Tele saddles with wound 3rd
Discussion in 'Fender' started by 5F6-A, Nov 19, 2017.
  1. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    This is how I have set my tele bridge. Compensated saddles for 1st, 2nd, 5th and 6th strings and regular for 3rd and 4th. I use a wound G string set (Rotos 12-52). Anybody else does that?
  2. PierM
    PierM Certified Naysayer Premium Member
    3,829
    6,560
    Aug 19, 2016
    You have some crazy random space between those strings. :)
    PS: I use all 3 compensated on my Tele. Impossible intonation with stock saddles.
  3. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    Picture angle gives an exaggerated impression. Also, I just had new strings on so spacing slightly off
    Do you use a wound 3rd?
  4. PierM
    3,829
    6,560
    Aug 19, 2016
    5F6-A likes this.
  5. Cozmik Cowboy
    Cozmik Cowboy Senior Member
    3,024
    2,531
    Jun 15, 2013
    I use D'Addario XL110w on my Tele - .010s with a woud G - but it has the 6-barrel-saddle bridge, so intonation is not a probalem.
  6. 5F6-A
    5F6-A Senior Member
    9,523
    2,050
    Aug 16, 2007
    Great pictures PierM
  7. kakerlak
    kakerlak Senior Member
    1,819
    867
    Feb 5, 2014
    The compensated saddles that are simply drilled off-angle can be turned around upside down to slant the opposite direction (just thread the height-adjust posts through the opposite direction and flip the saddle over 180°). That way, you can get them to do this (ASCII art time!):
    instead of:
