Telecaster Hardware History Question
Discussion in 'Fender' started by cooljuk, Aug 8, 2017.
  1. cooljuk
    13,591
    16,466
    Mar 12, 2009
    Can anyone pinpoint when Fender changed the jack cup style from the early heavy duty ones to the thin stamped ones?
    So, from this:
    To this:
    It's a little thing but also a big gaping hole in my notes that's bugging me because the two styles seem to need different size jack holes. Not for any specific projects or anything just a detail I've not been able to nail down yet. Thanks!
  2. chasenblues
    chasenblues Senior Member
    19,142
    25,674
    Apr 2, 2007
    According to this little blurb 1953,
    "The jack cup on Telecasters changed through the years. Pre-1953 jack cups were milled, and have sharper edges and "teeth" to hold it in the body. Later jack cups are pressed steel and have smoother edges and smooth sides."
    Found here, http://www.guitarhq.com/fender.html#specs
    In between "Potentiometers" and "Wiring"
    cooljuk likes this.
  3. efstop
    efstop Senior Member
    1,324
    1,582
    May 30, 2015
    Probably after CBS took over, as a lot of things changed, production-wise. Cheaper bridge and saddles, less curvy bodies, three bolt neck etc. Maybe late '60s-early '70s.
    Never mind. CB's google foo is better than mine :)
    cooljuk likes this.
  4. cooljuk
    13,591
    16,466
    Mar 12, 2009
    Thanks, man. I want to believe that but that site has a fair amount of false info mixed in with the good so I always take it with a grain of salt. If it IS that early, it should be covered in Nacho's book, which is on the way to me. :)
    Kris Ford likes this.
  5. chasenblues
    19,142
    25,674
    Apr 2, 2007
    True..Just poking around some sites seem to say late-ish 52 into 53..
    jeepers..:facepalm:
    When did they change from Slot heads screws to "Tone sucking" Philips head screw..:run:
    :laugh2:
    cooljuk likes this.
  6. cooljuk
    13,591
    16,466
    Mar 12, 2009
    That would be gradually from 51-54. Much more easily documented since you can see the screws in photos. :thumb:
    http://tele.protozoic.com
    I admit, I prefer slotted screws but only because they are a sign of craftsmanship. One of my dealers hates that I don't send my humbuckers with Philips head mounting screws. It would just be wrong to me, though (for the PAF replicas).
  7. chasenblues
    19,142
    25,674
    Apr 2, 2007
    So what's the "Vintage Correct" thread count for the screws?:hmm:
    Joking..
    cooljuk likes this.
  8. Phil W
    Phil W Senior Member
    775
    758
    Feb 2, 2012
    One reason I like my AVRI 52 Tele is the slotted head screws. Nice attention to detail.
    cooljuk likes this.
  9. cooljuk
    13,591
    16,466
    Mar 12, 2009
    Phil, my buddy/colleague has one of those. I was giving him grief about how Fender goes on and on about vintage-accuracy of the instrument but ships it without the dark circuit and blend knob. Then he explained that Fender actually included a second set of controls or mod kit to make it wired as such. My hat's off to Fender for that! They did a nice job all around. That's the guitar that ended up being used for my Tele pickup comparison demos, rather than my own builds. Mainly, because it was something folks would be familiar with and could find on the local shop wall but also a pretty nice blackguard build.
    (they still missed the underhanging neck pocket and nail holes. :naughty:)
    Phil W likes this.
  10. chasenblues
    19,142
    25,674
    Apr 2, 2007
    This?
  11. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,972
    14,234
    Nov 1, 2016
    Sometime right after the war according to my source two guys started a much needed tool and die manufacturing facility and were looking for work.
    Leo had reached a point where he needed massed produced parts as opposed to making them by hand as he had been doing.
    Race and Olmstead continued to supply Fender with stamped metal parts and tooling for many years....
    All I could find is the man's obit, but it confirms he lived and ran it at some point in the past. The obit is from Fullerton, CA.
    Olmsted, Karl A., passed away peacefully on Saturday, March 5, 2011 in Fullerton, California after a brief illness. He was 91. Born in Ohio to Paul and Marie Olmsted, Karl and his family moved to Brea when he was an infant. He attended schools in Brea and graduated from Brea Olinda High School in 1937. He and his partner owned Race and Olmsted Tool and Die in Fullerton.
    Mule Train and cooljuk like this.
  12. cooljuk
    13,591
    16,466
    Mar 12, 2009
    Not the router hump but the underhang on the other side of the pocket.
    chasenblues likes this.
  13. Walt_T
    Walt_T Senior Member
    2,851
    2,073
    Apr 3, 2014
    There are guys on the snarky Tele site (that I'm banned from) can tell you what's going on with that guitar. My '72 isn't like that.
  14. Phil W
    775
    758
    Feb 2, 2012
    Well at least you're not bitter ...
    Walt_T likes this.
  15. Walt_T
    2,851
    2,073
    Apr 3, 2014
    Nope, not bitter at all. I made a joke and it hit some nerves.
    Still, there is wealth of knowledge there.
  16. cooljuk
    13,591
    16,466
    Mar 12, 2009
    FYI - I found an answer I trust. Nacho says late 1952 was the change to the pressed steel style. :cheers2:
