ask you for a minimum and maximum value.
    Set it to clean for minimum value and breakup for maximum value.
    Now when you hit that switch, you'll go from clean to breakup, kind of like a 2 channel amp.
    Here's where it gets cool.
    You'll probably notice a volume difference now that you have the gain set differently every time you hit the switch.
    Go to the master or channel volume and do the same thing that you did with the gain parameter, and set it to the same switch.
    Now every time you hit the switch, the gain and volume parameters are both changing with one click.
    You can do this with every parameter of every amp or pedal, which is nuts.
    They have a cap of how many parameter changes can be stored in a single preset, but I haven't hit it yet, and I mess around with that stuff quite a bit.
    fleahead, MusicLaw and matthew bear like this.
  16. matthew bear
    4,295
    4,836
    Nov 9, 2008
    Damn James, that's rad!!! I'm exited to try it and keep my tweed amp as a super boost :laugh2: I knew this thing could do a lot on paper, but when it's on your desk it's another story altogether!
    MusicLaw and James R like this.
  17. cherrysunburst00
    cherrysunburst00 Senior Member
    13,688
    23,688
    Mar 15, 2015
    Cool! CONGRATS and ENJOY
  18. MusicLaw
    748
    395
    Oct 13, 2015
    If you're so inclined, browse the Helix 2.0 User Manual PDF! The document is available for download from Line 6's site. The User Manual PDF is also provided on the USB stick shipped with each new Helix. The latest User Manual is 2.0, dated July 2016. Line 6 has stated that they update the User Manual only for full interger versions. Thus, it will not be updated until Helix Core (firmware) version 3.0 is released (likely to be) some time next year. None of the new features, enhancements, nor improvements introduced in any firmware releases since July 2016 are covered in the Helix 2.0 User Manual! For these details you must read the Release Notes for each release subsequent to July 2016, and there have been several. These Release Notes are most easily found on HelixHelp.com. They are published on Line 6's site, however, they are burried amongst the acutal firmware releases page and not easy to find.
  19. matthew bear
    4,295
    4,836
    Nov 9, 2008
    Am I crazy?!? I really like the line 6 DOOM amp! it's good with the 4x12 with greenbacks...
    Metal all day!!!! DOOM!!!!! DOOOOOOOOOOOOOM!!!!!!!!!!!!!!!1ONE
    Rhust, Splattle101 and alstev like this.
  20. AllTheSound
    AllTheSound Senior Member
    766
    664
    Oct 5, 2013
    Congrats on the Helix! It's such a amazingly powerful tool you will never get bored with it :)
    mdubya likes this.
